coding issues....
pinMode(Switch(INPUT_PULLUP);
this suggests something that doesn't match what you posted
you may need to post all of your code...
Ok, I see what your saying, but when I copied the error code in here, it inserted strange symbols in, so I tried to correct it myself, but got it wrong....
the coding is as the above set of code, and the error message is indeed
"pinMode(Switch, INPUT_PULLUP);"
sorry, my bad
Complete code which gives me the above error
#include "LiquidCrystal.h"
LiquidCrystal lcd(A5, A4, A3, A2, A1, A0);
#define RELAY_ON 0
#define RELAY_OFF 1
#define Buzzer 2     //output to buzzer +'ve
#define PIRin 3      //from PIR sensor
#define Switch 4     //switch to reverse trigger LED's for exit
// #define Turnon 1     //switch LED's on until switched off
#define RELAY1 5     //relay for LED light section 1  by post
#define RELAY2 6     //relay for LED light section 2
#define RELAY3 7     //relay for LED light section 3
#define RELAY4 8     //relay for LED light section 4
#define RELAY5 9     //relay for LED light section 5
#define RELAY6 10    //relay for LED light section 6
#define RELAY7 11    //relay for LED light section 7   step 1
#define RELAY8 12    //relay for LED light section 8   step 2
#define Led 13                 //LED to indicate outside lights triggereed
int count = 0;                 // Count the number of triggers
int Exit = LOW;                  // set Exit switch to LOW
int Gate = LOW;                  // Sets PIR Sensors to Low to start with
// PIR power =  Brown >  blue > Yellow
//     earth =  Green >  black > Green
//     signal = Orange > yellow > Orange
  lcd.begin(16, 2);        // set up the LCD's number of columns(16) and rows(2):
    Serial.begin (9600);       // initiate serial com
      // Initialise the Arduino data pins for OUTPUT / INPUT options
      pinMode(RELAY1, OUTPUT);
      pinMode(RELAY2, OUTPUT);
      pinMode(RELAY3, OUTPUT);
      pinMode(RELAY4, OUTPUT);
      pinMode(RELAY5, OUTPUT);
      pinMode(RELAY6, OUTPUT);
      pinMode(RELAY7, OUTPUT);
      pinMode(RELAY8, OUTPUT);
      pinMode(PIRin,   INPUT);
      pinMode(Led,    OUTPUT);
      pinMode(Buzzer, OUTPUT);
      // set the outputs ready to start
      digitalWrite(RELAY1, RELAY_OFF);
      digitalWrite(RELAY2, RELAY_OFF);
      digitalWrite(RELAY3, RELAY_OFF);
      digitalWrite(RELAY4, RELAY_OFF);
      digitalWrite(RELAY5, RELAY_OFF);
      digitalWrite(RELAY6, RELAY_OFF);
      digitalWrite(RELAY7, RELAY_OFF);
      digitalWrite(RELAY8, RELAY_OFF);
      Gate = digitalRead(PIRin);            // read and rename input value
      Exit = digitalRead(Switch);           // read and rename input value
      lcd.setCursor(0, 0);
      lcd.print("  CALIBRATING! ");
      delay (1000);
      lcd.setCursor(0, 1);
      lcd.print(count);
      lcd.setCursor(3, 1);
      lcd.print(" Objects Seen");
    Serial.println(Exit);
   // Serial.println(PIRin);
  lcd.setCursor(0, 0);                // set up lcd display with text..
  lcd.print(" STAND BY MODE! ");
  lcd.print(count);
  digitalWrite(Led, LOW);
  delay (1250);                   // stablise sensor signal
  if (Exit == HIGH)        // check switch settig for exit mode
    lcd.print("  <EXIT MODE!>  ");
    Serial.println("EXIT");
    digitalWrite(Led, HIGH);      // set LED HIGH
    digitalWrite(Buzzer, HIGH);   // Beep.. (single for exit)
    delay (50);
    digitalWrite(Buzzer, LOW);
    digitalWrite(RELAY8, RELAY_ON);
    delay (300);                      //time ON between each light
    digitalWrite(RELAY7, RELAY_ON);
    delay (300);
    digitalWrite(RELAY6, RELAY_ON);
    delay (300);
    digitalWrite(RELAY5, RELAY_ON);
    delay (300);
    digitalWrite(RELAY4, RELAY_ON);
    delay (300);
    digitalWrite(RELAY3, RELAY_ON);
    delay (300);
    digitalWrite(RELAY2, RELAY_ON);
    delay (300);
    digitalWrite(RELAY1, RELAY_ON);
    delay (4000);                     // TIME ALL ON....
