codeing
hi im not sure what i s wrong with this code but please can someone help me? the code for processing PING the code is from lucky larry
the IDE says error variable of field “serialEvent” declared void
error expected ) 'before ‘my port’ this is in the highlighted bit of the code
import processing.serial.*;     // import serial library
Serial myPort;                  // declare a serial port
[glow=yellow,2,300]float x, y;                       // variable to store x and y co-ordinates for vertices[/glow]
int radius = 350;               // set the radius of objects
int w = 300;                    // set an arbitary width value
int degree = 0;                 // servo position in degrees
int value = 0;                  // value from sensor
int motion = 0;                 // value to store which way the servo is panning
int[] newValue = new int[181];  // create an array to store each new sensor value for each servo position
int[] oldValue = new int[181];  // create an array to store the previous values.
PFont myFont;                   // setup fonts in Processing
int radarDist = 0;              // set value to configure Radar distance labels
int firstRun = 0;               // value to ignore triggering motion on the first 2 servo sweeps
/* create background and serial buffer */
void setup(){
  // setup the background size, colour and font.
  size(750, 450);
  background (0); // 0 = black
  myFont = createFont("verdana", 12);
  textFont(myFont);
  // setup the serial port and buffer
  myPort = new Serial(this, Serial.list()[1], 9600);
  myPort.bufferUntil('n');
/* draw the screen */
void draw(){
  fill(0);                              // set the following shapes to be black
  noStroke();                           // set the following shapes to have no outline
  ellipse(radius, radius, 750, 750);    // draw a circle with a width/ height = 750 with its center position (x and y) set by the radius
  rectMode(CENTER);                     // set the following rectangle to be drawn around its center
  rect(350,402,800,100);                // draw rectangle (x, y, width, height)
  if (degree >= 179) {                  // if at the far right then set motion = 1/ true we're about to go right to left
    motion = 1;                         // this changes the animation to run right to left
  if (degree <= 1) {                    // if servo at 0 degrees then we're about to go left to right
    motion = 0;                         // this sets the animation to run left to right
  /* setup the radar sweep */
  We use trigonmetry to create points around a circle.
  So the radius plus the cosine of the servo position converted to radians
  Since radians 0 start at 90 degrees we add 180 to make it start from the left
  Adding +1 (i) each time through the loops to move 1 degree matching the one degree of servo movement
  cos is for the x left to right value and sin calculates the y value
  since its a circle we plot our lines and vertices around the start point for everything will always be the center.
  strokeWeight(7);                      // set the thickness of the lines
  if (motion == 0) {                    // if going left to right
    for (int i = 0; i <= 20; i++) {     // draw 20 lines with fading colour each 1 degree further round than the last
      stroke(0, (10*i), 0);             // set the stroke colour (Red, Green, Blue) base it on the the value of i
      line(radius, radius, radius + cos(radians(degree+(180+i)))*w, radius + sin(radians(degree+(180+i)))*w); // line(start x, start y, end x, end y)
  } else {                              // if going right to left
    for (int i = 20; i >= 0; i--) {     // draw 20 lines with fading colour
      stroke(0,200-(10*i), 0);          // using standard RGB values, each between 0 and 255
  /* Setup the shapes made from the sensor values */
  noStroke();                           // no outline
  /* first sweep */
  fill(0,50,0);                         // set the fill colour of the shape (Red, Green, Blue)
  beginShape();                         // start drawing shape
    for (int i = 0; i < 180; i++) {     // for each degree in the array
      x = radius + cos(radians((180+i)))*((oldValue[i])); // create x coordinate
