@mas3, I think your are right about the address line changes etc., but I believe the OP got two of these boards for the price, so that is not a bad price (if only one board it would be a bit over priced).
I have some bulky code that that may show both display, and keypad usage.
Demonstrates the use a 16x2 LCD display from dx.com
// include the library code:
#include <Time.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7); // pins for the DX.com lcd board http://dx.com/p/lcd-keypad-shield-for-arduino-duemilanove-lcd-1602-118059
//lcd(12, 11, 5, 4, 3, 2); // original arduion example pins
byte keyvalue;
int LastSecond=0;
boolean state0=LOW;
boolean state1=LOW;
boolean state2=LOW;
boolean state3=LOW;
boolean state10=HIGH;
boolean state11=LOW;
boolean state12=LOW;
boolean state13=LOW;
int barChar=90;
pinMode(0, OUTPUT); // data IO
pinMode(1, OUTPUT); // data IO
pinMode(2, OUTPUT); // data IO
pinMode(3, OUTPUT); // data IO
pinMode(13, OUTPUT); // onboard led
pinMode(17, OUTPUT); // onboard led2
pinMode(11, OUTPUT); // Pinned on ICSP of LCD Keypad
pinMode(12, OUTPUT); // Pinned on ICSP of LCD Keypad
pinMode(13, OUTPUT); // Pinned on ICSP of LCD Keypad
pinMode(10, OUTPUT); // LCD Keypad Shield BACKlight
digitalWrite(10, state10);
lcd.begin(16, 2); // set up the LCD's number of columns and rows:
setTime(6,22,11,29,06,2013); // setTime(hour,minute,second,day,month,year)
lcd.noCursor();
showtime(); // show time
delay(10);
keypressed(); // show value for keys
delay(10);
if (LastSecond!=second()) {
// MoistureTest();
LastSecond=second();
digitalWrite(13, state13);
if(state13==LOW) { state13=HIGH; }else{state13=LOW;}
void keypressed(){
analogRead(A0);
int value = analogRead(A0)/12;
if(value<70){keyvalue=60;}else{keyvalue=80; return;}
if(value<50)keyvalue=39;
if(value<31)keyvalue=25;
if(value<16)keyvalue=10;
if(value<5)keyvalue=0;
lcd.setCursor(15,1); // set cusor position to row 1, col 1
//lcd.print(keyvalue); // value on A0
if(keyvalue==85) return;
if(keyvalue==10) {
lcd.print("^");
if(keyvalue==25) {
lcd.print("V");
if(keyvalue==39) {
lcd.print("<");
barChar--;
if(keyvalue==0) {
lcd.print(">");
barChar++;
if(keyvalue==60) {
lcd.print("*");
if(state10==LOW) { state10=HIGH; }else{state10=LOW;}
delay(400);
if(keyvalue==25) { adjustTime(-62); delay(100);}
if(keyvalue==10) { adjustTime(1); delay(100);}
showtime();
delay(90);
lcd.setCursor(7, 0); lcd.print(barChar);lcd.print(" ");lcd.print(char(barChar));
delay(90);
void showtime(){
// lcd.setCursor(0, 0); lcd.print(now());
lcd.setCursor(0, 1);
if (hour()<10) lcd.print("0");
lcd.print(hour());
lcd.print(":");
if (minute()<10) lcd.print("0");
lcd.print(minute());
lcd.print(".");
if (second()<10) lcd.print("0");
lcd.cursor();
lcd.print(second()); lcd.print(" ");
lcd.setCursor(7, 1);
delay(50);
