Can anyone share coding for serial reception of a character from PC to Arduino mega2560 microcontroller.. I urgently need this .....
There are examples provided with the IDE.
if (Serial.available() >0){
byte incomingByte = Serial.read();
// now do something with incomingByte
thank you so much sir... but i need full programming code for serial communication reception of a character from PC to ARDUINO MEGA2560 micro controller
See reply #1
sir i need programming code for coding for serial reception of a character from PC to Arduino mega2560 microcontroller... i urgently need code sir...
karthikeyan:
Which part do you not understand about look in the examples in the IDE - specifically SerialCallResponse
Craig
hi sir,
Could you send program for serial reception of an any character from PC to Arduino mega 2560 microcontroller as soon as possible
val = Serial.read();
Now what exactly do you want to do?
@OP will you please stop posting the same question over and over again in different parts of the forum?
This is called cross-posting, and it is a shortcut to banning.
Topic merged.
There seems to be a rush of these sort of questions today. I wonder if it is an assignment?
Mostly from the same member, it would seem.
Very simple code for capturing one or more characters sent via the serial monitor.
// zoomkat 7-30-11 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
Serial.println("serial test 0021"); // so I can keep track of what is loaded
while (Serial.available()) {
delay(2); //delay to allow byte to arrive in input buffer
char c = Serial.read();
readString += c;
if (readString.length() >0) {
Serial.println(readString);
readString="";
AWOL:
There was also the one in the robotics forum earlier this week - maybe check IP addresses and see if they are one and the same ? This guys seems to have the same tone and registered around the same time
Craig
