Hi all,
I'm coding a timer system, at the moment something simple but I've already hit what may be a logic problem to how I'm tackling it.
The essence is the user can set ON, OFF and temperature values, which I do by a simple web-page that updates a JSON file on the Arduino/esp8266 littlefs filesystem. The structure is as follows:
{"sc_data":[{"dayofweek":"6","hourofday":"15","minuteofday":"00","settingvalue":"35"},{"dayofweek":"6","hourofday":"15","minuteofday":"45","settingvalue":"40"},{"dayofweek":"0","hourofday":"01","minuteofday":"00","settingvalue":"0"}],"scheduler":"1"}
In "sc_data" we hold the array of 3 values, dayofweek (0-6), hourofday (0-23), minuteofday (0-59) and setting value (int 0 being off, 1 being on, value >1 being a temperature).
In my code, I can check this against RTC (which I've loaded from ntp) and providing my device is running and the loop hits timing correct I can exactly match, dayofweek, hourofday and minuteofday.
However, what if I miss it? What if the unit is rebooted and is in the middle of a time-period?
I also do NOT sort my JSON stored array, so it could be in the wrong order (as in my example above, day 6 entries are first then there is a day 0 entry)
I'm trying to save memory, so I am using JUST the jsondocument store that I query/write and update:
DynamicJsonDocument doc_schedule(2048);
And my current timer check code is like this:
void heatschedule() {
// read the json file
File configFile = LittleFS.open("/schedule.json", "r");
DeserializationError error = deserializeJson(doc_schedule, configFile, DeserializationOption::NestingLimit(4));
if (error) {
DEBUG_PRINT("Failed to open config /schedule.json file for reading error : " + String(error.c_str()));
DEBUG_PRINT("opened /schedule.json");
configFile.close();
DateTimeParts p = DateTime.getParts();
int CurrDay = p.getWeekDay();
int Hours = p.getHours();
int Minutes = p.getMinutes();
DEBUG_PRINT("Current day of week: " + String(CurrDay));
DEBUG_PRINT("Current hour: " + String(Hours));
DEBUG_PRINT("Current mins: " + String(Minutes));
for (JsonObject elem : doc_schedule["sc_data"].as<JsonArray>()) {
if ((elem["dayofweek"].as<int>() == CurrDay) && (elem["hourofday"].as<int>() == Hours) && (elem["minuteofday"].as<int>() == Minutes)) {
DEBUG_PRINT("DAY HOUR AND MINUTES MATCH - trigger value " + String(elem["settingvalue"].as<int>()));
trigger_heater(elem["settingvalue"].as<int>());
So you can see I do a simple if match for day,hour,minute, which obviously doesn't work if we come to this AFTER the trigger time (It's not an efficient way to do it, I understand that).
I'm trying to get my head round how to solve. Possibly convert day+hour+minute to seconds since epoch/unixtime? Still unsure if I could then do a simple sort/calculate to check the LAST trigger event easily.
Any logical hints/tips anyone can give me please?
Thank you!
