Coding help required
Code written by Dennis Miller.
As a first attempt of coding.
2 74HC595 ICs cascaded to light up one LED at a time till all
are lit up.
Then the MR_Pin is set to low to Zero the register content
And the process starts all over again.
int SHCP_Pin = 8; // latch pin
int STCP_Pin = 9; // Storage Register clock input low to High
int DS_Pin = 10; // Data transferred to Register and output
int MR_Pin = 7; // Memory reset pin
pinMode(SHCP_Pin, OUTPUT); // Set pins 8,9,10 to output mode
pinMode(STCP_Pin, OUTPUT);
pinMode(DS_Pin, OUTPUT);
pinMode(MR_Pin, OUTPUT);
digitalWrite(SHCP_Pin, LOW);
digitalWrite(STCP_Pin, LOW);
digitalWrite(DS_Pin, LOW);
digitalWrite(MR_Pin, LOW);
for( int i = 0; i <=16; i++)
digitalWrite(MR_Pin, HIGH); // set MR_Pin to high
digitalWrite(DS_Pin, HIGH); // set DS_Pin high
delay(10); // introduce a delay
digitalWrite(SHCP_Pin, HIGH); // set SHCP_Pin high to send serial data to the Registers
delay(10); // introduce dealy
digitalWrite(SHCP_Pin, LOW); // set SHCP_Pin low
digitalWrite(STCP_Pin, HIGH); //set STCP_Pin High to send serial dats from REgisters to output
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
digitalWrite( MR_Pin, HIGH);
delay(10);
digitalWrite(MR_Pin, LOW); // Reset Shiftregister
Sorry!!
uploaded the old code!!
feeling foolish!!
Dennis Miller
/* This code hs been slightly modified and tidied up, however I failed in an attempt to use a table as suggested.
Is this code any better than the previous code?
ALSO HELP ? SUGESSTIONS required so that once all the leds are lit up I want to extinquish them one at a time.
I can stop the led's from going out i.e stop the register from resetting but have not got a clue how to reverse the process.
digitalWrite(SHCP_Pin, LOW); // Set pins to LOW
for( int i = 0; i <=16; i++) // set up for loop
initialiseshiftRegister(); // Initialise the shiftregister
lightupLeds(); // light up the led's
digitalWrite( MR_Pin, HIGH); // Stopping this 3 lines of code from running stops once all the led'd are lit up
delay(10);
void initialiseshiftRegister() // Functio to initialise shift register
void lightupLeds() // fuc=nction to light up all 16 led's
digitalWrite(DS_Pin, HIGH); // Make a data HIGH available on th eSerial input of the 74HC595
delay(10);
digitalWrite(SHCP_Pin, HIGH); // latch the data
delay(10);
digitalWrite(SHCP_Pin, LOW); // reset the latch pin
delay(10);
digitalWrite(STCP_Pin, HIGH); // Pass the data onto the register and the paralell output of the 74HC595
delay(10);
digitalWrite(STCP_Pin, LOW); // Reset the to low ready to transfer the next set of data to the sregister
When you post code, please use the "#" CODE TAGS button so it looks like the following:
 are lit up.
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
    delay(10);
  delay(10);
You've posted your code (incorrectly) but haven't told us what the problem is.
There's no need to make another post to correct something, just modify (edit) your original post.
