I am trying to implement a battery monitoring circuit for my sensor module.
Here is the function I wrote for it:
int analogpin = A0;
void setup(){
for(int i= 33; i<53; i+=2)
pinMode(i, OUTPUT);
void loop(){
int analogvalue = map(analogRead(analogpin), 0, 1023, 1, 10);
switch(analogvalue){
case 1:
digitalWrite(33, HIGH);
digitalWrite(35, LOW);
digitalWrite(37, LOW);
digitalWrite(39, LOW);
digitalWrite(41, LOW);
digitalWrite(43, LOW);
digitalWrite(45, LOW);
digitalWrite(47, LOW);
digitalWrite(49, LOW);
digitalWrite(51, LOW);
case 2:
digitalWrite(35, HIGH);
case 3:
digitalWrite(37, HIGH);
case 4:
digitalWrite(39, HIGH);
case 5:
digitalWrite(41, HIGH);
case 6:
digitalWrite(43, HIGH);
case 7:
digitalWrite(45, HIGH);
case 8:
digitalWrite(47, HIGH);
case 9:
digitalWrite(49, HIGH);
case 10:
digitalWrite(51, HIGH);
This works fine on an arduino with simply, just this code as the sketch. 7 LEDs light up(as they are supposed to in this case). However when I put this code into my entire sensor module code, random leds light up. the first five are stable and the next coulpe blink sometimes, clearly not working the way its supposed. Is this a current issue or is this a code issue?
THe entire sensor module code is a bit long, but here I go:
//----- Libraries -----//
#include <SPI.h>
#include <MPL115A1Lib.h> // Pressure Sensor MPL115A1
#include <DHT.h> // Temperature and Humidity Sensor RTH03
#include <U8glib.h> // LCD Display 128x64
#include <floatToString.h> // Converts floats to strings
#include <GPS610F.h> // GPS-610F Module
#include <RFZuluArduino.h> // Zulu 2km RF Module
//----- Defining Modules and Variables ------//
// Pressure Sensor
MPL115A1Lib PressSens; // Defines Pressure Sensor for library
#define FT_TO_M(x) ((long)((x)*(0.3048)))
#define KPA_TO_INHG(x) ((x)*(0.295333727))
#define KPA_TO_MMHG(x) ((x)*(7.50061683))
#define KPA_TO_PSIA(x) ((x)*(0.145037738))
#define KPA_TO_KGCM2(x) ((x)*(0.0102))
#define INHG_TO_PSIA(x) ((x)*(0.49109778))
#define DEGC_TO_DEGF(x) ((x)*(9.0/5.0)+32.0)
float press_pKa = 0;
float temp_c= 0;
long alt_ft = 0;
char charPress[7]; // Stores pressure
char charTemp[6]; // Stores temperature in C
char charAlt[5]; // Stores altitude
// Temperature & Humidity Sensor
#define DHTPIN 48 // Defines signal pin connection
#define DHTTYPE DHT22 // Defines Sensor model # DHT22 (RTH03)
DHT dht(DHTPIN, DHTTYPE); // Defines the Temp/Humd Sensor
float t = 0; // temp
float h = 0; // rel. humd.
