Code won't go past the setup and I can't find what's wrong
I've tried everything from re writing the code to trying to somehow replace the whole "if" function and it didn't work. Can anyone take a look at it?
Thanks in advance
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
const int tipkalo = A0;
const int tipkalo2 = A1;
const int switcc1 = A2;
const int switcc2 = A3;
const int switcc3 = A4;
const int switcc4 = A5;
const int IR_sensor = A6;
const int IR_led_transistor = 2;
const int C_LED = 3;
const int P_LED = 4;
const int kv = 5;
const int mosfet = 6;
int w_rpm = 0;
float hall_thresh = 7.0;
void setup(){
  lcd.begin(16, 2);
  lcd.print("2step system by");
  lcd.setCursor(0, 1);
  lcd.print("AnteLo");
  pinMode(tipkalo, INPUT);
  pinMode(C_LED, OUTPUT);
  pinMode(P_LED, OUTPUT);
  pinMode(IR_led_transistor, OUTPUT);
  pinMode(mosfet, OUTPUT);
  pinMode(kv, INPUT);
  pinMode(IR_sensor, INPUT);
  digitalWrite(C_LED, LOW);
  digitalWrite(P_LED, LOW);
  digitalWrite(mosfet, HIGH);
  delay(1500);
  digitalWrite(IR_led_transistor, HIGH);
  float hall_count = 1;
  float start = micros();
  bool on_state = false;
  while(true){
    if (digitalRead(IR_sensor)==0){
      if (on_state==false){
        on_state = true;
        hall_count+=1.0;
    } else{
      on_state = false;
    if (hall_count>=hall_thresh){
 float end_time = micros();
 float time_passed = ((end_time-start)/1000000.0);
 float rpm_val = (hall_count/time_passed)*6;
 delay(1);
 if (digitalRead(switcc1) == HIGH && rpm_val >= 1600){
   w_rpm = w_rpm + 1500;
 if (digitalRead(switcc2) == HIGH && rpm_val >= 1600){
   w_rpm = w_rpm + 500;
 if (digitalRead(switcc3) == HIGH && rpm_val >= 1600){
 if (digitalRead(switcc4) == HIGH && rpm_val >= 1600){
   w_rpm = w_rpm + 250;
 if (digitalRead(tipkalo) == HIGH && w_rpm == 0){
   lcd.print("no jumpers set");
 if (digitalRead(tipkalo) == HIGH && rpm_val >= w_rpm){
    lcd.begin(16, 2);
    lcd.print("2step active");
    lcd.setCursor(0,1);
    lcd.print(w_rpm);
    lcd.print("rpm");
    digitalWrite(mosfet, LOW);
 if (digitalRead(tipkalo2) == HIGH && w_rpm >= 1400) {
    lcd.begin(16, 2);
    lcd.setCursor(0,1);
    lcd.print(w_rpm);
    lcd.print("rpm");
 if (digitalRead(kv) == HIGH && w_rpm >= 4200){
    lcd.setCursor(3, 1);
    lcd.print("FLAT SHIFT");
 else {
     delay(100);
     lcd.begin(16, 2);
     lcd.print("2step deactive");
_2step_v1.1_final.ino (2.5 KB)
think your problem is at this line in your 'loop' routine:
while(true)
should it not be this instead?
while(on_state==true)
hope that helps...
put a Serial.println("sth"); after each line. Then you will know what the program is doing
sherzaad:
while(true)
hope that helps...
Yes, that did help a lot, thank you so much!
leoncoolmoon:
I did that yesterday and it just didn't get past the setup, thanks guys
leoncoolmoon:
...but remember that serial I/O is buffered.
micros() returns "unsigned long" which can go up over 4,000,000,000. Float can do 6 to 7 significant digits. Once you get up near 10,000,000 microseconds (10 seconds) your timing is going to get strange as your integer values get rounded off. You should always use "unsigned long" or "uint32_t" for millis() and micros() values.
