Coding a switch.
Hi, I'm currently working on a project with an LDR and 3 LED's, so baisically the more light the more LED's will turn on, however I want to give the option to turn the LED's manually aswell, I have a small switch and I was wondering whether I could do the following sequence:
  • Press once, 1 LED
  • Press twice, 2 LED's
  • Press the third time, 3 LED's
  • And finally the fourth time the switch is being pressed all LED's will turn off.
Thank you!
Similar to this code, but instead of 0 to 255, you want 0 to 3.
const byte LED = 6;
const byte Button = 2;
  pinMode(LED, OUTPUT);
  pinMode(Button, INPUT_PULLUP); // switch is normally HIGH and will go LOW when pressed.
  static byte last = LOW;
  static short count = 0;
  byte ButtonState = digitalRead(Button);
  if (ButtonState != last) // if the button is not equal to its last state ie held.
    if (ButtonState == LOW) // if button is pressed
      Serial.println(count);
      analogWrite(LED, count += 5); increment count by a factor of 5
    last = ButtonState;// update last button state.
  if (count > 255) // if count goes over 255, reset it back to zero and set LED off
    digitalWrite(LED, LOW);
    count = 0;
Also is it a switch or a button?
HazardsMind:
const byte LED = 6;
    count = 0;
Thanks, and it’s a button, my bad!
Here’s my coding:
//Amine Elazri
//19/01/2015
//LDR Circuit V001
int LDR_Pin = A0; //analog pin 0
int Led13 = 13;
int Led12 = 12;
int Led11= 11;
void setup() // One time run
Serial.begin(9600); //Data transmition between the board and the computer (9600bps)
pinMode (Led11, OUTPUT);
pinMode (Led12, OUTPUT);
pinMode (Led13, OUTPUT);
void loop() // will read multiple times “in a loop”
int LDRReading = analogRead(LDR_Pin);
Serial.println(LDRReading);
delay(250); // the interger is the amount of ms that the
if(LDRReading > 850)
digitalWrite; (Led11, LOW);
digitalWrite; (Led12, LOW);
digitalWrite; (Led13, LOW);
else if ((LDRReading >575) && (LDRReading <850))
digitalWrite; (Led11, HIGH);
else if ((LDRReading >350) && (LDRReading <575))
digitalWrite; (Led12, HIGH);
else if ((LDRReading >250) && (LDRReading <350))
digitalWrite; (Led13, HIGH);
How would I incorporate it? Sorry I’ve just been learning this for a few weeks now!
if (count == 1) //turn on one LED
else if (count == 2) //turn on two LEDs
else if (count == 3) //turn on three LEDs
else // count = 0 or greater than 3 // all off
HazardsMind: if (count == 1) //turn on one LED
So will I need to put this in?
digitalWrite; (Led11, HIGH); digitalWrite; (Led12, LOW); digitalWrite; (Led13, LOW);
and so on?
Sorry im a newbie!
yes
HazardsMind:
yes
Thanks, can I put it anywhere in the sketch or does it have to be at the top?
in the loop
