Codeblocks 17.12
Hallo all
I try to compile the arduino library into the Codeblocks environment.
I got allways the same error:
sketch.cpp:(.text.setup+0xa): undefined reference to Serial' sketch.cpp:(.text.setup+0xc): undefined reference to Serial'
.objs\sketch.o: In function loop': sketch.cpp:(.text.loop+0x4): undefined reference to Serial'
sketch.cpp:(.text.loop+0x6): undefined reference to Serial' .objs\cores\wiring.o: In function delay':
wiring.c:(.text.delay+0x6a): undefined reference to `yield'
collect2.exe: error: ld returned 1 exit status
Do someone know why this error happens?
Thanks Sascha
It appears that you have an undefined reference to Serial.
What is “Codeblocks”?
Could you take a few moments to Learn How To Use The Forum.
Posting tips.
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • How to insert an image into your post. ( Thanks Robin2 )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
