Hi there,
i got some of these 433Mhz RF-transmitters and recievers and planed to use them in a home automation project. Some arduinos should exchange data wirelessly.
But after some testing i noticed the very low signal range of these devices using the VirtualWire-library. VirtualWire isn't using any forward-error-correction (FEC). It can only verificate if the message is received properly or not by checking the CRC-checksum. So i decided to write an enhanced version of the library including some error-correction-algorithm in cost of data throughput.
My CodeWire-library is based on VirtualWire and uses a barker-code sequence to improve the signal to noise ratio and the manchaster-code to remove dc-components from the signal. It is even possible to determine the signal-strength of received messages. Using the CodeWire-library is fairly easy, because the commands of both libraries a nearly the same. Look at CodeWire.h for additional information.
Example:
Server Code:
#include <CodeWire.h>
uint8_t buf[16];
uint8_t i = 0;
uint8_t len = 16;
unsigned long timer = 0;
pinMode(6, OUTPUT);
pinMode(13, OUTPUT);
//startup CodeWire-library
cw_setup(1000); //define transmission speed
cw_rx_start(); //enable receiver-module
timer = millis()-1000;
//wait for incoming messages and reply them after a short break
if (cw_have_message() == true){
len = 16;
cw_get_message(buf, &len);
delay(1000); //important: wait until the superregenation-receiver of the server recalibrated the input level! Otherwise long ranged transmissions are not possible!
cw_send(buf, len);
timer = millis();
if (millis()-timer < 50){
digitalWrite(6, true);
}else{
digitalWrite(6, false);
Client Code:
uint8_t sen_buf[16];
uint8_t rec_buf[16];
uint8_t i = 0;
uint8_t len = 16;
uint8_t ok = 0;
pinMode(6, OUTPUT);
// send out ping-singnal every 10 seconds.
if (millis()-timer > 10000){
timer = millis();
for(i=0;i<16;i++){
sen_buf[i] = random(256); //randomize message
cw_send(sen_buf, 16); //send 16 byte of message data
Serial.print("sent message:");
for(i=0;i<16;i++){
Serial.print(" ");
Serial.print(sen_buf[i], HEX);
Serial.println("");
ok = true;
len = 16;
cw_get_message(rec_buf, &len); //receive message
Serial.print("got message:");
for(i=0;i<16;i++){
Serial.print(" ");
if (sen_buf[i] != rec_buf[i]){ //compare it with original message
ok = false;
Serial.println("");
if (ok = true){
Serial.println("message ok");
}else{
Serial.println("message fail");
Serial.println(cw_rx_signal_strength()); //print signal strength of last received message
Serial.println("");
Modules i used:
transmitter-module: XD-FST
receiver-module: XD-RF-5V
Link VirtualWire-library: VirtualWire: VirtualWire library for Arduino and other boards
CodeWire.zip (10.7 KB)
