Codes not getting dumped
HI -
There is problem with dumping, getting the following messages, could it be resolved?
Thanks
Arduino: 1.8.5 (Windows 8), Board: "Arduino Nano, ATmega328P"
Sketch uses 4248 bytes (13%) of program storage space. Maximum is 30720 bytes.
Global variables use 475 bytes (23%) of dynamic memory, leaving 1573 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe5
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe5
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
That's not dumping, that's uploading.
But the usual:
  • Did you select the right COM port?
  • Did it work before?
  • Did you install the drivers?
  • Is it a real Arduino or a clone? (eBay, Ali, Amazon are 99% clones)
If it's a new original Nano (not clone), you need to update the board manager to version 1.6.21.
