I have made a clock based on esp8266 node mcu and max7219. DS1307 rtc use for time keeping. now I add 2 button for setting time in rtc and tested it on proteus simulation software and it works perfectly, but when i want to use this function on real node mcu in my clock it does not works . nota able to change any time using this button. i have tried this code with and without pull up resister . can anybody help me to figure out this problem?
#include "Arduino.h"
#include <Wire.h>
#include "RTClib.h"
#include <RTClib.h>
#include <SoftwareSerial.h>
#include <DFRobotDFPlayerMini.h>
RTC_DS1307 RTC;
SoftwareSerial mySoftwareSerial(0, 2); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
//String date;
#define NUM_MAX 4
#define LINE_WIDTH 16
#define ROTATE 90
// for NodeMCU 1.0
#define DIN_PIN 11 // D8
#define CS_PIN 10 // D7
#define CLK_PIN 13 // D6
#include "max7219.h"
#include "fonts.h"
static uint8_t last_second = 0;
int hour2;
const int buttonHourPin = 3; // Replace with the actual pin number for the hour button
const int buttonMinutePin = 4; // Replace with the actual pin number for the minute button
int lastButtonHourState = HIGH; // Assuming HIGH when not pressed
int lastButtonMinuteState = HIGH; // Assuming HIGH when not pressed
// CHANGE YOUR CONFIG HERE:
Wire.begin();
RTC.begin();
//RTC.adjust(DateTime(F(__DATE__), F(__TIME__)));
mySoftwareSerial.begin(9600);
myDFPlayer.begin(mySoftwareSerial);
myDFPlayer.volume(8);
initMAX7219();
sendCmdAll(CMD_SHUTDOWN, 1);
pinMode(buttonHourPin, INPUT_PULLUP);
pinMode(buttonMinutePin, INPUT_PULLUP);
Serial.print("Connected to RTC module.");
#define MAX_DIGITS 16
byte dig[MAX_DIGITS] = { 0 };
byte digold[MAX_DIGITS] = { 0 };
byte digtrans[MAX_DIGITS] = { 0 };
int updCnt = 0;
int dots = 0;
long dotTime = 0;
long clkTime = 0;
int dx = 0;
int dy = 0;
byte del = 0;
int h, m, s;
long localEpoc = 0;
long localMillisAtUpdate = 0;
DateTime now = RTC.now();
h = now.hour();
m = now.minute();
s = now.second();
if (last_second != now.second()) {
if ((now.minute() == 59) && (now.second() == 58)) {
hour2 = now.hour();
hour2++;
chime();
last_second = now.second();
if (updCnt <= 0) { // every 10 scrolls, ~450s=7.5m
updCnt = 10;
//Serial.println("Getting DateTime now ...");
//printStringWithShift(" Getting DateTime now", 15);
DateTime now();
//Serial.println("DateTime now loaded");
clkTime = millis();
if (millis() - clkTime > 20000 && !del && dots) { // clock for 15s, then scrolls for about 30s
//printStringWithShift(date.c_str(), 40);
//delay(7000);
updCnt--;
clkTime = millis();
if (millis() - dotTime > 500) {
dotTime = millis();
dots = !dots;
updateTime();
showAnimClock();
handleButtons(); // Add this function call to handle button presses
// Adjusting LED intensity.
// 12am to 6am, lowest intensity 0
if ((h == 0) || ((h >= 1) && (h <= 6))) sendCmdAll(CMD_INTENSITY, 3);
// 6pm to 11pm, intensity = 2
else if ((h >= 18) && (h <= 23)) sendCmdAll(CMD_INTENSITY, 3);
// max brightness during bright daylight
else sendCmdAll(CMD_INTENSITY, 3);
void handleButtons() {
int buttonHourState = digitalRead(buttonHourPin);
int buttonMinuteState = digitalRead(buttonMinutePin);
if (buttonHourState == LOW && lastButtonHourState == HIGH) {
delay(100); // Debounce delay
hour2 = (hour2 + 1) % 24;
updateRTC();
if (buttonMinuteState == LOW && lastButtonMinuteState == HIGH) {
m = (m + 1) % 60;
updateRTC();
lastButtonHourState = buttonHourState;
lastButtonMinuteState = buttonMinuteState;
void updateRTC() {
RTC.adjust(DateTime(now.year(), now.month(), now.day(), hour2, m, now.second()));
void chime() {
DateTime now = RTC.now(); // Get the current date and time
int currentHour = now.hour();
if ((currentHour >= 8 && currentHour <= 23) || currentHour == 0) {
// Play the chime sound based on the hour2 variable
// (hour2 is incremented when it's 58 seconds past 59 minutes)
// Your chime sound logic here...