float f = 0; // temp in f
float hi = 0; // heat index
char rh[6]; // Stores Relative Humidity
char tempC[6]; // Stores Temperature in °C
char tempF[7]; // Stores Temp in F
char heatIndex[7]; // Stores heat index
char degree[3] = {176, 67}; // Stores °C symbol
char degreeF[3] = {176, 70}; // Stores °F symbol
// LCD Display
U8GLIB_ST7920_128X64_4X u8g(41, 42, 43); // Defines LCD pins (SPI: EN = 41, RW = 42, RS = 43)
// GPS Module
GPS610F gps(17, 16, 28, 26, 44, 27, 9600); // Defines GPS pins (SDI, SDO1, SDO2, PIO, PPS, RST, baudRate)
String gpsData;
char charGPS[82] = "";
char nmeaProto[6] = "";
char utcTime[11] = "";
char gpsStatus[2] = "";
char latitude[11] = "";
char nsIndicator[2] = "";
char longitude[11] = "";
char ewIndicator[2] = "";
char speedOverGnd[6] = "";
char courseOverGnd[6] = "";
char utcDate[7] = "";
char magVarDegrees[6] = "";
char magVarDirection[2] = "";
char modeIndicator[2] = "";
char checkSum[3] = "";
char tempTime[9] = "";
char tempDate[9] = "";
char tempLat[12] = "";
char tempLong[13] = "";
// RF Module
RFZuluArduino rf(15, 14, 2, 3, 4, 5, 4800); // Defines the RF module's pins (rx1, tx1, RTS, CTS, RST, PD, baudRate)
//Geiger Counter
unsigned int gcount = 0;
unsigned int countStartTime = 0;
int countsPerMinute=0;
//Battery Monitor
int analogpin = A0;
int analogvalue;
int misc=0;
String str; // temporary string
int draw_state = 0;
int tracker = 0;
Serial1.begin(9600);
//Serial.begin(9600);
dht.begin();
//LCD startup
LCDprepare();
AECLlogo();
//Battery Monitor
pinMode(i, OUTPUT);
//Initiates Battery Monitor
Monitor();
//----- Get Sensor Data -----//
// Temp/Humid
h = dht.readHumidity();
t = dht.readTemperature();
f = dht.readTemperature(true);
hi = dht.computeHeatIndex(f, h);
// Pressure Sensor
press_pKa = PressSens.calculatePressurekPa();
alt_ft = PressSens.calculateAltitudeFt(press_pKa);
//Geiger Counter
while (Serial1.available() > 0) { // Check if geiger counter is available
int inChar = Serial1.read(); // read char from geiger counter
if (inChar == '0' || inChar == '1') { // 0 and 1 represent an event
gcount++; // increase count
unsigned int now = millis(); // now is the time in milliseconds since start of program
unsigned int elapsedTime = now - countStartTime; // time elapsed
if (elapsedTime >= 60000) {
countsPerMinute = gcount;
// reset timers
gcount = 0;
countStartTime = now;
//----- Convert to Transmit -----//
// Temp/Humid
floatToString(rh, h, 1); // relative humidity
floatToString(tempC, t, 1); // temperature in C
floatToString(tempF, f, 1); // temp in F
floatToString(heatIndex, hi, 1); // heat index
// Pressure Sensor
str = String(FT_TO_M(alt_ft)); // convert altitude in ft to m
str.toCharArray(charAlt, 5); // covert string to char array
floatToString(charPress, press_pKa, 2);
// GPS Module*****************************************************
gps.getData().toCharArray(charGPS, 80);
gps.dataFields(0).toCharArray(nmeaProto, 6);
// time
gps.dataFields(1).toCharArray(utcTime, 11);
tempTime[0] = utcTime[0];
