Code to run pulse sensor on Adafruit Flora
I have a Pulse Sensor Amped from pulsesensor.com and an Adafruit Flora board.
Adafruit Flora is based on ATmega32u4.
I followed the instructions from here to setup the pulse sensor.
However, the sensor outputs results without even touching it.
It show various values at a 1-2 seconds interval, usually between 130-180 BPM.
I don’t know what I’m doing wrong, or what should I do to fix it.
The code is available on GitHub.
These are the code lines which are meaningful to me:
Interrupt setup:
void interruptSetup(){
  TCCR1A = 0x00;
  TCCR1B = 0x0C;
  OCR1A = 0x7C;
  TIMSK1 = 0x02;
  sei();
Option to use Timer1:
ISR(TIMER1_COMPA_vect)
Important: Flora pinout schema, because digital pins are associated with analog pins too.
PulseSensorAmped_Arduino_1dot4 code:
Set pulse pin (D12 on Flora is A11):
int pulsePin = 11;
Setting for pulse sensor to work on 3.3v:
analogReference(EXTERNAL);
Any ideas?
