Hello mates, and greetings from Germany,
I've a question:
Is it possible to code to complet and different codes on the same ESP-Cam ? I want to switch between a 3-pin-switch between those firmware. To understand what I really mean, here is an example:
For example, if I do not switch the 3-pin-switch, than the first code is apllied. If I switch the 3-pin-switch, than the other code is applied. Here is a code example:
// not switching the pin, the following codes is gonna run
#include "EEPROM.h"
int Test=0;
void setup();
Serial.println("yeaaah!!");
void loop();
Serial.println("on noooo :( ");
// switching the pin, than this code runs:
#include "FS.h"
int Test=0;
void setup();
Serial.println("wooops");
void loop();
Serial.println("ohhh yeahhhh : ");
