code with 2 buttons and 2 leds help please :)
hi, i need help with this code, i have problems at compile!!
this code is for switching direction for massage chair motor using 2 relays
i want when i press the first button to enable relay1 one for 30sec after delay 1sec and enable relay 2 for 30sec delay 1sec again and continue looping this until i press the button2
when i press button 2 i want to enable relay 1 for 30sec and after one loop i want everything stopped until i press again the button1 to start the first loop
thanks everyone for your time!!
:slight_smile:
#include <Button.h>
Button Button1 = Button1(10, INPUT_PULLUP);
Button Button2 = Button2(11, INPUT_PULLUP);
void setup(){
 pinMode (10, INPUT);
 pinMode (11, INPUT);
 pinMode (5, OUTPUT);
 pinMode (6, OUTPUT);
void loop(){
 if (Button1.isPressed()){
  digitalWrite(5, HIGH);
   delay(30000);
   digitalWrite(5, LOW);
   digitalWrite(6, HIGH);
   delay(30000);
   digitalWrite(6, LOW);
 else if (Button2.isPressed()) {
   delay(3000);
Post the complete error message here
Is that the correct syntax for creating instances of Button ?
Button Button1(10, INPUT_PULLUP);
Button Button2(11, INPUT_PULLUP);
Seems more likely
the errors i have after change this
with this
errors:
sketch_mar18a:3: error: no matching function for call to 'Button::Button(int, int)'
C:\Users\Bilakoss\Documents\Arduino\sketch_mar18a\sketch_mar18a.ino:3:32: note: candidates are:
In file included from C:\Users\Bilakoss\Documents\Arduino\sketch_mar18a\sketch_mar18a.ino:1:0:
C:\Users\Bilakoss\Documents\Arduino\libraries\Button/Button.h:14:3: note: Button::Button(uint8_t)
Button(uint8_t pin);
C:\Users\Bilakoss\Documents\Arduino\libraries\Button/Button.h:14:3: note: candidate expects 1 argument, 2 provided
C:\Users\Bilakoss\Documents\Arduino\libraries\Button/Button.h:11:7: note: constexpr Button::Button(const Button&)
class Button
C:\Users\Bilakoss\Documents\Arduino\libraries\Button/Button.h:11:7: note: candidate expects 1 argument, 2 provided
C:\Users\Bilakoss\Documents\Arduino\libraries\Button/Button.h:11:7: note: constexpr Button::Button(Button&&)
sketch_mar18a:4: error: no matching function for call to 'Button::Button(int, int)'
C:\Users\Bilakoss\Documents\Arduino\sketch_mar18a\sketch_mar18a.ino:4:32: note: candidates are:
class Button
C:\Users\Bilakoss\Documents\Arduino\sketch_mar18a\sketch_mar18a.ino: In function 'void loop()':
sketch_mar18a:15: error: 'class Button' has no member named 'isPressed'
sketch_mar18a:25: error: 'class Button' has no member named 'isPressed'
exit status 1 no matching function for call to 'Button::Button(int, int)'
Which button library are you using ?
this is my library!!!
Button.zip (4.97 KB)
In the library example the button objects are created like this
Button button1(2); // Connect your button between pin 2 and GND
Button button2(3); // Connect your button between pin 3 and GND
Button button3(4); // Connect your button between pin 4 and GND
The function in the library that creates the button objects takes one paramater, the pin number
but you have used a different syntax
Change your code to match that of the library