tempTime[1] = utcTime[1];
tempTime[2] = ':';
tempTime[3] = utcTime[2];
tempTime[4] = utcTime[3];
tempTime[5] = ':';
tempTime[6] = utcTime[4];
tempTime[7] = utcTime[5];
gps.dataFields(2).toCharArray(gpsStatus, 2);
// latitude
gps.dataFields(3).toCharArray(latitude, 11);
gps.dataFields(4).toCharArray(nsIndicator, 2);
tempLat[0] = latitude[0];
tempLat[1] = latitude[1];
tempLat[2] = 176; // °
tempLat[3] = latitude[2];
tempLat[4] = latitude[3];
tempLat[5] = latitude[4];
tempLat[6] = latitude[5];
tempLat[7] = latitude[6];
tempLat[8] = 39; // '
tempLat[9] = ' ';
tempLat[10] = nsIndicator[0];
// longitude
gps.dataFields(5).toCharArray(longitude, 11);
gps.dataFields(6).toCharArray(ewIndicator, 2);
tempLong[0] = longitude[0];
tempLong[1] = longitude[1];
tempLong[2] = longitude[2];
tempLong[3] = 176; // °
tempLong[4] = longitude[3];
tempLong[5] = longitude[4];
tempLong[6] = longitude[5];
tempLong[7] = longitude[6];
tempLong[8] = longitude[7];
tempLong[9] = 39; // '
tempLong[10] = ' ';
tempLong[11] = ewIndicator[0];
gps.dataFields(7).toCharArray(speedOverGnd, 6);
gps.dataFields(8).toCharArray(courseOverGnd, 6);
// date
gps.dataFields(9).toCharArray(utcDate, 7);
tempDate[0] = utcDate[0];
tempDate[1] = utcDate[1];
tempDate[2] = '/';
tempDate[3] = utcDate[2];
tempDate[4] = utcDate[3];
tempDate[5] = '/';
tempDate[6] = utcDate[4];
tempDate[7] = utcDate[5];
gps.dataFields(10).toCharArray(magVarDegrees, 6);
gps.dataFields(11).toCharArray(magVarDirection, 2);
gps.dataFields(12).toCharArray(modeIndicator, 2);
gps.dataFields(13).toCharArray(checkSum, 3);
//GeigerCounter Conversions
String geigerbuffer = String(countsPerMinute);
char gbuff[5];
geigerbuffer.toCharArray(gbuff,5);
// transmit the data
rf.transmit(charGPS, tempC, rh, charPress, gbuff);
/*test
Serial.println(charGPS);
Serial.println(tempC);
Serial.println(rh);
Serial.println(charPress);
Serial.println(gbuff);
//----- Output to LCD Display -----//
u8g.firstPage();
do {
draw();
while( u8g.nextPage() );
tracker++;
if (tracker <= 2){
draw_state = 0;
else if (tracker <= 5){
draw_state = 1;
/*else if (tracker <= 8){
draw_state = 2;
else {
tracker = 0;
void draw(void) {
LCDprepare();
switch (draw_state){
case 0:
//AECLlogo();
SensorInfo();
case 1:
//SensorInfo();
GpsInfo();
/*case 2:
GpsInfo();
void SensorInfo(){
// Banner
u8g.setColorIndex(1);
u8g.setFont(u8g_font_ncenR08);
u8g.drawStr(12,8, "Sensor Readings:");
battery(); // show charge
// Sensor Readings
tempHumd();
pressSens();
void GpsInfo(){
// Banner
u8g.drawStr(15,8, "GPS Information");
GPSOutput();
void battery(){
// body of the battery
u8g.drawFrame(112,0,16,7);
u8g.drawFrame(111,2,1,3);
u8g.drawBox(113,1,14,5); // fills in the battery
u8g.setColorIndex(0);
u8g.setFont(u8g_font_p01type);
u8g.drawStr(113, 5, "100");
u8g.drawStr(123, 5, "%");
void tempHumd(){
u8g.setFont(u8g_font_baby);
//Temperature
u8g.drawStr(0, 20, "Temperature:");
u8g.drawStr(61, 20, tempC);
u8g.drawStr(81, 20, degree); // °C
u8g.drawStr(91, 20, "/");
