Hello, my name is Nick and about 2 years ago build a button box. Recently I needed an Arduino for physics class and my second one didn't work, so I stole the Arduino I had been using in my button box and re codded it. Ever since then when taking the original button box code unmodified, it won't recompile and be saved onto the board I was using previously. Any ideas on why it won't compile anymore?
#include <Keypad.h>
#include <Joystick.h>
//DEFINITIONS
#define ENABLE_PULLUPS
#define NUMROTARIES 0 //replace "?" with number of rotary encoders you are using
#define NUMBUTTONS 32 //replace "?"with number of buttong you are using
#define NUMROWS 6 //replace "?" with number of rows you have
#define NUMCOLS 6 //replace "?" with number of columns you have
//BUTTON MATRIX
//first change number of rows and columns to match your button matrix,
//then replace all "?" with numbers (starting from 0)
byte buttons[NUMROWS][NUMCOLS] = {
{0,1,2,3,4,5},
{6,7,8,9,10,11},
{12,13,14,15,16,17},
{18,19,20,21,22,23},
{24,25,26,27,28,29},
{30,31,32,33,34,35}
struct rotariesdef {
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
volatile unsigned char state;
//ROTARY ENCODERS
//each line controls a different rotary encoder
//the first two numbers refer to the pins the encoder is connected to
//the second two are the buttons each click of the encoder wil press
//do NOT exceed 31 for the final button number
rotariesdef rotaries[NUMROTARIES] {
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
// R_START (00)
{R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CCW_BEGIN
{R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
// R_CW_BEGIN
{R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
// R_START_M (11)
{R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
// R_CW_BEGIN_M
{R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
// R_CCW_BEGIN_M
{R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
// R_START
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
//BUTTON MATRIX PART 2
byte rowPins[NUMROWS] = {A5,A4,A3,A2,A1,A0}; //change "?" to the pins the rows of your button matrix are connected to
byte colPins[NUMCOLS] = {8,9,10,11,12,13}; //change "?" to the pins the rows of your button matrix are connected to
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
//JOYSTICK SETTINGS
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK,
32, //number of buttons
0, //number of hat switches
//Set as many axis to "true" as you have potentiometers for
false, // y axis
false, // x axis
false, // z axis
false, // rx axis
false, // ry axis
false, // rz axis
false, // rudder
false, // throttle
false, // accelerator
false, // brake
false); // steering wheel
const int numReadings = 20;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int currentOutputLevel = 0;
//POTENTIOMETERS PART 1
//add all the axis' which are enabled above
int zAxis_ = 0;
int RxAxis_ = 0;
//POTENTIOMETERS PART 2
//Which pins are your potentiometers connected to?
int potentiometerPin1 = 0; //Change "?" to the pin your potentiometer is connected to
int potentiometerPin2 = 0;
const bool initAutoSendState = true;
Joystick.begin();
rotary_init();
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
CheckAllEncoders();
CheckAllButtons();
CheckAllPotentiometers();
//POTENTIOMETERS PART 3
//change the details to match teh details above for each potentiometer you are using
void CheckAllPotentiometers(){
//potentiometer 1
currentOutputLevel = getAverageOutput(potentiometerPin1);
zAxis_ = map(currentOutputLevel,0,1023,0,255);
Joystick.setZAxis(zAxis_);
//potentiometer 2
currentOutputLevel = getAverageOutput(potentiometerPin2);
RxAxis_ = map(currentOutputLevel,0,1023,0,255);
Joystick.setRxAxis(RxAxis_);
int getAverageOutput(int pinToRead){
index = 0;
total = 0;
while (index < numReadings){
readings[index] = analogRead(pinToRead);
total = total + readings[index];
index = index + 1;
//delay (1);
return total / numReadings;
void CheckAllButtons(void) {
if (buttbx.getKeys())
for (int i=0; i<LIST_MAX; i++)
if ( buttbx.key[i].stateChanged )
switch (buttbx.key[i].kstate) {
case PRESSED:
case HOLD:
Joystick.setButton(buttbx.key[i].kchar, 1);
case RELEASED:
case IDLE:
Joystick.setButton(buttbx.key[i].kchar, 0);
void rotary_init() {
for (int i=0;i<NUMROTARIES;i++) {
pinMode(rotaries[i].pin1, INPUT);
pinMode(rotaries[i].pin2, INPUT);
#ifdef ENABLE_PULLUPS
digitalWrite(rotaries[i].pin1, HIGH);
digitalWrite(rotaries[i].pin2, HIGH);
#endif
unsigned char rotary_process(int _i) {
//Serial.print("Processing rotary: ");
//Serial.println(_i);
unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
Serial.println("Checking rotaries");
unsigned char result = rotary_process(i);
if (result == DIR_CCW) {
Serial.print("Rotary ");
Serial.print(i);
Serial.println(" <<< Going CCW");
Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
if (result == DIR_CW) {
Serial.print(i);
Serial.println(" >>> Going CW");
Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
Serial.println("Done checking");
These are the initial errors I get.
/usr/local/bin/arduino-cli compile --fqbn arduino:avr:leonardoeth --build-cache-path /tmp --output-dir /tmp/1594083658/build --build-path /tmp/arduino-build-D7C569E98392A802056C2AF4F8B58814 /tmp/1594083658/Large_Button_Box_-_Code_File
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-Code_File.ino:101:1: error: 'Joystick' does not name a type; did you mean 'Joystick'?
Joystick
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino: In function 'void setup()':
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino:139:11: error: expected unqualified-id before '.' token
Joystick.begin();
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino: In function 'void CheckAllPotentiometers()':
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino:161:11: error: expected unqualified-id before '.' token
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino:166:11: error: expected unqualified-id before '.' token
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino: In function 'void CheckAllButtons()':
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino:195:39: error: expected unqualified-id before '.' token
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino:199:39: error: expected unqualified-id before '.' token
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino: In function 'void CheckAllEncoders()':
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino:236:15: error: expected unqualified-id before '.' token
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino:236:70: error: expected unqualified-id before '.' token
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino:242:15: error: expected unqualified-id before '.' token
/tmp/1594083658/Large_Button_Box_-Code_File/Large_Button_Box-_Code_File.ino:242:69: error: expected unqualified-id before '.' token
Multiple libraries were found for "Joystick.h"
Used: /home/builder/opt/libraries/joystick_1_0_0
Not used: /home/builder/opt/libraries/joystick_module_1_0_0
Not used: /home/builder/opt/libraries/bluevga_library_for_bluepill_0_1_3
Not used: /home/builder/opt/libraries/axisjoystick_2_2_3
Multiple libraries were found for "Keypad.h"
Used: /home/builder/opt/libraries/keypad_3_1_1
Not used: /home/builder/opt/libraries/acemenu_0_1_3
Error during build: exit status 1
Blockquote
Is it just not able to find the libraries needed?
