Hello
I'm using AT commands to get information about RSSI between XBee connected to USB adapter and XBee connected to Arduino (coordinator). In this case everything seems to work fine, but when instead of a USB adapter i want to use XBee connected to another Arduino the same code doesn't work, as if it couldn't go back again into the AT command mode ![]()
I'm using Digi XBee series 2 (XB24-Z7WIT-004) and Arduino Leonardo.
Plus I tested if they are communicating with terminal and they do, so everything is good with the configuration part.
Thank you in advance for any clues. ![]()
My code:
String adres1 = "ATDL40B1848D\r"; // connected to arduino
//String adres2 = "ATDL40B18453\r";
String adres3 = "ATDL40A235ED\r"; // connected to usb port
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Start");
Serial1.begin(9600);
SendStartCommand();
SendAddressCommand(adres3);
SendExitCommand();
Serial1.write("msg"); //sending msg for having different RSSI value in each iteration
SendStartCommand();
SendRSSICommand();
//delay(1000);
void SendStartCommand() {
String bufor0 = "+++";
Serial1.print(bufor0);
while (Serial1.available() == 0) {
Serial.print("");
delay(300);
//response for the +++ command
int bufor = 0;
Serial.print("+++ ");
while (Serial1.available() > 0) {
bufor = Serial1.read();
Serial.write(bufor);
void SendAddressCommand(String Adres) {
Serial1.print(Adres);
Serial.print("");
delay(300);
//response for the atdl address command
int bufor = 0;
Serial.print("Zmiana adresu ");
void SendExitCommand() {
String bufor0 = "ATCN\r";
Serial.print("");
delay(300);
int bufor = 0;
Serial.print("exit ");
void SendRSSICommand() {
String bufor0 = "ATDB\r";
Serial.print("");
delay(300);
int bufor = 0;
Serial.print("RSSI: ");
