Hello,
I'm having some difficulties with the uploading code to a ESP8266 from the Arduino IDE. It seems to recognise the board without issue but does not do anything after printing "Leaving... Hard resetting via RTS pin...". I cannot find a solution to this online but some suggest it could be a problem with the memory. I'm running a very simple program to test the ESP8266, seen below. Also I'm not sure if this has any significance but when I plugged in this ESP8266 for the first time the blue LED would stay on while powered but once I tried to upload a code the LED stays off unless it's compiling code before attempting to upload it. The board I have selected in Arduino is the NodeMCU 1.0 (ESP-12E Module). below is also the output, any help would be much appreciated. I would just like to know if there is something wrong with the board and if I should replace it?
. Variables and constants in RAM (global, static), used 28188 / 80192 bytes (35%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1496 initialized variables
╠══ RODATA 932 constants
╚══ BSS 25760 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 60347 / 65536 bytes (92%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 27579 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 241572 / 1048576 bytes (23%)
╚══ IROM 241572 code in flash
esptool.py v3.0
Serial port COM4
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 58:bf:25:d9:b4:03
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 275728 bytes to 202296...
Writing at 0x00000000... (7 %)
Writing at 0x00004000... (15 %)
Writing at 0x00008000... (23 %)
Writing at 0x0000c000... (30 %)
Writing at 0x00010000... (38 %)
Writing at 0x00014000... (46 %)
Writing at 0x00018000... (53 %)
Writing at 0x0001c000... (61 %)
Writing at 0x00020000... (69 %)
Writing at 0x00024000... (76 %)
Writing at 0x00028000... (84 %)
Writing at 0x0002c000... (92 %)
Writing at 0x00030000... (100 %)
Wrote 275728 bytes (202296 compressed) at 0x00000000 in 17.8 seconds (effective 123.8 kbit/s)...
Hash of data verified.
Leaving...
// Define the GPIO pin for the LED
const int ledPin = D2;
// Start Serial communication
// Set the LED pin as an output
pinMode(ledPin, OUTPUT);
// Blink the LED
digitalWrite(ledPin, HIGH); // Turn the LED on
delay(1000); // Wait for 1 second
digitalWrite(ledPin, LOW); // Turn the LED off
printf("done");
