Code to send Stepper to a home position.
Hi
I have a Arduino UNO microcontroller with a Adafruit shield connected to a stepper motor.
I want to be able to Home to a sensor switch and then step to different locations from the home position.
Can anyone share some code to get me started? I want to push a button and have the stepper rotate backwards or fordwards until
it contacts a sensor switch and set this as the home position. I would then use other buttons to step to diferent positions.
Thanks Rmac
I have done the examples you suggested and have a sketch started. What I am looking for if a sample code for sending a stepper to a home position. If anyone has done one and is willing to share it would help.
Rmac
Show me yours and I wil show you mine ... :slight_smile:
Seriously, show us your code.
The logic is simple
S.SetSpeed(somethingslow) ;
S.step(3) ; // move forward a little in case we already ar at home.
while (digitalRead(pinwithswitch)==HIGH)   S.step(-1) ;
 // Stepper at home position
This will step one step and after each step check if the home-switch is depressed (it goes LOW). Then it will exit the loop (and the stepper is standing still)
