Looking for some coding help. I have a device that outputs to a data stream that is read by an Uno.
Ive done the code that reads the stream successfully, but what I want to do now is trigger 2 digital pins based on the value of Byte 5 as it changes
Below is the Output
FF 0 0 0 3 0 0 0 30 32 Time (ms) =405
The value it outputs is 0, 4, 8 and 12
I want one digital pin to trigger on 4, the other on 8 and both on 12
Code attached.
Any ideas?
FaveroFullArm_ExtensionDecoder.ino (5.15 KB)
Take a look at the bitRead() function or consider using the bit mask functionality available in C, ie &, |, ^ etc
Please follow the advice on posting a programming question given in Read this before posting a programming question
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here
Have tried the bit read function. Byte 5 of my string defines the state of the lamps
Bit D2 = RED lamp (left)
Bit D3 = GREEN lamp (right)
1 is on and 0 is off
What im not clear on is how to use bitread() to specifically read bits 2 and bit 3 in byte 5 of my string " Buffer1"
Im clear how to trigger a digital pin from the bit read command - triggering the LED below
if (bitRead(???,2) == 1) {
digitalWrite(LED_BUILTIN, HIGH);
Not using code tags strikes again
What are you not clear about ?
byte bit2 = bitRead(buffer1[5], 2); //read bit 2 of byte 5 of buffer1 array
byte bit3 = bitRead(buffer1[5], 3);
byte bit5 = bitRead(buffer1[5], 5);
So Sorry,
Im new to all this so apologies for not following correct protocol
Thanks - Your help is doing what I want with the code