    delay (100);                      //time OFF between each light
    delay (100);
    delay (200);
    delay (200);
    delay (200);
    delay (200);
    delay (200);
    delay (500);                     // TIME ALL OFF BEFORE RETRIGGER
  if (Gate == HIGH)                     // check if the input from PIR is HIGH
    Serial.println("Detected something...");
    count++ ;                          // increase "Objects seen" count by 1
    lcd.print(count);
    lcd.print(" LIGHTS ARE ON!");      // Display "Light are On" on LCD inside
    digitalWrite(Led, HIGH);            // turn LED ON
    digitalWrite(Buzzer, HIGH);         //Beep beep
    delay (50);
    delay (50);
    delay (50);
    delay (300);
    delay (300);
    delay (300);
    delay (300);
    delay (300);
    delay (300);
    delay (3000);                         // TIME ALL ON....
    delay (150);                         //time OFF between each light
    delay (150);
    delay (150);
    delay (150);
    delay (150);
    delay (150);
    delay (150);
    digitalWrite(Led, LOW);          // turn LED off again
ok, seems like it was just one to many "spaces" between Switch, and INPUT_PULLUP....
but it still loops in Exit mode....
I'm going to start the wiring side again... if you guys say the code is good (which surprises me I got this close on my own after only a month or so of coding ), then it must be a mix up with the wiring....
Don't forget that input pullup means that you need to check for Exit being low when the switch is pressed. And of course you will need to adjust the wiring to accommodate that too.
Right, sorted a lot out, everything seems to work ok, apart from (theres always an "apart from") from when I enter "temp on" (ie flick a rocker switch)
I want it to keep the lights on (ie relays turned on) until the switch is released...
at the moment in te following code, it does that, but also keeps looking for other inputs from the PIR and EXIT switch...... how can I make the code ignore other input when it has the TEMP or TURNON input HIGH...
#define RELAY_ON 0
#define RELAY_OFF 1
int Temp = LOW;                   // set Switch for turning lights temp (no timer!)
   // Serial.begin (9600);       // initiate serial com
      pinMode(Switch, INPUT);
      delay (1000);
      lcd.print(count);
   Temp = digitalRead(Turnon);           // read and rename input value
   // Serial.println(Exit);
  lcd.print(count);
 // delay (1250);                   // stablise sensor signal
  //  Serial.println("EXIT");
  //  digitalWrite(Led, HIGH);      // set LED HIGH
    delay (50);
    digitalWrite(RELAY8, RELAY_ON);   //Turn relays ON in sequence 8 > 1
    delay (300);
    delay (300);
    delay (300);
    delay (300);
    delay (300);
    delay (300);
    digitalWrite(RELAY8, RELAY_OFF);   //Turn relays OFF in sequence 1 > 8
    delay (100);
    delay (200);
    delay (200);
    delay (200);
    delay (200);
    delay (200);
    // delay (500);                     // TIME ALL OFF BEFORE RETRIGGER
   // Serial.println("Detected something...");
    lcd.print(count);
    delay (50);
    delay (50);
    delay (50);
    digitalWrite(RELAY1, RELAY_ON);   //Turn relays on in sequence 1 > 8
    delay (300);
    delay (300);
    delay (300);
    delay (300);
    delay (300);
    delay (300);
    digitalWrite(RELAY1, RELAY_OFF);   //Turn relays OFF in sequence 1 > 8
    delay (150);
    delay (150);
    delay (150);
    delay (150);
    delay (150);
    delay (150);
if (Temp == HIGH)
    lcd.print("  <TEMP MODE!>  ");      // to turn led ON until switched off...
  //  Serial.println("TEMP ON");
  // digitalWrite(Buzzer, HIGH);   // Beep.. (single for exit)
  //  delay (50);
    digitalWrite(RELAY6, RELAY_ON);   //Turn relays ON in sequence ...
    delay (00);                      //time ON between each light
    delay (350);
    delay (00);
    delay (350);
    delay (00);
    delay (350);
    delay (00);
   else if (Temp == LOW)
    digitalWrite(RELAY8, RELAY_OFF);   //Turn relays ON in sequence ...
    delay (00);                      //time OFF between each light
    delay (350);
    delay (00);
    delay (350);
    delay (00);
    delay (350);
    delay (00);
    // delay (100);                     // TIME ALL OFF BEFORE RETRIGGER
if ((Exit == HIGH) && (Temp == LOW))
