Currently I'm having some troubles with serial communication between two arduinos. I can send and receive the data however the receiving end seems to be getting a lot of interference since the motors are turning when they shouldn't be.
Transmitter.
#include <PS2X_lib.h> //for v1.6
PS2X ps2x; // create PS2 Controller Class
// Arrays, 0 = Left, 1 = Right, 2 = Vertical
int ledPin = 3;
int error = 0;
int data[] = {
0, 0};
int pwm[] = {
0, 0, 0};
int dir[] = {
0, 0, 0};
byte type = 0;
int sync = 0xAA;
int led1 = 0xBB;
int led2 = 0xCC;
void setup(){
pinMode(ledPin, OUTPUT);
error = ps2x.config_gamepad(13,10,11,12, true, true); //setup pins and settings: GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
void loop(){
ps2x.read_gamepad();
data[0] = (ps2x.Analog(PSS_LY));
data[1] = (ps2x.Analog(PSS_RY));
for(int index = 0; index < 2; index++){
if(data[index] <= 104){
pwm[index] = map(data[index], 104, 0, 0, 255);
dir[index] = 1;
else if(data[index] >= 150){
pwm[index] = map(data[index], 150, 255, 0, 255);
dir[index] = 0;
else{
pwm[index] = 0;
dir[index] = 0;
if(ps2x.Button(PSB_L2)){
pwm[2] = 255;
dir[2] = 0;
else if(ps2x.Button(PSB_R2)){
pwm[2] = 255;
dir[2] = 1;
else{
pwm[2] = 0;
dir[2] = 0;
for(int index = 0; index < 3; index++){
Serial.write(sync);
Serial.write(index);
Serial.write(pwm[index]);
Serial.write(dir[index]);
delay(50);
if(Serial.available() > 0 && Serial.read() == led1)
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
Receive:
int inData[4]; // Allocate some space for the Bytes
int index;
int pwm;
int dir;
int motorPin[] = {
6, 9, 10, 11};
int dirPin[] = {
2, 3, 4, 5};
int sync = 0xAA;
int led1 = 0xBB;
int led2 = 0xCC;
// 0 = left, 1 = right, 2 = vertical
void setup(){
for (int x = 0; x < 4; x++){
pinMode(motorPin[x], OUTPUT);
pinMode(dirPin[x], OUTPUT);
boolean recieve(){
if(Serial.available() > 0 && Serial.read() == sync){ //If there is a Serial message waiting and the Serial is sync, then proceed
delay(2);
index = Serial.read(); // index
delay(2);
pwm = Serial.read(); // pwm value
delay(2);
dir = Serial.read(); // dir value
delay(2); // YOU NEED DELAY, delay prevents garbled messages. (saves you from headaches)
return true;
return false;
if (recieve()){
Serial.print(led1, BYTE);
if(dir == 1)
dir = HIGH;
else if(dir == 0)
dir = LOW;
switch(index){
case 0:
analogWrite(motorPin[0], pwm);
digitalWrite(dirPin[0], dir);
case 1:
analogWrite(motorPin[1], pwm);
digitalWrite(dirPin[1], dir);
case 2:
analogWrite(motorPin[2], pwm);
analogWrite(motorPin[3], pwm);
digitalWrite(dirPin[2], dir);
digitalWrite(dirPin[3], dir);
Serial.print(led2, BYTE);
Please help!
