Coding for two DS18B20 temperature sensors
Hello everyone,
So I've just started a project for the first time looking to measure various water quality parameters with an Arduino. I'm taking it step by step and just successfully coded my first sketch that actively measured temperature and had a speaker go off if it went out of bounds of parameters I set. Now, I'm interested in adding an additional DS18B20 temperature sensor, but am now running into problems.
Here's my code below:
#include <DallasTemperature.h>
#include <OneWire.h>
int digitalspeak = 8;   //Pin Digital Speaker is connected to
int temp_sensor1 = 5;   //Pin DS18B20 Sensor 1 is connected to
int temp_sensor2 = 6;   //Pin DS18B20 Sensor 2 is connected to
float temperature = 0;   //Variable to store the temperature in
int lowerLimit = 15;  //define the lower threshold for temperature
int higherLimit = 30;  //define the higher threshold for temperature
OneWire oneWirePin1(temp_sensor1);
OneWire oneWirePin2(temp_sensor2);
DallasTemperature sensors(&oneWirePin1);
DallasTemperature sensors(&oneWirePin2);
void setup(void) {
  //Setup the speaker to act as outputs
  pinMode (digitalspeak, OUTPUT);
  sensors.begin();
  Serial.print("Requesting Temperatures from sensors: ");
  sensors.requestTemperatures();
  Serial.println("DONE");
  temperature = sensors.getTempCByIndex(0);
  digitalWrite(digitalspeak, LOW);
  Serial.print("Temperature is ");
  Serial.print(temperature);
  if(temperature <= lowerLimit){
    Serial.println(", Digital speaker is Activated");
    tone(digitalspeak,3000,1000);
  else if(temperature >= higherLimit){
I'm starting to get error messages when introducing "DallasTemperature sensors(&oneWirePin2);". What am I doing wrong?
You are not posting the entire text of the error message(s). There is a copy errors button in the lower right of the IDE window. Copy the errors and paste into a post in code tags.
Sorry - here are the error messages:
Arduino: 1.8.9 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega1280"
sketch_jun15a:18:26: error: redefinition of 'DallasTemperature sensors'
C:\Users\Tyler.Tyler-PC\Desktop\sketch_jun15a\sketch_jun15a.ino:17:19: note: 'DallasTemperature sensors' previously declared here
exit status 1
option enabled in File -> Preferences.
This seems ridiculous. You appear to be trying to use a one wire device with proper one wire code on two pins. I bet you don't have good reason for using two pins anyway.
Try http://www.hacktronics.com/Tutorials/arduino-1-wire-tutorial.html for two sensors on one pin. Note that there are two programmes, the first to get the sensor addresses, and the second to use them.
In the unlikely event that you really do need each sensor on its own pin, try this
http://sheepdogguides.com/ardo duino/ar3ne1tt2.htm
About the only reason for using this is that you are running out of memory faster than you are running out of pins, but I don't think you save much..
