Coding Error in My Sketch - Any Ideas?
Hi!
This is my first time posting so if I’m not supposed to ask this question or it should be someplace else, do please let me know.
I have an Arduino Uno R3 and also a servo and an IR receiver. I can press buttons on my remote and it writes the “Left” or “Right” as below. Also, when I upload the code below, the servo turns to the right and sticks there, as if trying to go further. What I am trying to do is click the left or right button on my remote and make the servo spin one way or the other.
I’m certain that I am misunderstanding something simple here. . . Can anyone suggest changes?
Thanks so much!
-Gary
======= SNIP =====
#include <Servo.h>
#include <IRremote.h> // use the library
Servo myservo;
int receiver = 11; // pin 1 of IR receiver to Arduino digital pin 11
IRrecv irrecv(receiver); // create instance of ‘irrecv’
decode_results results;
int pos = 0;
myservo.attach(9);
irrecv.enableIRIn(); // Start the receiver
Serial.begin(9600); // for serial monitor output
void translateIR() // takes action based on IR code received
switch(results.value)
case 2148500501: Serial.write(" LEFT\n “); for(pos = 90; pos <= 180; pos += 1) { myservo.write(pos); } break;
case 2148467733: Serial.write(” LEFT\n"); for(pos = 90; pos <= 180; pos += 1) { myservo.write(pos); } break;
case 2148467732: Serial.write(" RIGHT\n “); for(pos = 90; pos >= 0; pos -= 1) { myservo.write(pos); } break;
case 2148500500: Serial.write(” RIGHT\n"); for(pos = 90; pos >= 0; pos -= 1) { myservo.write(pos); } break;
if (irrecv.decode(&results)) // have we received an IR signal?
{ Serial.write(" TEST\n ");
translateIR();
for (int z=0; z<2; z++) // ignore 2nd and 3rd signal repeat
irrecv.resume(); // receive the next value
GSoon
The code below will not “correct” but it should give you an understanding of what is wrong in your code.
Best regards
Jantje
#include <Servo.h>
Servo myservo;
IRrecv irrecv(receiver); // create instance of 'irrecv'
   int pos = 0;
myservo.attach(9);
    case 2148500501:
    case 2148467733: Serial.write(" LEFT\n");    myservo.write(++pos);      break;
    case 2148467732:
    case 2148500500: Serial.write(" RIGHT\n");     myservo.write(--pos);      break;
    translateIR();