switch (hour2) {
case 0:
myDFPlayer.play(12);
case 1:
myDFPlayer.play(1);
case 2:
myDFPlayer.play(2);
case 3:
myDFPlayer.play(3);
case 4:
myDFPlayer.play(4);
case 5:
myDFPlayer.play(5);
case 6:
myDFPlayer.play(6);
case 7:
myDFPlayer.play(7);
case 8:
myDFPlayer.play(8);
case 9:
myDFPlayer.play(9);
case 10:
myDFPlayer.play(10);
case 11:
myDFPlayer.play(11);
case 12:
case 13:
myDFPlayer.play(1);
case 14:
myDFPlayer.play(2);
case 15:
myDFPlayer.play(3);
case 16:
myDFPlayer.play(4);
case 17:
myDFPlayer.play(5);
case 18:
myDFPlayer.play(6);
case 19:
myDFPlayer.play(7);
case 20:
myDFPlayer.play(8);
case 21:
myDFPlayer.play(9);
case 22:
case 23:
void showSimpleClock() {
dx = dy = 0;
clr();
// Convert hours to 12-hour format and set AM/PM
int displayHour = h % 12;
int isPM = h >= 12;
if (!displayHour) displayHour = 12;
showDigit(displayHour / 10, 4, dig6x8);
showDigit(displayHour % 10, 12, dig6x8);
showDigit(m / 10, 21, dig6x8);
showDigit(m % 10, 29, dig6x8);
showDigit(s / 10, 38, dig6x8);
showDigit(s % 10, 46, dig6x8);
setCol(19, dots ? B00100100 : 0);
setCol(36, dots ? B00100100 : 0);
refreshAll();
void showAnimClock() {
byte digPos[4] = { 1, 8, 17, 25 };
int digHt = 12;
int num = 4;
int i;
if (del == 0) {
del = digHt;
for (i = 0; i < num; i++) digold[i] = dig[i];
int temp = h % 12;
if (!temp) temp = 12;
dig[0] = temp / 10 ? temp / 10 : 10;
dig[1] = temp % 10;
dig[2] = m / 10;
dig[3] = m % 10;
for (i = 0; i < num; i++) digtrans[i] = (dig[i] == digold[i]) ? 0 : digHt;
} else
del--;
clr();
for (i = 0; i < num; i++) {
if (digtrans[i] == 0) {
dy = 0;
showDigit(dig[i], digPos[i], dig6x8);
dy = digHt - digtrans[i];
showDigit(digold[i], digPos[i], dig6x8);
dy = -digtrans[i];
digtrans[i]--;
dy = 0;
setCol(15, dots ? B00100100 : 0);
refreshAll();
delay(60);
void showDigit(char ch, int col, const uint8_t *font) {
if (dy < -8 || dy > 8) return;
int len = pgm_read_byte(font);
int w = pgm_read_byte(font + 1 + ch * len);
col += dx;
for (int i = 0; i < w; i++)
if (col + i >= 0 && col + i < 8 * NUM_MAX) {
byte v = pgm_read_byte(font + 1 + ch * len + 1 + i);
if (!dy) scr[col + i] = v;
else scr[col + i] |= dy > 0 ? v >> dy : v << -dy;
void setCol(int col, byte v) {
col += dx;
if (col >= 0 && col < 8 * NUM_MAX)
if (!dy) scr[col] = v;
else scr[col] |= dy > 0 ? v >> dy : v << -dy;
int showChar(char ch, const uint8_t *font) {
int i, w = pgm_read_byte(font + 1 + ch * len);
for (i = 0; i < w; i++)
scr[NUM_MAX * 8 + i] = pgm_read_byte(font + 1 + ch * len + 1 + i);
scr[NUM_MAX * 8 + i] = 0;
return w;
void printCharWithShift(unsigned char c, int shiftDelay) {
if (c < ' ' || c > '~' + 25) return;
c -= 32;
int w = showChar(c, font);
for (int i = 0; i < w + 1; i++) {
delay(shiftDelay);
scrollLeft();
refreshAll();
void printStringWithShift(const char *s, int shiftDelay) {
while (*s) {
printCharWithShift(*s, shiftDelay);
s++;
void updateTime() {
