code writing help 16x16 matrix
Hi gang, first off let me say I am new to the world of ARDUINO and coding. I have been tinkering only for about the last month in my spare time(which has not been a lot). Enough said!
I have made myself a 16x16 matrix (256 pixel) with ws2812 in ZIGZAG configuration, and I am using a ARDUINO UNO to control them.
So what I am trying to figure out is a “Simple or easy” way to alter my state of programing.
I will try to explain the best I can.
first off, I am writing code to illuminate all leds in a rainbow pattern, that lights all leds, and from the center out changes through the color spectrum.
Then I would like to have the next cycle do a totally different pattern. I can accomplish this by changing one of the lines, shown below
example:
strip.setPixelColor(ledArray1*, Wheel((i+j) & 255)); “this is original code line”*
then if I add " *2 or other # up to 256" after ((I+j) I get a different result, so new code is this:
strip.setPixelColor(ledArray1_, Wheel((i+j)2 & 255)); "this is with # added"_
so this is what I am trying to accomplish, and am not sure how to write it, or if it is even possible.
in an easier manner than writing the code over and over(which I could do.
I would like to use multiple #'s for multiple outcomes in a loop cycle.
ARDUINO UNO
16x16 matrix (ws2812 led strips) ZIGZAG configuration - homemade
running ADAFRUIT_NEOPIXEL
hope I have provided enough information
thanks in advance
and go easy on me, I am trying but have a limited amount of time I can commit to world of ARDUINO.
sorry, was not sure how to put code in, so I just put it as an attachment down below. :frowning:
_
_
*#include <Adafruit_NeoPixel.h>
#define PIN 4
#define NUM_LEDS 256
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
int ledArray1 = //outside into center 16x16 (256 pixels)
0,1,2,3,4,5,6,7,8,9,
10,11,12,13,14,15,16,47,48,79,
80,111,112,143,144,175,176,207,208,
239,240,241,242,243,244,245,246,247,248,
249,250,251,252,253,254,255,224,223,192,
191,160,159,128,127,96,95,64,63,32,
31,30,29,28,27,26,25,24,23,22,
21,20,19,18,17,46,49,78,81,110,
113,142,145,174,177,206,209,238,237,236,
235,234,233,232,231,230,229,228,227,226,
225,222,193,190,161,158,129,126,97,94,
65,62,33,34,35,36,37,38,39,40,
41,42,43,44,45,50,77,82,109,114,
141,146,173,178,205,210,211,212,213,214,
215,216,217,218,219,220,221,194,189,162,
157,130,125,98,93,66,61,60,59,58,
57,56,55,54,53,52,51,76,83,108,
115,140,147,172,179,204,203,202,201,200,
199,198,197,196,195,188,163,156,131,124,
99,92,67,68,69,70,71,72,73,74,75,
84,107,116,139,148,171,180,181,182,183,
184,185,186,187,164,155,132,123,100,91,
90,89,88,87,86,85,106,117,138,149,
170,169,168,167,166,165,154,133,122,101,
102,103,104,105,118,137,150,151,152,153,
134,121,120,119,136,135,
  strip.begin();
  strip.setBrightness(30);
  strip.show();
  rainbow(10); // rainbow pattern full screen…
//-------------------------rainbow---------------------------------------------------
void rainbow(uint8_t wait)
  for (int n=0; n<4; n++)// n<(#) number of times it will cycle pattern
    uint16_t i, j;
for(j=0; j<256; j++)
    for(i=0; i<strip.numPixels(); i++)
      strip.setPixelColor(ledArray1[i], Wheel((i+j) & 255));
    strip.show();
    delay(2);
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
  WheelPos -= 85;
  return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  strip.show();
    delay(10);
_
```_
_
for arduino fourm (code).txt (2.24 KB)*_
Well since I submitted my ^^ ABOVE^^ question, I have learned a lot. :frowning: :stuck_out_tongue:
I wrote more code, and have drastically improved my knowledge of the the coding(sort of)
#define PIN 4
int ledArray1[] = //outside into center 16x16 (256 pixels)
  strip.begin();
  strip.show();
  rainbow6(10);// rainbow pattern full screen...
  rainbow2(10);
  rainbow3(10);
  rainbow4(10);
  rainbow5(10);
  rainbow(10);
  for (int n=0; n<1; n++)// n<(#) number of times it will cycle pattern
    uint16_t i, j;
    strip.show();
    delay(2);
  if(WheelPos < 85) {
   WheelPos -= 85;
   WheelPos -= 170;
  strip.show();
    delay(10);
//-------------------------rainbow2---------------------------------------------------
void rainbow2(uint8_t wait)
    uint16_t i, j;
      strip.setPixelColor(ledArray1[i], Wheel2((i+j)*4 & 255));
    strip.show();
    delay(2);
uint32_t Wheel2(byte WheelPos) {
  if(WheelPos < 85) {
   WheelPos -= 85;
   WheelPos -= 170;
  strip.show();
    delay(10);
//-------------------------rainbow3---------------------------------------------------
void rainbow3(uint8_t wait)
    uint16_t i, j;
      strip.setPixelColor(ledArray1[i], Wheel3((i+j)*8 & 255));
    strip.show();
    delay(2);
uint32_t Wheel3(byte WheelPos) {
  if(WheelPos < 85) {
   WheelPos -= 85;
   WheelPos -= 170;
  strip.show();
    delay(10);
//-------------------------rainbow4---------------------------------------------------
void rainbow4(uint8_t wait)
    uint16_t i, j;
      strip.setPixelColor(ledArray1[i], Wheel4((i+j)*16 & 255));
    strip.show();
    delay(2);
uint32_t Wheel4(byte WheelPos) {
  if(WheelPos < 85) {
   WheelPos -= 85;
   WheelPos -= 170;
  strip.show();
    delay(10);
//-------------------------rainbow5---------------------------------------------------
void rainbow5(uint8_t wait)
    uint16_t i, j;
      strip.setPixelColor(ledArray1[i], Wheel5((i+j)*32 & 255));// I like this effect
    strip.show();
    delay(75);
uint32_t Wheel5(byte WheelPos) {
  if(WheelPos < 85) {
   WheelPos -= 85;
   WheelPos -= 170;
  strip.show();
    delay(10);
//-------------------------rainbow6---------------------------------------------------
void rainbow6(uint8_t wait)
    uint16_t i, j;
      strip.setPixelColor(ledArray1[i], Wheel6((i+j)*64 & 255));
    strip.show();
    delay(50);
uint32_t Wheel6(byte WheelPos) {
  if(WheelPos < 85) {
   WheelPos -= 85;
   WheelPos -= 170;
  strip.show();
    delay(10);
this would be the best way I could explain what I trying to achieve, wanting to learn an easier way to write the code.
I also discovered that when I change the delay time in the “rainbow#” line/loop that I get different results/effects.
also learnt how to re-arrange their order, so the Loop" I am working with is the first to be displayed. :slight_smile:
I am off to seek more knowledge.
I am a 49 year old, and still learning new things everyday! :wink:
