Code works on Uno but not on Leonardo
Hi.
Please excuse my ignorance in this area. I using the code below on a Uno and it works as it should, but then I try the same code with a Leonardo without no success. (reading the value from my receiver as they change when I move the transmitter sticks and print the values).
I am aware of the difference in serial and serial1 and I tried both, again without success.
The hardware is a Spektrum AR 610 receiver and a UnoR3 and a brand new Leonardo.
I have 5V and Ground to my receiver from the board and then I have 4 channels from the receiver connected to A0-A3 (I know I should not use A4+A5)
The reason for using the Leonardo is that I will need more than 6 Analog inputs.
The code is from this website and again it works fine with the Uno.
#include <EnableInterrupt.h>
#define SERIAL_PORT_SPEED 57600
#define RC_NUM_CHANNELS 4
#define RC_CH1 0
#define RC_CH2 1
#define RC_CH3 2
#define RC_CH4 3
#define RC_CH1_INPUT A0
#define RC_CH2_INPUT A1
#define RC_CH3_INPUT A2
#define RC_CH4_INPUT A3
uint16_t rc_values[RC_NUM_CHANNELS];
uint32_t rc_start[RC_NUM_CHANNELS];
volatile uint16_t rc_shared[RC_NUM_CHANNELS];
void rc_read_values() {
noInterrupts();
memcpy(rc_values, (const void *)rc_shared, sizeof(rc_shared));
interrupts();
void calc_input(uint8_t channel, uint8_t input_pin) {
if (digitalRead(input_pin) == HIGH) {
rc_start[channel] = micros();
uint16_t rc_compare = (uint16_t)(micros() - rc_start[channel]);
rc_shared[channel] = rc_compare;
void calc_ch1() { calc_input(RC_CH1, RC_CH1_INPUT); }
void calc_ch2() { calc_input(RC_CH2, RC_CH2_INPUT); }
void calc_ch3() { calc_input(RC_CH3, RC_CH3_INPUT); }
void calc_ch4() { calc_input(RC_CH4, RC_CH4_INPUT); }
Serial.begin(SERIAL_PORT_SPEED);
pinMode(RC_CH1_INPUT, INPUT);
pinMode(RC_CH2_INPUT, INPUT);
pinMode(RC_CH3_INPUT, INPUT);
pinMode(RC_CH4_INPUT, INPUT);
enableInterrupt(RC_CH1_INPUT, calc_ch1, CHANGE);
enableInterrupt(RC_CH2_INPUT, calc_ch2, CHANGE);
enableInterrupt(RC_CH3_INPUT, calc_ch3, CHANGE);
enableInterrupt(RC_CH4_INPUT, calc_ch4, CHANGE);
rc_read_values();
Serial.print(“CH1:”); Serial.print(rc_values[RC_CH1]); Serial.print("\t");
Serial.print(“CH2:”); Serial.print(rc_values[RC_CH2]); Serial.print("\t");
Serial.print(“CH3:”); Serial.print(rc_values[RC_CH3]); Serial.print("\t");
Serial.print(“CH4:”); Serial.println(rc_values[RC_CH4]);
delay(200);
Leonardo programs need the line
while (!Serial) {}
so it waits until the serial port is created before trying Serial.begin()
RTFM
...R
