Buenas tardes chic@s,
Mi codigo no se compila su puestamente porque atan2f no esta definida. He intentado definirla pero o no se o no es el problema.
No se casi nada de programacion asi que esto es muy duro pa mi, a ver si podeis echar un ojo al codigo. Dejo tambien el enlace a la libreria por si alguien le interesa o quiere probar.
Solo necesito que compile para cargarlo, que haga una cosa u otra ye es harina de otro costal.
Este es el codigo:
Example sketch for the PS3 USB library - developed by Kristian Lauszus
For more information visit my blog: http://blog.tkjelectronics.dk/ or
send me an e-mail: kristianl@tkjelectronics.com
#include <PS3USB.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#include <SPI.h>
#endif
USB Usb;
/* You can create the instance of the class in two ways */
PS3USB PS3(&Usb); // This will just create the instance
//PS3USB PS3(&Usb,0x00,0x15,0x83,0x3D,0x0A,0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
bool printAngle;
uint8_t state = 0;
#if !defined(__MIPSEL__)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while (1); //halt
Serial.print(F("\r\nPS3 USB Library Started"));
Usb.Task();
if (PS3.PS3Connected || PS3.PS3NavigationConnected) {
if (PS3.getAnalogHat(LeftHatX) > 137 || PS3.getAnalogHat(LeftHatX) < 117 || PS3.getAnalogHat(LeftHatY) > 137 || PS3.getAnalogHat(LeftHatY) < 117 || PS3.getAnalogHat(RightHatX) > 137 || PS3.getAnalogHat(RightHatX) < 117 || PS3.getAnalogHat(RightHatY) > 137 || PS3.getAnalogHat(RightHatY) < 117) {
Serial.print(F("\r\nLeftHatX: "));
Serial.print(PS3.getAnalogHat(LeftHatX));
Serial.print(F("\tLeftHatY: "));
Serial.print(PS3.getAnalogHat(LeftHatY));
if (PS3.PS3Connected) { // The Navigation controller only have one joystick
Serial.print(F("\tRightHatX: "));
Serial.print(PS3.getAnalogHat(RightHatX));
Serial.print(F("\tRightHatY: "));
Serial.print(PS3.getAnalogHat(RightHatY));
// Analog button values can be read from almost all buttons
if (PS3.getAnalogButton(L2) || PS3.getAnalogButton(R2)) {
Serial.print(F("\r\nL2: "));
Serial.print(PS3.getAnalogButton(L2));
if (!PS3.PS3NavigationConnected) {
Serial.print(F("\tR2: "));
Serial.print(PS3.getAnalogButton(R2));
if (PS3.getButtonClick(PS))
Serial.print(F("\r\nPS"));
if (PS3.getButtonClick(TRIANGLE))
Serial.print(F("\r\nTraingle"));
if (PS3.getButtonClick(CIRCLE))
Serial.print(F("\r\nCircle"));
if (PS3.getButtonClick(CROSS))
Serial.print(F("\r\nCross"));
if (PS3.getButtonClick(SQUARE))
Serial.print(F("\r\nSquare"));
if (PS3.getButtonClick(UP)) {
Serial.print(F("\r\nUp"));
PS3.setLedOff();
PS3.setLedOn(LED4);
if (PS3.getButtonClick(RIGHT)) {
Serial.print(F("\r\nRight"));
PS3.setLedOff();
PS3.setLedOn(LED1);
if (PS3.getButtonClick(DOWN)) {
Serial.print(F("\r\nDown"));
PS3.setLedOff();
PS3.setLedOn(LED2);
if (PS3.getButtonClick(LEFT)) {
Serial.print(F("\r\nLeft"));
PS3.setLedOff();
PS3.setLedOn(LED3);
if (PS3.getButtonClick(L1))
Serial.print(F("\r\nL1"));
if (PS3.getButtonClick(L3))
Serial.print(F("\r\nL3"));
if (PS3.getButtonClick(R1))
Serial.print(F("\r\nR1"));
if (PS3.getButtonClick(R3))
Serial.print(F("\r\nR3"));
if (PS3.getButtonClick(SELECT)) {
Serial.print(F("\r\nSelect - "));
PS3.printStatusString();
if (PS3.getButtonClick(START)) {
Serial.print(F("\r\nStart"));
printAngle = !printAngle;
if (printAngle) {
Serial.print(F("\r\nPitch: "));
Serial.print(PS3.getAngle(Pitch));
Serial.print(F("\tRoll: "));
Serial.print(PS3.getAngle(Roll));
else if (PS3.PS3MoveConnected) { // One can only set the color of the bulb, set the rumble, set and get the bluetooth address and calibrate the magnetometer via USB
if (state == 0) {
PS3.moveSetRumble(0);
PS3.moveSetBulb(Off);
} else if (state == 1) {
PS3.moveSetRumble(75);
PS3.moveSetBulb(Red);
} else if (state == 2) {
PS3.moveSetRumble(125);
PS3.moveSetBulb(Green);
} else if (state == 3) {
PS3.moveSetRumble(150);
PS3.moveSetBulb(Blue);
} else if (state == 4) {
PS3.moveSetRumble(175);
PS3.moveSetBulb(Yellow);
} else if (state == 5) {
PS3.moveSetRumble(200);
PS3.moveSetBulb(Lightblue);
} else if (state == 6) {
PS3.moveSetRumble(225);
PS3.moveSetBulb(Purple);
} else if (state == 7) {
PS3.moveSetRumble(250);
PS3.moveSetBulb(White);
state++;
if (state > 7)
state = 0;
Este es el error:
C:\Users\Laptop\Desktop\Impresora\Arduino Instaladores\arduino-1.0.5-r2\libraries\USBHostShield20\PS3BT.cpp: In member function 'float PS3BT::getAngle(AngleEnum)':
C:\Users\Laptop\Desktop\Impresora\Arduino Instaladores\arduino-1.0.5-r2\libraries\USBHostShield20\PS3BT.cpp:107: error: 'atan2f' was not declared in this scope
C:\Users\Laptop\Desktop\Impresora\Arduino Instaladores\arduino-1.0.5-r2\libraries\USBHostShield20\PS3BT.cpp:109: error: 'atan2f' was not declared in this scope
Y esta la libreria:
Muchas gracias.
