Hello I am working on a project that requires me to send sensor data attached to arduino to thingspeak. Previously I was using a GSM module but Now I have shifted to LoRa. I have seen some example code like this one
#include <SPI.h>
#include <RH_RF95.h>
RH_RF95 rf95;
#define dht_dpin A0 // Use A0 pin as Data pin for DHT11.
byte bGlobalErr;
char dht_dat[5]; // Store Sensor Data
char node_id[3] = {1, 1, 1}; //LoRa End Node ID
float frequency = 868.0;
unsigned int count = 1;
InitDHT();
if (!rf95.init())
Serial.println("init failed");
// Setup ISM frequency
rf95.setFrequency(frequency);
// Setup Power,dBm
rf95.setTxPower(13);
rf95.setSyncWord(0x34);
Serial.println("LoRa End Node Example --");
Serial.println(" DHT11 Temperature and Humidity Sensor\n");
Serial.print("LoRa End Node ID: ");
for (int i = 0; i < 3; i++)
Serial.print(node_id[i], HEX);
void InitDHT()
pinMode(dht_dpin, OUTPUT); //Set A0 to output
digitalWrite(dht_dpin, HIGH); //Pull high A0
//Get Sensor Data
void ReadDHT()
bGlobalErr = 0;
byte dht_in;
byte i;
//pinMode(dht_dpin,OUTPUT);
digitalWrite(dht_dpin, LOW); //Pull Low A0 and send signal
delay(30);//Delay > 18ms so DHT11 can get the start signal
delayMicroseconds(40);//Check the high level time to see if the data is 0 or 1
pinMode(dht_dpin, INPUT);
// delayMicroseconds(40);
dht_in = digitalRead(dht_dpin); //Get A0 Status
// Serial.println(dht_in,DEC);
if (dht_in) {
bGlobalErr = 1;
return;
delayMicroseconds(80);//DHT11 send response, pull low A0 80us
if (!dht_in) {
bGlobalErr = 2;
return;
for (i = 0; i < 5; i++) //Get sensor data
dht_dat[i] = read_dht_dat();
digitalWrite(dht_dpin, HIGH); //release signal and wait for next signal
byte dht_check_sum = dht_dat[0] + dht_dat[1] + dht_dat[2] + dht_dat[3]; //calculate check sum
if (dht_dat[4] != dht_check_sum) //check sum mismatch
bGlobalErr = 3;
byte read_dht_dat() {
byte i = 0;
byte result = 0;
for (i = 0; i < 8; i++)
while (digitalRead(dht_dpin) == LOW); //wait 50us
delayMicroseconds(30);//Check the high level time to see if the data is 0 or 1
if (digitalRead(dht_dpin) == HIGH)
result |= (1 << (7 - i)); //
while (digitalRead(dht_dpin) == HIGH); //Get High, Wait for next data sampleing.
return result;
uint16_t calcByte(uint16_t crc, uint8_t b)
uint32_t i;
crc = crc ^ (uint32_t)b << 8;
for ( i = 0; i < 8; i++)
if ((crc & 0x8000) == 0x8000)
crc = crc << 1 ^ 0x1021;
crc = crc << 1;
return crc & 0xffff;
uint16_t CRC16(uint8_t *pBuffer, uint32_t length)
uint16_t wCRC16 = 0;
uint32_t i;
if (( pBuffer == 0 ) || ( length == 0 ))
return 0;
for ( i = 0; i < length; i++)
wCRC16 = calcByte(wCRC16, pBuffer[i]);
return wCRC16;
Serial.print("########### ");
Serial.print("COUNT=");
Serial.print(count);
Serial.println(" ###########");
count++;
ReadDHT();
char data[50] = {0} ;
int dataLength = 7; // Payload Length
// Use data[0], data[1],data[2] as Node ID
data[0] = node_id[0] ;
data[1] = node_id[1] ;
data[2] = node_id[2] ;
data[3] = dht_dat[0];//Get Humidity Integer Part
data[4] = dht_dat[1];//Get Humidity Decimal Part
data[5] = dht_dat[2];//Get Temperature Integer Part
data[6] = dht_dat[3];//Get Temperature Decimal Part
switch (bGlobalErr)
case 0:
Serial.print("Current humidity = ");
Serial.print(data[3], DEC);//Show humidity
Serial.print(".");
Serial.print(data[4], DEC);//Show humidity
Serial.print("% ");
Serial.print("temperature = ");
Serial.print(data[5], DEC);//Show temperature
Serial.print(".");
Serial.print(data[6], DEC);//Show temperature
Serial.println("C ");
case 1:
Serial.println("Error 1: DHT start condition 1 not met.");
case 2:
Serial.println("Error 2: DHT start condition 2 not met.");
case 3:
Serial.println("Error 3: DHT checksum error.");
default:
Serial.println("Error: Unrecognized code encountered.");
uint16_t crcData = CRC16((unsigned char*)data, dataLength); //get CRC DATA
//Serial.println(crcData,HEX);
Serial.print("Data to be sent(without CRC): ");
int i;
for (i = 0; i < dataLength; i++)
Serial.print(data[i], HEX);
Serial.print(" ");
unsigned char sendBuf[50] = {0};
sendBuf[i] = data[i] ;
sendBuf[dataLength] = (unsigned char)crcData; // Add CRC to LoRa Data
sendBuf[dataLength + 1] = (unsigned char)(crcData >> 8); // Add CRC to LoRa Data
Serial.print("Data to be sent(with CRC): ");
for (i = 0; i < (dataLength + 2); i++)
Serial.print(sendBuf[i], HEX);
Serial.print(" ");
rf95.send(sendBuf, dataLength + 2); //Send LoRa Data
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];//Reply data array
uint8_t len = sizeof(buf);//reply data length
if (rf95.waitAvailableTimeout(3000))// Check If there is reply in 3 seconds.
// Should be a reply message for us now
if (rf95.recv(buf, &len))//check if reply message is correct
if (buf[0] == node_id[0] && buf[1] == node_id[2] && buf[2] == node_id[2] ) // Check if reply message has the our node ID
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
Serial.print("Got Reply from Gateway: ");//print reply
Serial.println((char*)buf);
delay(400);
digitalWrite(4, LOW);
//Serial.print("RSSI: "); // print RSSI
//Serial.println(rf95.lastRssi(), DEC);
Serial.println("recv failed");//
rf95.send(sendBuf, strlen((char*)sendBuf));//resend if no reply
Serial.println("No reply, is LoRa gateway running?");//No signal reply
rf95.send(sendBuf, strlen((char*)sendBuf));//resend data
delay(30000); // Send sensor data every 30 seconds
Serial.println("");
This is the client side and for the server side the code is : Arduino-Profile-Examples/LG01_ThingSpeak_RESTful_Single_Data.ino at master · dragino/Arduino-Profile-Examples · GitHub
(Had to remove the code as it exceed maximum allowed characters.)
The issue is these are for a single sensor i.e DHT11. I have been trying to alter the code so that I can use multiple sensors like DS18B20, Turbidity sensor, pH sensor but so far I haven't been successful.
Currently I am trying out this code : https://community.thingspeak.com/forum/arduino/please-help/
and I am editing it as per my requirements. If anyone can link me to a forum with a solution to my problem or help me out with the code. I am new to LoRa.
