int valore = 0;
int pompa = 7;
int setpoint = 0;
const int sensore_pulse = 8; //Sensore pulsazione
boolean state = true;
int counter = 0;
Serial.begin(9600); //Il baud rate predefinito del Nextion TFT è 9600.
pinMode(pompa,OUTPUT);
//==================================================// Bottone 1 //==================================================//
if(Serial.available()>0)
String Received = Serial.readString();
if(int(Received[0]) == 1)
digitalWrite(pompa,HIGH);
setpoint = 42; //================================Calibro bottone 1 (100ml)
while(1)
digitalWrite(pompa, HIGH);
if (!digitalRead(sensore_pulse) && state)
counter++;
state = false;
if (digitalRead(sensore_pulse))
state = true;
valore = counter;
long percent = map(valore, 0, setpoint, 0, 100);
Serial.print("j0.val="); //Stampo la variabile che voglio che cambi sullo schermo
Serial.print(percent); //Stampo il valore che voglio visualizzare
Serial.write(0xff); //Aggiungo sempre 3 full bytes dopo
Serial.write(0xff);
Serial.write(0xff);
if (counter >= setpoint)
valore = 0;
counter = 0;
setpoint = 0;
Serial.print("page 7"); //Stampo il valore che voglio visualizzare
Serial.write(0xff);
Serial.write(0xff);
digitalWrite(pompa, LOW);
delay(30);
//==================================================// Bottone 2 //==================================================//
if(int(Received[0]) == 2)
setpoint = 110; //================================Calibro bottone 2 (250ml)
while(1)
counter++;
state = false;
state = true;
valore = counter;
Serial.write(0xff);
Serial.write(0xff);
valore = 0;
counter = 0;
setpoint = 0;
Serial.write(0xff);
Serial.write(0xff);
delay(30);
//==================================================// Bottone 3 //==================================================//
if(int(Received[0]) == 3)
setpoint = 219; //================================Calibrate bottone 3 (500ml)
while(1)
counter++;
state = false;
state = true;
valore = counter;
Serial.write(0xff);
Serial.write(0xff);
valore = 0;
counter = 0;
setpoint = 0;
Serial.write(0xff);
Serial.write(0xff);
delay(30);
//==================================================// Bottone 4 //==================================================//
if(int(Received[0]) == 4)
setpoint = 442; //================================Calibro bottone 4 (1000ml)
while(1)
counter++;
state = false;
state = true;
valore = counter;
Serial.write(0xff);
Serial.write(0xff);
valore = 0;
counter = 0;
setpoint = 0;
Serial.write(0xff);
Serial.write(0xff);
delay(30);
Buongiorno e benvenuto nella sezione Italiana del forum,
prima di tutto ti segnalo che, nella sezione in lingua Inglese, si può scrivere SOLO in Inglese ... quindi, per favore, la prossima volta presta più attenzione in quale sezione metti i tuoi post; questa volta esso è stato spostato, da un moderatore della sezione di lingua Inglese, nella sezione di lingua Italiana ... la prossima volta potrebbe venire direttamente eliminato, dopo di che ...
... cortesemente, leggi attentamente il REGOLAMENTO di detta sezione, (... e, per evitare future possibili discussioni/incomprensioni, prestando molta attenzione al punto 15) e poi, come da suddetto regolamento (punto 16.7), fai la tua presentazione NELL'APPOSITA DISCUSSIONE spiegando bene quali esperienze hai in elettronica e programmazione, affinché noi possiamo conoscere la tua esperienza ed esprimerci con termini adeguati.
Grazie,
Guglielmo
P.S.: Ti ricordo che, purtroppo, fino a quando non sarà fatta la presentazione nell’apposita discussione, nel rispetto del succitato regolamento nessuno ti risponderà (eventuali risposte o tuoi ulteriori post, verrebbero temporaneamente nascosti), quindi ti consiglio di farla al più presto.
P.P.S.: Evitate di utilizzare la traduzione automatica fatta dal browser ... vi impedisce di capire la lingua della sezione dove andate a scrivere ...
