Code works for all but one thing.
I have created a linear word clock and it keeps time very well. All the words light up appropriately except for O’Clock. This is code that I appropriated from a different source and modified it to my own needs. It all worked normally until I added the RTC coding. After that it refused to light up the O’clock. Any insight on this matter would be greatly appreciated.
Code attribution remains in the comments section of the INO.
WordClockV2.ino (6.34 KB)
Code posted properly, with code tags:
  Arduino + Neopixel Word Clock Code
  by: Alex - Super Make Something
  date: August 16, 2015
  license: Public domain.  Please use, reuse, and modify this sketch!
  additional: modified from "simple.ino" NeoPixel example sketch by Shae Erisson of Adafruit Industries.
  NOTE: REQUIRES NEOPIXEL & TIME LIBRARIES TO BE INSTALLED UNDER ...\Arduino\libraries
  NEOPIXEL LIBRARY AVAILABLE AT: https://github.com/adafruit/Adafruit_NeoPixel
  TIME LIBRARY AVAILABLE AT: https://github.com/PaulStoffregen/Time
  Explanation: This code lights up Neopixels corresponding to the current time.
  Time is kept using the time library.
  Neopixels are lit using the Adafruit Neopixel library.
  Depending on the current time, flags to light corresponding Neopixels are saved in an array
  After parsing the time, Neopixels are turned on/off according to the flags using a for loop
#include <TimeLib.h>
#include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
#include <avr/power.h>
#include "Time.h"
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN           3
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS     23
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
// Declare integer array with size corresponding to number of Neopixels in chain
// int individualPixels[NUMPIXELS];
// Time variables
int h;
int m;
int s;
// RGB color variables
int red=255;
int green=255;
int blue=100;
  pixels.begin(); //Begin Neopixel string
  pixels.show();
  Serial.begin(9600); //Begin Serial for debugging purposes
//  Initialize RTC
   //while (!Serial) ; // wait until Arduino Serial Monitor opens
  delay(200);
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
  setSyncInterval(10); // sync the time every 60 seconds (1 minutes)
  if(timeStatus()!= timeSet){
     Serial.println("Unable to sync with the RTC");
     RTC.set(1408278800); // set the RTC to jul 17 2019 9:00 am
     setTime(1408278800);
    else{
     Serial.println("RTC has set the system time");
  //Declare integer array with size corresponding to number of Neopixels in chain
  int individualPixels[NUMPIXELS]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
 rainbow (20)
 void rainbowCycle(uint8_t wait)
  uint16_t i, j;
  for(j = 0; j < 256 * 5; j++) // 5 cycles of all colors on wheel
    for(i = 0; i < strip.numPixels(); i++)
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
  /* Get current time */
  h=hourFormat12();    // Returns the hour of current time between 1-12
  m=minute();        // Returns the minute of current time
  s=second();        // Returns the second of current time (not used, included for completeness)
  Serial.print(h);
  Serial.print(":");
  Serial.print(m);
  Serial.print(":");
  Serial.println(s);
  /* Parse time values to light corresponding pixels */
  individualPixels[0]=1; //Light "IT"
  individualPixels[1]=1; //Light "IS"
  /* Minutes between 0-5 - Light "O CLOCK" */
  if ((m>=0 && m<5)){
    individualPixels[23]=1;
  /* Minutes between 5-10 or 55-60 - Light "FIVE," "MINUTES" */
  if ((m>=5 && m<10) || (m>=55 && m<60)){
    individualPixels[6]=1;
    individualPixels[7]=1;
  /* Minutes between 10-15 or 50-55 - Light "TEN," "MINUTES" */
  if ((m>=10 && m<15) || (m>=50 && m<55)){
    individualPixels[2]=1;
  /* Minutes between 15-20 or 45-50 - Light "QUARTER" */
  if ((m>=15 && m<20) || (m>=45 && m<50)){
    individualPixels[4]=1;
  /* Minutes between 20-25 or 40-45 - Light "TWENTY," "MINUTES" */
  if ((m>=20 && m<25) || (m>=40 && m<45)){
    individualPixels[5]=1;
  /* Minutes between 25-30 or 35-40 - Light "TWENTY," "FIVE," "MINUTES" */
  if ((m>=25 && m<30) || (m>=35 && m<40)){
  /* Minutes between 30-35 - Light "HALF" */
  if ((m>=30 && m<35)){
    individualPixels[3]=1;
  /* Minutes between 5-35 - Light "PAST" */
  if ((m>=5) && (m<35)){
    individualPixels[8]=1;
  /* Minutes between 35-60 - Light "TO" & MODIFY CURRENT HOUR VALUE */
  if (m>=35){
    individualPixels[9]=1;
    h++; //Add 1 from current hour
    /*Set time to twelve for hour around midnight, noon */
    if (h==0){
      h=12;
    /*Corner case for 12:35-12:59 */
    if (h==13){
      h=1;
  /* Hour=1 - Light "ONE" */
  if (h==1){
    individualPixels[10]=1;
  /* Hour=2 - Light "TWO" */
  if (h==2){
    individualPixels[11]=1;
  /* Hour=3 - Light "THREE" */
  if (h==3){
    individualPixels[12]=1;
  /* Hour=4 - Light "FOUR" */
  if (h==4){
    individualPixels[13]=1;
  /* Hour=5 - Light "FIVE" */
  if (h==5){
    individualPixels[14]=1;
  /* Hour=6 - Light "SIX" */
  if (h==6){
    individualPixels[15]=1;
  /* Hour=7 - Light "SEVEN" */
  if (h==7){
    individualPixels[16]=1;
  /* Hour=8 - Light "EIGHT" */
  if (h==8){
    individualPixels[17]=1;
  /* Hour=9 - Light "NINE" */
  if (h==9){
    individualPixels[18]=1;
  /* Hour=10 - Light "TEN" */
  if (h==10){
    individualPixels[19]=1;
  /* Hour=11 - Light "ELEVEN" */
  if (h==11){
    individualPixels[20]=1;
  /* Hour=12 - Light "TWELVE" */
  if (h==12){
    individualPixels[21]=1;
  /* Light pixels corresponding to current time */
  for (int i=0; i<sizeof(individualPixels); i++){
    if (individualPixels[i]==1){
      pixels.setPixelColor(i, pixels.Color(red,green,blue)); //Set Neopixel color
    else{
      pixels.setPixelColor(i,pixels.Color(0,0,0));
  pixels.show(); //Display Neopixel color
//  /* Clear pixel values for re-assignment during next iteration */
//  for (int j=0; j<sizeof(individualPixels); j++){
//      individualPixels[j]=0; //Set array values to 0
//      pixels.setPixelColor(j, pixels.Color(0,0,0)); //Set Neopixel color to 0 brightness, i.e. off
  if ((m>=0 && m<5)){
The array does not have an element numbered 23, only 0 to 22
Awesome thank you so much, clearly you have a talent for these things.
