try this code
// canbus transmit TVL data
#include <mcp_can.h>
#include <SPI.h>
MCP_CAN CAN0(10);//9); // Set CS pin <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
// convert TVL ASCII string to byte array
// e.g. "0A04060708090B03010203"
// return length for data read OK 0 for fail
int TVLtoBytes(byte *d) {
char data[20] = {0};
while (!Serial.available()) ; // wait
// get tag and length
Serial.readBytesUntil('\n', data, 4);
Serial.print("\n\ndata read = "); Serial.println(data);
int tag = 0, length = 0;
if (sscanf(data, "%02x%02x", &tag, &length) != 2)return 0;
d[0] = tag;
d[1] = length;
// read values
for (int i = 0; i < length; i++) {
Serial.readBytesUntil('\n', data, 2);
Serial.print("data read = "); Serial.println(data);
int value = 0;
sscanf(data, "%02x", &value);
d[2 + i] = value;
return d[1];
// Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
while (CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) != CAN_OK) // for Canbus shield V1
//while(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) != CAN_OK) // for Can MCP2515 board
Serial.println("MCP2515 not initialized!");
Serial.println("Initialized MCP2515");
CAN0.setMode(MCP_NORMAL); // Change to normal mode to allow messages to be transmitted
byte d[11] = {0};
int l = TVLtoBytes(d);
if (l <= 0) return;
Serial.print("data length = ");
Serial.println(l);
Serial.print(" byte data to transmit over canbus ");
for (int i = 0; i < l + 2; i++)
Serial.print(" ");
Serial.print(d[i], HEX);
// send data: ID = 0x100, Standard CAN Frame, Data length = 8 bytes, 'data' = array of data bytes to send
byte sndStat = CAN0.sendMsgBuf(d[0], 0, d[1], &d[2]);
if (sndStat == CAN_OK) Serial.println("Message Sent Successfully!");
else Serial.println("Error Sending Message...");
when run on a Mega using Canbus shield V1
Entering Configuration Mode Successful!
Setting Baudrate Successful!
Initialized MCP2515
data read = 0A04
data read = 06
data read = 07
data read = 08
data read = 09
data length = 4
byte data to transmit over canbus A 4 6 7 8 9Message Sent Successfully!
data read = 0B03
data read = 01
data read = 02
data read = 03
data length = 3
byte data to transmit over canbus B 3 1 2 3Message Sent Successfully!
receiver code
// CAN Receive Example
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
char msgString[128]; // Array to store serial string
#define CAN0_INT 2 // Set INT to pin 2
MCP_CAN CAN0(10); // Set CS to pin 10
// while(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) != CAN_OK) // for Canbus shield V1
Serial.println("MCP2515 Initialized Successfully!");
CAN0.setMode(MCP_NORMAL); // Set operation mode to normal so the MCP2515 sends acks to received data.
pinMode(CAN0_INT, INPUT); // Configuring pin for /INT input
Serial.println("MCP2515 Library Receive Example...");
if(!digitalRead(CAN0_INT)) // If CAN0_INT pin is low, read receive buffer
CAN0.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
if((rxId & 0x80000000) == 0x80000000) // Determine if ID is standard (11 bits) or extended (29 bits)
sprintf(msgString, "Extended ID: 0x%.8lX DLC: %1d Data:", (rxId & 0x1FFFFFFF), len);
sprintf(msgString, "Standard ID: 0x%.3lX DLC: %1d Data:", rxId, len);
Serial.print(msgString);
if((rxId & 0x40000000) == 0x40000000){ // Determine if message is a remote request frame.
sprintf(msgString, " REMOTE REQUEST FRAME");
for(byte i = 0; i<len; i++){
sprintf(msgString, " 0x%.2X", rxBuf[i]);
when run on a UNO with a Can MCP2515 board
Initialized MCP2515
Standard ID: 0x00A DLC: 4 Data: 0x06 0x07 0x08 0x09
Standard ID: 0x00B DLC: 3 Data: 0x01 0x02 0x03
