Coding for smart Monitoring System
I need to Change the parameter to the arduino board by simple messaging through sms via GSM module. Is it possible to do that? Example If i want to change the value of hot and cold in the code ??
#include <dht.h>
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
SoftwareSerial serialSIM900(7,8);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
dht DHT;
#include "DHT.h"
#define DHT11_PIN A0
const int hot = 28; // set temperature high
const int cold = 20; //set Temperature cold parameter
const int high = 70;//set Humidity hot parameter
const int low = 10; // Set Humidity low parameter
If you mean that you have a sketch running on an Arduino and you want to change the value of some variables in the sketch using an SMS message then yes you can do that.
Please can you write me the code
ardly:
Surjit:
Don't be silly :slight_smile:
There is a gigs and collaborations section of the forum where you may find somebody that you can pay to write code for you. It would be a good idea to write a detailed specification of what you require.
ardly:
Please can you give me the hint How to do that
"Project Guidance" is for people who are doing a project themselves and need a little help.
If you want to pay somebody to write code post in "Gigs and Collaborations"
http://forum.arduino.cc/index.php?board=26.0
