i am currently making a countdown timer using a ws2812 ledstrip to create a 2 digit 7 segment display and i am having problems with my code
it showing this error message:
In file included from /Users/swaggyt/Documents/Arduino/sketch_may01c/sketch_may01c.ino:2:0:
/Users/swaggyt/Documents/Arduino/libraries/FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.005
# pragma message "FastLED version 3.002.005"
/Users/swaggyt/Documents/Arduino/sketch_may01c/sketch_may01c.ino:19:1: warning: declaration does not declare anything [-fpermissive]
CRGBArray<NUM_LEDS> leds; /* CRGB leds[NUM_LEDS]; <--not using this. Using
sketch_may01c:22:14: error: expected constructor, destructor, or type conversion before '(' token
CRGBSet segA ( leds(pps * 0, pps - 1+(pps * 0) ));
sketch_may01c:23:14: error: expected constructor, destructor, or type conversion before '(' token
CRGBSet segB ( leds(pps * 1, pps - 1+(pps * 1) ));
sketch_may01c:24:14: error: expected constructor, destructor, or type conversion before '(' token
CRGBSet segC ( leds(pps * 2, pps - 1+(pps * 2) ));
sketch_may01c:25:14: error: expected constructor, destructor, or type conversion before '(' token
CRGBSet segD ( leds(pps * 3, pps - 1+(pps * 3) ));
sketch_may01c:26:14: error: expected constructor, destructor, or type conversion before '(' token
CRGBSet segE ( leds(pps * 4, pps - 1+(pps * 4) ));
sketch_may01c:27:14: error: expected constructor, destructor, or type conversion before '(' token
CRGBSet segF ( leds(pps * 5, pps - 1+(pps * 5) ));
sketch_may01c:28:14: error: expected constructor, destructor, or type conversion before '(' token
CRGBSet segG ( leds(pps * 6, pps - 1+(pps * 6) ));
/Users/swaggyt/Documents/Arduino/sketch_may01c/sketch_may01c.ino: In function 'void LEDStrip_setup()':
sketch_may01c:32:54: error: expected primary-expression before ',' token
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds,
/Users/swaggyt/Documents/Arduino/sketch_may01c/sketch_may01c.ino: In function 'void setSegments(uint8_t)':
sketch_may01c:68:1: error: 'segA' was not declared in this scope
segA = segB = segC = segD = segE = segF = segG = CRGB::Black; // Initially set segments
sketch_may01c:68:8: error: 'segB' was not declared in this scope
sketch_may01c:68:15: error: 'segC' was not declared in this scope
sketch_may01c:68:22: error: 'segD' was not declared in this scope
sketch_may01c:68:29: error: 'segE' was not declared in this scope
sketch_may01c:68:36: error: 'segF' was not declared in this scope
sketch_may01c:68:43: error: 'segG' was not declared in this scope
sketch_may01c:91:50: error: expected ',' before '+' token
for (uint8_t p = 0; p < (7 * pps); p++) { leds[p + (7 * pps)] = leds[p]; }}}}
sketch_may01c:91:50: error: expected identifier before '+' token
/Users/swaggyt/Documents/Arduino/sketch_may01c/sketch_may01c.ino: In lambda function:
sketch_may01c:91:63: error: expected '{' before '=' token
sketch_may01c:91:72: error: expected '{' before ';' token
sketch_may01c:91:63: error: no match for 'operator=' (operand types are 'setSegments(uint8_t)::<lambda()>' and 'setSegments(uint8_t)::<lambda()>')
/Users/swaggyt/Documents/Arduino/sketch_may01c/sketch_may01c.ino:91:61: note: candidate: setSegments(uint8_t)::<lambda()>& setSegments(uint8_t)::<lambda()>::operator=(const setSegments(uint8_t)::<lambda()>&) <deleted>
/Users/swaggyt/Documents/Arduino/sketch_may01c/sketch_may01c.ino:91:61: note: no known conversion for argument 1 from 'setSegments(uint8_t)::<lambda()>' to 'const setSegments(uint8_t)::<lambda()>&'
exit status 1
my code is as follows:
#include <FastLED.h>
#define DATA_PIN 11
#define LED_TYPE SK6812
#define COLOR_ORDER RGB
#define NUM_LEDS 56
#define BRIGHTNESS 250
#define FRAMES_PER_SECOND 5
#define CRGBSet
#define leds
const uint8_t pps = 4; // number of Pixels Per Segment
CHSV segON10(96, 255, 255); // color of 10s digit segments NOT TURNED RED
CHSV segON(96, 255, 255); // color of 1s digit segments
CRGBArray instead. */
// Name segments (based on layout in link above) and define pixel ranges.
void LEDStrip_setup() {
pinMode(DATA_PIN, OUTPUT);
NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(BRIGHTNESS);
FastLED.clear(); }
void LEDStrip_loop() {
FastLED.delay(1); }
void setSegments(uint8_t count) {
// Based on the current count set number segments on or off
uint8_t c1 = 0; // Variable to store 1s digit
uint8_t c10 = 0; // Variable to store 10s digit
uint8_t c;
CHSV segCOLOR(0, 0, 0);
if (count > 9) { // Split out 1s and 10s digits if count is greater then 9
c1 = count % 10;
c10 = count / 10;
c1 = count;
c10 = 0;}
// Operate on 1s digit segments first, shift them over, and then do the 10s digit segments
for (uint8_t i = 0; i < 2; i++) {
if (i == 0) {
c = c1;
segCOLOR = segON;
c = c10;
segCOLOR = segON10; }
if (c == 0) {
segB = segC = segD = segE = segF = segG = segCOLOR; }
if (c == 1) {
segB = segG = segCOLOR; }
if (c == 2) {
segA = segB = segC = segE = segF = segCOLOR;}
if (c == 3) {
segA = segB = segC = segF = segG = segCOLOR;}
if (c == 4) {
segA = segB = segD = segG = segCOLOR;}
if (c == 5) {
segA = segC = segD = segF = segG = segCOLOR;}
if (c == 6) {
segA = segC = segD = segE = segF = segG = segCOLOR; }
if (c == 7) {
segB = segC = segG = segCOLOR;}
if (c == 8) {
segA = segB = segC = segD = segE = segF = segG = segCOLOR;}
if (c == 9) {
segA = segB = segC = segD = segF = segG = segCOLOR; }
if (i == 0) { // Shift segments over to 1s digit display area
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
counter_with_sensor_7segment.ino (1.41 KB)
