Sorry! Is this what you meant?
Based on Sketch built by Gustavo Silveira (aka Music Nerd)
Modified by Dolce Wang
This code is only for Arduinos that use ATmega32u4 (like Micro, Pro Micro, Leonardo...)
Remember to also assign the correct board in the IDE (like Tools / Boards / Sparkfun AVR / Pro Micro...)
// Change any fields with //**
// LIBRARY
#include "MIDIUSB.h"
/* BUTTONS
const int NButtons = 1; //*** total number of buttons
const int buttonPin[NButtons] = {2, 3, 5, 7}; //*** define Digital Pins connected from Buttons to Arduino; (ie {10, 16, 14, 15, 6, 7, 8, 9, 2, 3, 4, 5}; 12 buttons)
int buttonCState[NButtons] = {}; // stores the button current value
int buttonPState[NButtons] = {}; // stores the button previous value
// debounce
unsigned long lastDebounceTime[NButtons] = {0}; // the last time the output pin was toggled
unsigned long debounceDelay = 50; //** the debounce time; increase if the output flickers
// POTENTIOMETERS
const int NPots = 1; //*** total number of pots (knobs and faders)
const int potPin[NPots] = {A1}; //*** define Analog Pins connected from Pots to Arduino; Leave nothing in the array if 0 pots {}
int potCState[NPots] = {0}; // Current state of the pot; delete 0 if 0 pots
int potPState[NPots] = {0}; // Previous state of the pot; delete 0 if 0 pots
int potVar = 0; // Difference between the current and previous state of the pot
int midiCState[NPots] = {0}; // Current state of the midi value; delete 0 if 0 pots
int midiPState[NPots] = {0}; // Previous state of the midi value; delete 0 if 0 pots
const int TIMEOUT = 300; //* Amount of time the potentiometer will be read after it exceeds the varThreshold
const int varThreshold = 10; //* Threshold for the potentiometer signal variation
boolean potMoving = true; // If the potentiometer is moving
unsigned long PTime[NPots] = {0}; // Previously stored time; delete 0 if 0 pots
unsigned long timer[NPots] = {0}; // Stores the time that has elapsed since the timer was reset; delete 0 if 0 pots
// MIDI Assignments
byte midiCh = 1; //* MIDI channel to be used
byte note = 36; //* Lowest note to be used; 36 = C2; 60 = Middle C
byte cc = 1; //* Lowest MIDI CC to be used
// SETUP
// Baud Rate
// 31250 for MIDI class compliant | 115200 for Hairless MIDI
// Buttons
// Initialize buttons with pull up resistors
for (int i = 0; i < NButtons; i++) {
pinMode(buttonPin[i], INPUT_PULLUP);
// LOOP
// buttons();
potentiometers();
// BUTTONS
void buttons() {
buttonCState[i] = digitalRead(buttonPin[i]); // read pins from arduino
if ((millis() - lastDebounceTime[i]) > debounceDelay) {
if (buttonPState[i] != buttonCState[i]) {
lastDebounceTime[i] = millis();
if (buttonCState[i] == LOW) {
// Sends the MIDI note ON
// use if using with ATmega32U4 (micro, pro micro, leonardo...)
noteOn(midiCh, note + i, 127); // channel, note, velocity
MidiUSB.flush();
else {
// Sends the MIDI note OFF accordingly to the chosen board
noteOn(midiCh, note + i, 0); // channel, note, velocity
MidiUSB.flush();
buttonPState[i] = buttonCState[i];
// POTENTIOMETERS
void potentiometers() {
for (int i = 0; i < NPots; i++) { // Loops through all the potentiometers
potCState[i] = analogRead(potPin[i]); // reads the pins from arduino
midiCState[i] = map(potCState[i], 0, 1023, 0, 127); // Maps the reading of the potCState to a value usable in midi
potVar = abs(potCState[i] - potPState[i]); // Calculates the absolute value between the difference between the current and previous state of the pot
if (potVar > varThreshold) { // Opens the gate if the potentiometer variation is greater than the threshold
PTime[i] = millis(); // Stores the previous time
timer[i] = millis() - PTime[i]; // Resets the timer 11000 - 11000 = 0ms
if (timer[i] < TIMEOUT) { // If the timer is less than the maximum allowed time it means that the potentiometer is still moving
potMoving = true;
else {
potMoving = false;
if (potMoving == true) { // If the potentiometer is still moving, send the change control
if (midiPState[i] != midiCState[i]) {
// Sends MIDI CC
// Use if using with ATmega32U4 (micro, pro micro, leonardo...)
controlChange(midiCh, cc + i, midiCState[i]); // (channel, CC number, CC value)
MidiUSB.flush();
potPState[i] = potCState[i]; // Stores the current reading of the potentiometer to compare with the next
midiPState[i] = midiCState[i];
// if using with ATmega32U4 (micro, pro micro, leonardo...)
