Coding Help
I am learning coding and working with arduinos but i have a project that involves work out of my depth but something i am willing to understand.
The project that i am working on is a Rc controller for my Quadcopter.
i found a site with a code to do such a task, but its much more advanced script to what i know.
So can some one help understand what i need to do with this scripts.
/* omote robotic controller
   written by Oscar Liang
   blog.oscarliang.net
   Client - Robot side
#include "Arduino.h"
#define MaxPacketNum 20
byte packets[MaxPacketNum];
byte pre_packets[MaxPacketNum];
byte Cur_Packet_Index = 0;
int pot1 = 0;
int pot2 = 0;
int pot3 = 0;
int pot4 = 0;
int js1_x = 512;
int js1_y = 512;
int js2_x = 512;
int js2_y = 512;
bool toggle1 = 0;
bool toggle2 = 0;
bool toggle3 = 0;
bool toggle4 = 0;
bool button3 = 0;
bool button4 = 0;
bool button5 = 0;
bool button6 = 0;
void DecodeButton(byte byte1, bool *bit1, bool *bit2, bool *bit3, bool *bit4, bool *bit5, bool *bit6, bool *bit7, bool *bit8){
// Usage: DecodeButton(buttonByte, &toggle1, &toggle2, &toggle3, &toggle4, &button3, &button4, &button5, &button6);
	byte sum = 0;
	*bit1 = byte1 >> 7;
	sum += (*bit1)*128;
	*bit2 = (byte1-sum) >> 6;
	sum += (*bit2)*64;
	*bit3 = byte1-sum >> 5;
	sum += (*bit3)*32;
	*bit4 = byte1-sum >> 4;
	sum += (*bit4)*16;
	*bit5 = byte1-sum >> 3;
	sum += (*bit5)*8;
	*bit6 = byte1-sum >> 2;
	sum += (*bit6)*4;
	*bit7 = byte1-sum >> 1;
	sum += (*bit7)*2;
	*bit8 = byte1-sum >> 0;
void DecodeButton2(byte byte1, byte *bit1, byte *bit2, byte *bit3, byte *bit4, byte *bit5, byte *bit6, byte *bit7, byte *bit8){
	byte sum = 0;
	*bit1 = byte1 >> 7;
	sum += (*bit1)*128;
	sum += (*bit2)*64;
	sum += (*bit3)*32;
	sum += (*bit4)*16;
	sum += (*bit5)*8;
	sum += (*bit6)*4;
	sum += (*bit7)*2;
void OM_Init(){
  delay(100);
  Serial.write(1);
bool OM_ReceivePacket(){
	if(Serial.available() > 0){
		while (Serial.available() > 0) {
			pre_packets[Cur_Packet_Index] = packets[Cur_Packet_Index]; // saving previous commands
			packets[Cur_Packet_Index++] = Serial.read();
			delay(2);
			// packets overflow, flag error
			if (Cur_Packet_Index >= MaxPacketNum){
				Serial.write(98);
				Serial.flush();
		switch (packets[0]){
				// full short
			case 0:	{
				// verfity we have received all data
				if(Cur_Packet_Index < 9){
					Serial.write(99);
				pot1 = map(packets[1], 0, 255, 0, 1023);
				pot2 = map(packets[2], 0, 255, 0, 1023);
				pot3 = map(packets[3], 0, 255, 0, 1023);
				pot4 = map(packets[4], 0, 255, 0, 1023);
				js1_x = map(packets[5], 0, 255, 0, 1023);
				js1_y = map(packets[6], 0, 255, 0, 1023);
				js2_x = map(packets[7], 0, 255, 0, 1023);
				js2_y = map(packets[8], 0, 255, 0, 1023);
				DecodeButton(packets[9], &toggle1, &toggle2, &toggle3, &toggle4, &button3, &button4, &button5, &button6);
			// full - long
			case 1: {
				pot1 = word(packets[1], packets[2]);
				pot2 = word(packets[3], packets[4]);
				pot3 = word(packets[5], packets[6]);
				pot4 = word(packets[7], packets[8]);
				js1_x = word(packets[9], packets[10]);
				js1_y = word(packets[11], packets[12]);
				js2_x = word(packets[13], packets[14]);
				js2_y = word(packets[15], packets[16]);
				DecodeButton(packets[17], &toggle1, &toggle2, &toggle3, &toggle4, &button3, &button4, &button5, &button6);
			// sel - short
			case 2: {
				pot2 = map(packets[1], 0, 255, 0, 1023);
				js1_x = map(packets[2], 0, 255, 0, 1023);
				js1_y = map(packets[3], 0, 255, 0, 1023);
				DecodeButton(packets[4], &toggle1, &toggle2, &toggle3, &toggle4, &button3, &button4, &button5, &button6);
			// sel - long
			case 3: {
				pot2 = word(packets[1], packets[2]);
				js1_x = word(packets[3], packets[4]);
				js1_y = word(packets[5], packets[6]);
				DecodeButton(packets[7], &toggle1, &toggle2, &toggle3, &toggle4, &button3, &button4, &button5, &button6);
			default:
		// Reset Variables for next loop
		return true;
	else{
		return false;
void OM_SendFeedback(byte feedback){
	Serial.write(feedback);
Any help would be appreciated.
I can not post the host side of code as it exceeds 9500 chars but code can be found at http://blog.oscarliang.net/diy-wireless-rc-remote-controller-for-robots/
