coding help
I need help to make below flow
Move Disk (PUL=9, DIR =8)
If pin 21 is High
Stop DISK
Set pin 10 HIGH then LOW
Move Motor1 (PUL=7, DIR=6) for 5 seconds
Stop Motor1
Set pin 3 High for 1 second
second Set pin 3 High for 1 second
Start over again even if pin 21 is HIGH (it will go LOW once disk moves)
If pin 21 is LOW
Move disk
i tried below coding but not stable
#include <Stepper.h>
int PULD = 9; //define Pulse pin
int DIRD = 8;//define Direction pin
int DIRT = 6;
int PULT = 7;
int VLV1 = 3;
int ORG = 2;
int val;
int IR = 21;
int sp;
pinMode (PULD, OUTPUT);
pinMode (DIRD, OUTPUT);
pinMode (PULT, OUTPUT);
pinMode (DIRT, OUTPUT);
pinMode (VLV1, OUTPUT);
pinMode (ORG, INPUT);
pinMode (IR, INPUT);
digitalWrite(DIRD, HIGH);
digitalWrite(PULD, HIGH);
delayMicroseconds(648); //Speed
digitalWrite(PULD, LOW);
delayMicroseconds(50); //Stop
sp = digitalRead(IR);
if (sp == LOW)
for (int i = 0; i < 50; i++)
digitalWrite(DIRD, LOW);
delayMicroseconds(10000);
val = digitalRead(ORG);
if (val == LOW)
for (int x = 0; x < 32000; x++)
digitalWrite(DIRT, HIGH);
digitalWrite(PULT, HIGH);
delayMicroseconds(50); //Speed
digitalWrite(PULT, LOW);
delayMicroseconds(100); //Stop
for (int x = 0; x < 1500; x++)
digitalWrite(VLV1, HIGH);
delayMicroseconds(1000);
digitalWrite(VLV1, LOW);
for (int i = 0; i < 2500; i++)
digitalWrite(DIRT, LOW);
Please tell us in detail what your program actually does and what you want it to do that is different.
To make it easy for people to help you please modify your post and use the code button </>
so your code
looks like this
and is easy to copy to a text editor. See How to use the Forum
...R