      y = radius + sin(radians((180+i)))*((oldValue[i])); // create y coordinate
      vertex(x, y);                     // plot vertices
  endShape();                           // end shape
  /* second sweep */
  fill(0,110,0);
  beginShape();
      x = radius + cos(radians((180+i)))*(newValue[i]);
      y = radius + sin(radians((180+i)))*(newValue[i]);
      vertex(x, y);
  endShape();
  /* average */
  fill(0,170,0);
  beginShape();
      x = radius + cos(radians((180+i)))*((newValue[i]+oldValue[i])/2); // create average
      y = radius + sin(radians((180+i)))*((newValue[i]+oldValue[i])/2);
      vertex(x, y);
  endShape();
  /* if after first 2 sweeps, highlight motion with red circle*/
  if (firstRun >= 360) {
    stroke(150,0,0);
    strokeWeight(1);
    noFill();
        if (oldValue[i] - newValue[i] > 35 || newValue[i] - oldValue[i] > 35) {
          ellipse(x, y, 10, 10);
  /* set the radar distance rings and out put their values, 50, 100, 150 etc.. */
  for (int i = 0; i <=6; i++){
    noFill();
    strokeWeight(1);
    stroke(0, 255-(30*i), 0);
    ellipse(radius, radius, (100*i), (100*i));
    fill(0, 100, 0);
    noStroke();
    text(Integer.toString(radarDist+50), 380, (305-radarDist), 50, 50);
    radarDist+=50;
  radarDist = 0;
  /* draw the grid lines on the radar every 30 degrees and write their values 180, 210, 240 etc.. */
  for (int i = 0; i <= 6; i++) {
    strokeWeight(1);
    stroke(0, 55, 0);
    line(radius, radius, radius + cos(radians(180+(30*i)))*w, radius + sin(radians(180+(30*i)))*w);
    fill(0, 55, 0);
    noStroke();
    if (180+(30*i) >= 300) {
      text(Integer.toString(180+(30*i)), (radius+10) + cos(radians(180+(30*i)))*(w+10), (radius+10) + sin(radians(180+(30*i)))*(w+10), 25,50);
      text(Integer.toString(180+(30*i)), radius + cos(radians(180+(30*i)))*w, radius + sin(radians(180+(30*i)))*w, 60,40);
  /* Write information text and values. */
  noStroke();
  fill(0);
  fill(0, 100, 0);
  text("Degrees: "+Integer.toString(degree), 100, 380, 100, 50);         // use Integet.toString to convert numeric to string as text() only outputs strings
  text("Distance: "+Integer.toString(value), 100, 400, 100, 50);         // text(string, x, y, width, height)
  text("Radar screen code at luckylarry.co.uk", 540, 380, 250, 50);
  fill(0);
  rect(70,60,150,100);
  fill(0, 100, 0);
  text("Screen Key:", 100, 50, 150, 50);
  fill(0,50,0);
  rect(30,53,10,10);
  text("First sweep", 115, 70, 150, 50);
  fill(0,110,0);
  rect(30,73,10,10);
  text("Second sweep", 115, 90, 150, 50);
  fill(0,170,0);
  rect(30,93,10,10);
  text("Average", 115, 110, 150, 50);
  noFill();
  stroke(150,0,0);
  strokeWeight(1);
  ellipse(29, 113, 10, 10);
  fill(150,0,0);
  text("Motion", 115, 130, 150, 50);
/* get values from serial port */
void serialEvent (Serial myPort) {
  String xString = myPort.readStringUntil('n');  // read the serial port until a new line
    if (xString != null) {  // if theres data in between the new lines
        xString = trim(xString); // get rid of any whitespace just in case
        String getX = xString.substring(1, xString.indexOf("V")); // get the value of the servo position
        String getV = xString.substring(xString.indexOf("V")+1, xString.length()); // get the value of the sensor reading
        degree = Integer.parseInt(getX); // set the values to variables
        value = Integer.parseInt(getV);
        oldValue[degree] = newValue[degree]; // store the values in the arrays.
        newValue[degree] = value;
        /* sets a counter to allow for the first 2 sweeps of the servo */
        firstRun++;
        if (firstRun > 360) {
          firstRun = 360; // keep the value at 360
moderator update: code tags
It looks like you have picked up some badly out od date code. Look at the serial class in the reference section, there you will find the current explanation of serialEvent().
If you remove the myPort param from the dec and change myPort to Serial it should at leat build.
The code however uses String which is a very bad idea on an arduino. And to be honest the rest of the code you have copied is very poor - I'd recommend you scrap it and start over!.
Mark
That code is not for an arduino it is for the Processing language.
Ah......
Mark
