Code uploading for forever
Sketch uses 2274 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 184 bytes (8%) of dynamic memory, leaving 1864 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\SUBHANKAR\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\SUBHANKAR\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM5" -b115200 -D "-Uflash:w:C:\Users\SUBHANKAR\AppData\Local\arduino\sketches\B7702AEAF940F69AF8F9C2F323482DE1/square.wave.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\SUBHANKAR\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd0
avrdude done.  Thank you.
Failed uploading: uploading error: exit status 1
After compiling when it starts the uploading it takes a long long time and then throw this message.. plz fix this issue
Your question was answered a multiple times on the forum, please use the search button
Which board?
Clone or original?
What is the serial-to-usb converter on the board?
Please provide a link if you bought it on the web.
What is the history of the board? Did it ever work?
Which version of the IDE?
