CODED LOCK, with database on excel
hi guys , i have problem to save the date , time out , time in and the user( matricule ) on EXCEL
PLS HELP GUYS , this is the code
#include <LiquidCrystal.h>
#include <Keypad.h>
/*-------------------------------KEYPAD---------------------------------------*/
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 3; //number of columns on the keypad
char key_pressed;
int i ;
int j ;
int PIR = A0;
int LOCK = A4;
const int BUTTON = A3; // boutton pour la sorie placer dans la face de porte dans l'enterieur
char keymap[numRows][numCols]=
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
//Code that shows the the keypad connections to the arduino terminals
byte rowPins[numRows] = {4, 5, 6, 7};//Rows 0 to 3
byte colPins[numCols] = { A5, 2, 3};//Columns 0
Keypad mykeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
/*-------------------------------CONSTANTS------------------------------------*/
LiquidCrystal lcd(13,12,11,10,9,8); //LCD
char MAT[5][4] = {"1111","2222","3333","4444","5555"}; //MATRICULE
char PASS[5][4] = {"1111","2222","3333","4444","5555"};// MOT DE PASSE
    int VAS=0;// ENRGISTRE FIHA VALEUR DE 1 JUSQU'A 5
    char mat[5];
    char password[5];
    //boolean changedPassword = false;
 Serial.begin(9600); // Initialize serial communications with the PC
  Serial.println("LABEL,Date,Matricule,Time IN,Time OUT");// make four columns (Date,Time,[Name:"user name"]line 48 & 52,[Number:"user number"]line 49 & 53)
              lcd.begin(16, 2); //Setup the LCD's number of columns and rows
              pinMode(BUTTON, INPUT);// BUTTON
              pinMode(A1, OUTPUT); // LED RED
              pinMode(A2, OUTPUT); // LED GREEN
              pinMode(A0, INPUT);//PIR
              pinMode(A4, OUTPUT);   //LOCK
 if(digitalRead(PIR) == HIGH)
        lcd.setCursor(0,0);
        lcd.print("ENTER MAT:  ");
        lcd.setCursor(0,1);
        lcd.print("");
 key_pressed = mykeypad.getKey();
  if (key_pressed == '0' || key_pressed == '1' || key_pressed == '2' || key_pressed == '3' || key_pressed == '4' || key_pressed == '5' || key_pressed == '6' || key_pressed == '7' || key_pressed == '8' || key_pressed == '9' ) {
    mat[i++] = key_pressed;
      lcd.setCursor(i, 2);
      lcd.print(key_pressed);
    if (i == 4)
    for(int l=0;l<4;l++)
       int resultat = 0;  //ajout de resultat pour afficher la valeur renvoyer par la comparaison
       resultat = strncmp(mat, MAT[l],4) ; //on compare les mots
  if(resultat == 0)
        VAS=l;
        i =0;
        lcd.setCursor(0, 0);
        lcd.print(" Mat Accepted");
        lcd.setCursor(0, 1);
        lcd.print("                ");
        digitalWrite(A2, HIGH);
        delay(300);
        digitalWrite(A2, LOW);
        lcd.clear();
        lcd.print("Enter Password   ");
        delay(400);
  while (j < 4) {
    if (key_pressed== '0' || key_pressed== '1' || key_pressed== '2' || key_pressed== '3' || key_pressed== '4' || key_pressed== '5' || key_pressed== '6' || key_pressed== '7' || key_pressed== '8' || key_pressed== '9')
          password[j++] = key_pressed;
          lcd.setCursor(j, 2);
          lcd.print("*");
          key_pressed=0;
  if (!strncmp(password, PASS[VAS],4))
          j=0;
          lcd.print("Pass Accepted");
          lcd.print("WELCOME");
          digitalWrite(LOCK, HIGH);//unlock the door for 5 seconds
                 Serial.print("DATA,DATE," + MAT[5][4]);//send the Name to excel
      Serial.print(",");
      Serial.print(MAT[5][4]); //send the Number to excel
      Serial.print(",");
      Serial.print("");
      Serial.print(",");
      Serial.println("TIME");
           digitalWrite(LOCK, LOW);
          delay(300);
          lcd.clear();
            j=0;
            lcd.print("                    ");
            lcd.print("Wrong Password");
            digitalWrite(A1,HIGH);
            delay(200);
            digitalWrite(A1,LOW);
            lcd.print("Wrong Mat");
            lcd.print("Try again PLS");
            delay(200);
            delay(200);
            lcd.clear();
            lcd.print("Enter Mat");
             i =0;
            lcd.clear();
            digitalWrite(4,LOW);
            digitalWrite(5,LOW);
            digitalWrite(6,LOW);
            digitalWrite(7,LOW);
    if(digitalRead(BUTTON) == HIGH){
        j=0;
       /*   Serial.print(",");
      Serial.print(",");
      Serial.print("");
      Serial.print(",");
      Serial.println("TIME");*/
          lcd.clear();
        return loop();
Don't you think it might be important to tell us what the problem is?
That comment makes no sense.
or
  if (key_pressed >= '0' && key_pressed <= '9' ) {
Which one is easier to read and understand?
Why?
I gave up reading your code. It looks like it was typed by a drunken monkey high on crack.
Get that monkey into rehab, and learn to use Tools + Auto Format.
return loop();
what do you want with this?
this code is to open the door by 5 users ,everyone has his number and password, i need to save the time of enter and the number of the user on excel , pls help
You've gotten several responses with questions and suggestions. It does not appear that you've even read the responses. Just why should we continue trying to help?
I did what you told me , i am amateure , that's why i am asking you guys , i tried to change few things
#include <Keypad.h>
char key_pressed;
int i ;
int j ;
int PIR = A0;
int LOCK = A4;
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
    char mat[5];
    char password[5];
              lcd.begin(16, 2);
        lcd.setCursor(0,0);
        lcd.setCursor(0,1);
        lcd.print("");
    if (i == 4)
  if(resultat == 0)
        VAS=l;
        i =0;
        lcd.print("                ");
        delay(300);
        lcd.clear();
        delay(400);
  while (j < 4) {
          lcd.print("*");
          key_pressed=0;
          j=0;
      Serial.print(",");
      Serial.print(",");
      Serial.print("TIME IN");
      Serial.print(",");
      Serial.println("");
          delay(300);
          lcd.clear();
            j=0;
            lcd.print("                    ");
            delay(200);
            delay(200);
            delay(200);
            lcd.clear();
             i =0;
            lcd.clear();
        j=0;
      Serial.print(",");
      Serial.print("");
      Serial.print(",");
          lcd.clear();
i am amateure
Even an amateur can answer questions about what the problem is. Why should we keep looking at your code, when we do not know what the problem is?
i can connect excel to arduino but when i open the door i get nothing on table , no save for data
The indention was not one of them. The Tools + Auto Format menu item doesn't require any effort to use. Reading piss-poorly indented code requires too much effort.
Instead of writing to Excel, for the time being, open the Serial Monitor app, instead, and add more Serial.print() statements, to see what your code is actually doing.
You gave some of these pins meaningful names. Why are you not using them?
INPUT is rarely the correct value. INPUT_PULLUP is usually much better. You need to understand what each value means, and determine, based on how the thing connected to the pin is actually wired, which is better.
That array does not have an element with those indices. Array indexes start at 0.
What does your calculator say the result is of ADDing a string literal and a non-existent value? That operator does NOT append strings.
