Coding help!
New to the Arduino software.
The Board we are using is the LilyPad Arduino w/ ATMega328.
We have 6 LEDs (3 red and 3 green) and a button.
We're trying to get the 3 red LEDs to light up when the button is clicked once, and if the button is pressed for more than 2 seconds, the green LEDs should light up.
We need the coding please! This is our first project and we need a jump start as time is low
DanielHastings:
Is that the extent of it? Do any LEDs ever go off?
DanielHastings:
That's not really what this forum is for. It's for helping people with particular problems with their code, not providing code for them. See this post: (sticky) http://arduino.cc/forum/index.php/topic,97455.0.html In particular, items 6 and 10.
That being said, the Arduino already provides a fairly comprehensive set of example sketches showing basic functionality of nearly all it's features. Spend a few minutes looking through them, and you'll likely find a lot of what you're looking for.
Go do some reading in the Learning section. Start with declaring IO pin, setting them up as inputs & outputs,
add Debounce of a button, then add checking for time passage using millis.
What you are after is pretty basic.
@OP
To save your inevitable embarrassment, I've deleted your duplicate cross-postings.
Cross-posting wastes time, and I'm sure you wouldn't want that.
