Does anybody know how to do this exact same thing but without visuino and using actual hand written code? I tried to follow the tutorial but visuino does not support my board, and when i try to compile the code i get errors. I have the attiny 85 board. I know this board is limited in its capabilities but im not sure what it can and cant do. Does anyone know if i can even accomplish this sort of thing with the attiny, or is my board too cheap and useless? Any help or advice would be very helpful. I try coding by myself but still am not very good. Thank you.
That tutorial was a demonstration of using an IR remote control device, an IR receiver and a relay module with an Arduino Nano.
You can still do all that with an ATTINY85 but without the Visuino development tools because it is such a simple application.
Start by looking for projects which use the ATTINY85 IR library: Google
When i try to use IRLibrary it says multiple instances of IRLibrary were found. Do you know why this problem occurs?
mrbdog498:
I'm just guessing that it is probably because you have multiple copies of that library. I can't imagine what else you could possibly read from that.
Not getting anywhere for good reason in the thread on THE SAME SUBJECT in Programming Questions, what do you know there's this new one with a different first name and the same (SOMEONE PLEASE HELP) in Project Guidance.
Participants here might as well read that one to see the sticking points that brought this one about.
