I have built an inclinometer using a 3-axis accelerometer. I need to "zero out" the degrees using a push button.
For example, if I have the inclinometer sitting on a 10 degree slant, I want to be able to press a push button and have the serial output register the degrees as zero instead of 10 degrees. Then, as I rotate the inclinometer, the degrees will register based off of the new zero baseline.
I think I need to be able to store the current degrees value when the push button is pressed and then use that stored value in the calculation I use to determine degrees.
For example, here is my calculation to calculate degrees:
double x_Buff = float(mySensor.readAccelerometer(X_AXIS));
double y_Buff = float(mySensor.readAccelerometer(Y_AXIS));
double z_Buff = float(mySensor.readAccelerometer(Z_AXIS));
int z = (atan2((- x_Buff) , sqrt(y_Buff * y_Buff + z_Buff * z_Buff)) * 57.3);
I think i want to introduce a variable, say "y", that will be set to the current degrees when the push button is pressed and then I can use the "y" variable in a new calculation such as:
x = (y - (atan2((- x_Buff) , sqrt(y_Buff * y_Buff + z_Buff * z_Buff)) * 57.3))
I am having troubles resetting my "y" variable every time I press the button on the push button. Can someone help? Is there a better way to do this?
Here is my code:
#include "NineAxesMotion.h" //Contains the bridge code between the API and the Arduino Environment
#include <Wire.h> //Communicate with I2C / TWI devices
NineAxesMotion mySensor; //Object that for the sensor
bool updateSensorData = true; //Flag to update the sensor data. Default is true to perform the first read before the first stream
int ledPinR1 = 5; // left red led
int ledPinY1 = 6; // left yellow led
int ledPinG1 = 8; // green led
int ledPinY2 = 9; // right yellow led
int ledPinR2 = 10; // right red led
int buttonApin = 11; // set zero button
void setup() //This code is executed once
pinMode(ledPinR1, OUTPUT);
pinMode(ledPinY1, OUTPUT);
pinMode(ledPinG1, OUTPUT);
pinMode(ledPinY2, OUTPUT);
pinMode(ledPinR2, OUTPUT);
pinMode(buttonApin, INPUT_PULLUP);
//Peripheral Initialization
Serial.begin(115200); //Initialize the Serial Port to view information on the Serial Monitor
I2C.begin(); //Initialize I2C communication to the let the library communicate with the sensor.
//Sensor Initialization
mySensor.initSensor(); //The I2C Address can be changed here inside this function in the library
mySensor.setOperationMode(OPERATION_MODE_NDOF); //Can be configured to other operation modes as desired
mySensor.setUpdateMode(MANUAL); //The default is AUTO. Changing to manual requires calling the relevant update functions prior to calling the read functions
//Setting to MANUAL requires lesser reads to the sensor
mySensor.updateAccelConfig();
Serial.println("Default accelerometer configuration settings...");
Serial.print("Range: ");
Serial.println(mySensor.readAccelRange());
Serial.print("Bandwidth: ");
Serial.println(mySensor.readAccelBandwidth());
Serial.print("Power Mode: ");
Serial.println(mySensor.readAccelPowerMode());
Serial.println("Streaming in ..."); //Countdown
Serial.print("3...");
delay(1000); //Wait for a second
Serial.print("2...");
Serial.println("1...");
void loop() //This code is looped forever
delay(50);
//Calcuate degrees of angle
int y = 0;
int x = (atan2((- x_Buff) , sqrt(y_Buff * y_Buff + z_Buff * z_Buff)) * 57.3);
if (digitalRead(buttonApin) == LOW)
//I need to code to set zero out current angle
int x = (y - (atan2((- x_Buff) , sqrt(y_Buff * y_Buff + z_Buff * z_Buff)) * 57.3));
if (updateSensorData) //Keep the updating of data as a separate task
mySensor.updateAccel(); //Update the Accelerometer data
mySensor.updateLinearAccel(); //Update the Linear Acceleration data
mySensor.updateGravAccel(); //Update the Gravity Acceleration data
mySensor.updateCalibStatus(); //Update the Calibration Status
updateSensorData = false;
Serial.print(" Pitch: ");
Serial.print(x);
Serial.print(" degrees ");
Serial.print(y);
if ((x >= -5) && (x <= 5)) //Light green LED if angle is within specified degrees
digitalWrite(ledPinR1, LOW);
digitalWrite(ledPinY1, LOW);
digitalWrite(ledPinG1, HIGH);
digitalWrite(ledPinY2, LOW);
digitalWrite(ledPinR2, LOW);
else if ((x >= 6) && (x <= 25)) //Light yellow LED if angle is within specified degrees
digitalWrite(ledPinG1, LOW);
digitalWrite(ledPinY2, HIGH);
else if ((x >= 26) && (x <= 90)) //Light red LED if angle is within specified degrees
digitalWrite(ledPinR2, HIGH);
else if ((x >= -25) && (x <= -6)) //Light yellow LED if angle is within specified degrees
digitalWrite(ledPinY1, HIGH);
else if ((x >= -90) && (x <= -26)) //Light red LED if angle is within specified degrees
digitalWrite(ledPinR1, HIGH);
else //if error