// Arduino MIDI functions MIDIUSB Library
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
void controlChange(byte channel, byte control, byte value) {
midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
MidiUSB.sendMIDI(event);
and the main .ino
// Copyright Louie "Wake The Tiger" 2023
// with edits by Will Hitchings
// Sketch for a Midi Pedal to control FX in a PC
// 8 SWITCHES
// 8 LED's
// 1 POTENTIOMETER
// = = = CHECK 'boards.txt' ! ! !
// MIDI Notes to Control LEDs
#define LED1_NOTE 41 //
#define LED2_NOTE 42 //
#define LED3_NOTE 43 //
#define LED4_NOTE 44 //
#define LED5_NOTE 45 //
#define LED6_NOTE 46 //
#define LED7_NOTE 47 //
#define LED8_NOTE 48 //
// Buttons/Switches to MIDI Notes
#define BTN1_NOTE 51 //
#define BTN2_NOTE 52 //
#define BTN3_NOTE 53 //
#define BTN4_NOTE 54 //
#define BTN5_NOTE 55 //
#define BTN6_NOTE 56 //
#define BTN7_NOTE 57 //
#define BTN8_NOTE 58 //
const int ButtonPins[8] = {1,2,3,4,5,6,7,8}; //
const int LEDPins[8] = {9,10,11,12,17,14,15,16}; //
const int PotPins[1] = {A1};
#define deviceChannel 0 // This is the MIDI channel number 0-15
#define buttonDebounceTime 150 // Debounce time for each button in milliseconds (prevents multiple triggers due to chatter)
// POTS VERSION 2
// const int NPots = 1; //*** total number of pots (knobs and faders)
const int PotPins[NPots] = {A1}; //*** define Analog Pins connected from Pots to Arduino; Leave nothing in the array if 0 pots {}
int potentiometers;
// MIDI Assignments
bool InternalLED_state = LOW;
bool buttonState[8] = {0,0,0,0,0,0,0,0};
unsigned long buttonToggleTime[8] = {0,0,0,0,0,0,0,0};
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, InternalLED_state); // Turn LED On
for (int i=0; i<8; i++){
pinMode(ButtonPins[i], INPUT_PULLUP);// For All buttons
pinMode(LEDPins[i], OUTPUT);// For All LED buttons
digitalWrite(LEDPins[i], HIGH); // Turn LED On
delay(100); // Do this one-by-one
delay(300); // Wait
digitalWrite(LEDPins[i], LOW); // Turn LED Off
// POTS VERSION 1
// Serial.println(potValue);
// Serial.println(potState);
// delay(potDelayTime);
// potValue = analogRead(potPin);
// potValue = map(potValue, 0, 1023, 0, 276);
// POTS VERSION 2
potentiometers();
midiEventPacket_t rx;
rx = MidiUSB.read(); // Check for Message
if (rx.header != 0); // If message Received
// printMessage(rx);
// toggleOnBoardLED(); // FOR DEBUGGING - CAN BE REMOVED - WH added ;
// POTS VERSION 1
// for (int i = 0; i < N_POTS; i++);
// POTS VERSION 2
// POTENTIOMETERS
potMoving = true;
else {
potMoving = false;
// Sends MIDI CC
MidiUSB.flush();
} // FOR END
//------------------------- TURN LED's ON
if (rx.byte1 >> 4 == 0x9){ // If it's a note ON message
switch(rx.byte2){ // Check which Note is Played
case LED1_NOTE:
digitalWrite(LEDPins[0], HIGH); // Turn LED On
case LED2_NOTE:
digitalWrite(LEDPins[1], HIGH); // Turn LED On
case LED3_NOTE:
digitalWrite(LEDPins[2], HIGH); // Turn LED On
case LED4_NOTE:
digitalWrite(LEDPins[3], HIGH); // Turn LED On
case LED5_NOTE:
digitalWrite(LEDPins[4], HIGH); // Turn LED On
case LED6_NOTE:
digitalWrite(LEDPins[5], HIGH); // Turn LED On
case LED7_NOTE:
digitalWrite(LEDPins[6], HIGH); // Turn LED On
case LED8_NOTE:
digitalWrite(LEDPins[7], HIGH); // Turn LED On
//------------------------- TURN LED's OFF
if (rx.byte1 >> 4 == 0x8){ // If it's a note OFF message
case LED1_NOTE:
digitalWrite(LEDPins[0], LOW); // Turn LED Off
case LED2_NOTE:
digitalWrite(LEDPins[1], LOW); // Turn LED Off
case LED3_NOTE:
digitalWrite(LEDPins[2], LOW); // Turn LED Off