u8g.drawStr(98, 20, tempF);
u8g.drawStr(118, 20, degreeF); // °F
//%RH
u8g.drawStr(13, 30, "Humidity:");
u8g.drawStr(74, 30, rh);
u8g.drawStr(95, 30, "%RH");
//Heat index
u8g.drawStr(8, 40, "Heat Index:");
u8g.drawStr(75, 40, heatIndex);
u8g.drawStr(97, 40, degreeF); // °F
void pressSens(){
u8g.drawStr(10, 50, "Pressure:");
u8g.drawStr(72, 50, charPress);
u8g.drawStr(97, 50, "kPa");
u8g.drawStr(14, 60, "Altitude:");
u8g.drawStr(77, 60, charAlt);
u8g.drawStr(98, 60, "m");
void GPSOutput(){
u8g.drawStr(1, 20, "Date:");
u8g.drawStr(26, 20, tempDate); // UTC date
u8g.drawStr(69, 20, "Time:");
u8g.drawStr(93, 20, tempTime); // UTC time
u8g.drawStr(11, 30, "Status:");
u8g.drawStr(48, 30, gpsStatus); // Gps status
u8g.drawStr(73, 30, "Mode:");
u8g.drawStr(105, 30, modeIndicator); // mode indicator
u8g.drawStr(20, 40, "Latitude:");
u8g.drawStr(65, 40, tempLat); // Latitude
u8g.drawStr(15, 50, "Longitude:");
u8g.drawStr(65, 50, tempLong); // Longitude
u8g.drawStr(1, 60, "Speed:");
u8g.drawStr(31, 60, speedOverGnd); // Speed over ground
u8g.drawStr(52, 60, "km");
u8g.drawStr(68, 60, "Course:");
u8g.drawStr(102, 60, courseOverGnd); // course over ground
u8g.drawStr(124, 60, degree); // °
void LCDprepare(){
u8g.setFont(u8g_font_6x10);
u8g.setFontRefHeightExtendedText();
u8g.setDefaultForegroundColor();
u8g.setFontPosTop();
void AECLlogo(){
u8g.setColorIndex(1); // Sets pixels on
// top to bottom left
u8g.drawLine(64, 0, 35, 64);
u8g.drawLine(64, 0, 36, 64);
u8g.drawLine(64, 0, 37, 64);
u8g.drawLine(64, 0, 38, 64);
u8g.drawLine(64, 0, 39, 64);
u8g.drawLine(64, 0, 40, 64);
u8g.drawLine(64, 0, 41, 64);
u8g.drawLine(64, 0, 42, 64);
// top to bottom right
u8g.drawLine(64, 0, 93, 64);
u8g.drawLine(64, 0, 92, 64);
u8g.drawLine(64, 0, 91, 64);
u8g.drawLine(64, 0, 90, 64);
u8g.drawLine(64, 0, 89, 64);
u8g.drawLine(64, 0, 88, 64);
u8g.drawLine(64, 0, 87, 64);
u8g.drawLine(64, 0, 86, 64);
// bottom right to middle left
u8g.drawLine(38, 32, 92, 64);
u8g.drawLine(38, 32, 91, 64);
u8g.drawLine(37, 32, 90, 64);
u8g.drawLine(37, 32, 89, 64);
u8g.drawLine(36, 32, 88, 64);
u8g.drawLine(36, 32, 87, 64);
// left to right
u8g.drawLine(36, 32, 92, 31);
u8g.drawLine(36, 32, 92, 32);
u8g.drawLine(36, 32, 92, 33);
u8g.drawLine(36, 32, 92, 34);
u8g.drawLine(36, 32, 92, 35);
u8g.drawLine(36, 33, 92, 36);
u8g.drawLine(36, 33, 92, 37);
u8g.setColorIndex(0); // sets pixels off
u8g.drawDisc(92,34,3, U8G_DRAW_ALL); // draws filled circle
u8g.setColorIndex(1); // sets pixels on
u8g.drawDisc(96,34,4, U8G_DRAW_ALL); // draws filled circle
// top line
u8g.drawLine(96,27,92,23);
u8g.drawLine(95,27,91,23);
u8g.drawLine(97,27,93,23);
// bottom line
u8g.drawLine(96,41,92,45);
u8g.drawLine(95,41,91,45);
u8g.drawLine(97,41,93,45);
u8g.drawStr(102, 52, "AECL");
u8g.drawStr(102, 60, "EACL");
int freeRam () {
extern int __heap_start, *__brkval;
int v;
return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
void Monitor(){
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
case 10:
