Coding Help
Hi guys,
I'm a bit new to Arduino so this may be stupid, but I'm trying to make a program that takes an input of characters from the serial port, uses it to create a string, and then writes that same string to the serial port. (I call it the parrot code for obvious reasons.) The main problem is that it has to take in any generic string so long as its 6 characters long and the first character is a. The code is below. My problem is that the code will only run once. That is to say that the first string will work perfectly, but upon inputting a second string the code won't do anything. Any possible fixes?
Code:
  • The code is just not running twice.
  • Fix that and you should be good, because it works
  • perfectly for the first time.
    //Also, the code only accepts strings prefaced by 'a',
    //otherwise it won't print it.
int txtMsgLength = 6;
String txtMsg = ""; // a string for incoming text
while (!Serial) {
; // wait for serial port to connect
// send an intro:
Serial.println("Code Initialized");
if (Serial.available() > 0) {
for( int x = 0; x < 1; x++) {
char inChar = Serial.read();
txtMsg += inChar; // add any incoming characters to the String:
if (txtMsg.length() == txtMsgLength && txtMsg.startsWith("a") ) {
Serial.println(txtMsg);
Thanks,
RainBox
(deleted)
Thanks!
Total noob question though, how exactly would I do that?
Sorry for my incompetence :slight_smile: ,
RainBox
Thanks for the suggestion but it didn't end up working. Maybe I did it wrong?
What I changed the last if statement to was:
txtMsg = "";
But the code still won't run twice.
Any other suggestions, or a fix on that old one?
Whoops my bad. But yes, please do look at it if you could.
 * The code is just not running twice.
  while (!Serial) {
  // send an intro:
            txtMsg = "";
It is not a good idea to use Strings with Arduino. They cause memory problems.
Use character arrays instead, and post your code properly, so it looks like this similar program using character arrays;
char message[21];  //20 characters plus zero terminator
int x=0; //array index
  while (!Serial) {
  // send an intro:
      message[x] = Serial.read(); // add incoming characters to the array
      x++; //increment index
      message[x]=0; //terminate character string
    if ( strlen(message) == 20 ) { //if 20 characters have been read and stored, print the string
            Serial.println(message);
            x=0; //start over from beginning
            message[x]=0; //empty message
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
It is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. Just use cstrings - char arrays terminated with 0.
...R
Add some extra Serial.print statements to see what your code is doing. Examining the intermediate results should make it clear why the code is failing.
      Serial.print("inChar ");
      Serial.print((int)inChar, DEC);
      Serial.print(' ');
      Serial.println(inChar);
      Serial.print("txtMsg "); Serial.println(txtMsg);
HINT 1: In the serial console window, set it to "No line ending". If do you do not, your program will receive invisible characters such as line feed or carriage return or both. This will not fix the problem but it reduces the complexity.
HINT 2: The for loop executes only 1 time so it can be removed. But this will not fix the problem.