case LED4_NOTE:
digitalWrite(LEDPins[3], LOW); // Turn LED Off
case LED5_NOTE:
digitalWrite(LEDPins[4], LOW); // Turn LED Off
case LED6_NOTE:
digitalWrite(LEDPins[5], LOW); // Turn LED Off
case LED7_NOTE:
digitalWrite(LEDPins[6], LOW); // Turn LED Off
case LED8_NOTE:
digitalWrite(LEDPins[7], LOW); // Turn LED Off
// END If message Received
// CHECK BUTTONS
for (int i=0; i<8; i++){ // For all Eight buttons
if (millis() < buttonToggleTime[i] + buttonDebounceTime){ // If it was recently changed
continue; // Skip this button. Do next one
if (buttonState[i] == 0){ // If Button is Not Pressed Already
if (digitalRead(ButtonPins[i]) == 0){ // Pin is Low, button is pressed
buttonState[i] = 1; // Mark as pressed
buttonToggleTime[i] = millis(); // Update Event Time
switch(i){ // Pick which Note it is (from button ID)
case 0:
noteOn(deviceChannel, BTN1_NOTE, 127); // Channel, Note, Velocity
case 1:
noteOn(deviceChannel, BTN2_NOTE, 127); // Channel, Note, Velocity
case 2:
noteOn(deviceChannel, BTN3_NOTE, 127); // Channel, Note, Velocity
case 3:
noteOn(deviceChannel, BTN4_NOTE, 127); // Channel, Note, Velocity
case 4:
noteOn(deviceChannel, BTN5_NOTE, 127); // Channel, Note, Velocity
case 5:
noteOn(deviceChannel, BTN6_NOTE, 127); // Channel, Note, Velocity
case 6:
noteOn(deviceChannel, BTN7_NOTE, 127); // Channel, Note, Velocity
case 7:
noteOn(deviceChannel, BTN8_NOTE, 127); // Channel, Note, Velocity
} // End Switch
} // End Button Read
} // End IF (Button Not Already Pressed)
else{ // Button Already Pressed (Button State == 1)
if (digitalRead(ButtonPins[i]) == 1){ // Pin is High, button is released
//toggleOnBoardLED(); // FOR DEBUGGING - CAN BE REMOVED - WH added ;
buttonState[i] = 0; // Mark as released
// MIDI NOTE OFF MESSAGES FOR BUTTONS
case 0:
noteOff(deviceChannel, BTN1_NOTE, 0); // Channel, Note, Velocity
case 1:
noteOff(deviceChannel, BTN2_NOTE, 0); // Channel, Note, Velocity
case 2:
noteOff(deviceChannel, BTN3_NOTE, 0); // Channel, Note, Velocity
case 3:
noteOff(deviceChannel, BTN4_NOTE, 0); // Channel, Note, Velocity
case 4:
noteOff(deviceChannel, BTN5_NOTE, 0); // Channel, Note, Velocity
case 5:
noteOff(deviceChannel, BTN6_NOTE, 0); // Channel, Note, Velocity
case 6:
noteOff(deviceChannel, BTN7_NOTE, 0); // Channel, Note, Velocity
case 7:
noteOff(deviceChannel, BTN8_NOTE, 0); // Channel, Note, Velocity
} // End Switch
}// End Button Read
} // End Else (Button Already Pressed)
}// End IF all eight buttons
} // END LOOP
//void toggleOnBoardLED(void){
// InternalLED_state = !InternalLED_state; // Toggle LED state - DEBUGGING
// digitalWrite(LED_BUILTIN, InternalLED_state); // set internal LED - DEBUGGING
void printMessage (midiEventPacket_t data){ // Not USED - For testing - Won't work with only one USB port (i.e. Micro)
Serial.print("Received: ");
Serial.print(data.header, HEX); //First parameter is the event type (0x09 = note on, 0x08 = note off).combined with the channel.
Serial.print("-");
Serial.print(data.byte1, HEX);
Serial.print("-");
Serial.print(data.byte2, HEX);
Serial.print("-");
Serial.println(data.byte3, HEX);
// First parameter is the event type (0x09 = note on, 0x08 = note off).
// Second parameter is note-on/note-off, combined with the channel.
// Channel can be anything between 0-15. Typically reported to the user as 1-16.
// Third parameter is the note number (48 = middle C).
// Fourth parameter is the velocity (64 = normal, 127 = fastest).
// POTS VERSION 2
MidiUSB.flush();// Send note now
MidiUSB.flush(); // Send note now
Hope this works ok!
