high is this how i'd do the other code it's showing a cupple of errors not sure if it's right?
#include <MIDI.h>
#include "Controller.h"
MIDI CONTROLLER
by Notes and Volts
www.notesandvolts.com
Version 1.2 **Arduino UNO ONLY!**
MIDI_CREATE_DEFAULT_INSTANCE();
//***SET THE NUMBER OF CONTROLS USED**************************
//---How many buttons are connected directly to pins?---------
byte NUMBER_BUTTONS = 5;
//---How many potentiometers are connected directly to pins?--
byte NUMBER_POTS = 4;
//---How many buttons are connected to a multiplexer?---------
byte NUMBER_MUX_BUTTONS = 0;
//---How many potentiometers are connected to a multiplexer?--
byte NUMBER_MUX_POTS = 0;
const int LED1Pin = 12;
const int LED2Pin = 11;
const int LED3Pin = 10;
const int LED4Pin = 9;
const int LED5Pin = 8;
//***ANY MULTIPLEXERS? (74HC4067)************************************
//MUX address pins must be connected to Arduino UNO pins 2,3,4,5
//A0 = PIN2, A1 = PIN3, A2 = PIN4, A3 = PIN5
//Mux NAME (OUTPUT PIN, , How Many Mux Pins?(8 or 16) , Is It Analog?);
//Mux M1(10, 16, false); //Digital multiplexer on Arduino pin 10
//Mux M2(A5, 8, true); //Analog multiplexer on Arduino analog pin A0
//***DEFINE DIRECTLY CONNECTED POTENTIOMETERS************************
//Pot (Pin Number, Command, CC Control, Channel Number)
//**Command parameter is for future use**
Pot PO1(A0, 0, 1, 1);
Pot PO2(A1, 0, 10, 1);
Pot PO3(A2, 0, 22, 1);
Pot PO4(A3, 0, 118, 1);
//Pot PO5(A4, 0, 30, 1);
//Pot PO6(A5, 0, 31, 1);
//Add pots used to array below like this-> Pot *POTS[] {&PO1, &PO2, &PO3, &PO4, &PO5, &PO6};
Pot *POTS[] {&PO1, &PO2, &PO3, &PO4};
//***DEFINE DIRECTLY CONNECTED BUTTONS*******************************
//Button (Pin Number, Command, Note Number, Channel, Debounce Time)
//** Command parameter 0=NOTE 1=CC 2=Toggle CC **
Button BU1(2, 2, 60, 1, 5 );
Button BU2(3, 2, 61, 1, 5 );
Button BU3(4, 2, 62, 1, 5 );
Button BU4(5, 2, 63, 1, 5 );
Button BU5(6, 2, 64, 1, 5 );
//Button BU6(7, 0, 65, 1, 5 );
//Button BU7(8, 1, 64, 1, 5 );
//Button BU8(9, 2, 64, 1, 5 );
//Add buttons used to array below like this-> Button *BUTTONS[] {&BU1, &BU2, &BU3, &BU4, &BU5, &BU6, &BU7, &BU8};
Button *BUTTONS[] {&BU1, &BU2, &BU3, &BU4, &BU5};
//***DEFINE BUTTONS CONNECTED TO MULTIPLEXER*************************
//Button::Button(Mux mux, byte muxpin, byte command, byte value, byte channel, byte debounce)
//Button MBU1(M1, 0, 0, 70, 1, 5);
//Button MBU2(M1, 1, 1, 71, 1, 5);
//Button MBU3(M1, 2, 2, 72, 1, 5);
//Button MBU4(M1, 3, 0, 73, 1, 5);
//Button MBU5(M1, 4, 0, 74, 1, 5);
//Button MBU6(M1, 5, 0, 75, 1, 5);
//Button MBU7(M1, 6, 0, 76, 1, 5);
//Button MBU8(M1, 7, 0, 77, 1, 5);
//Button MBU9(M1, 8, 0, 78, 1, 5);
//Button MBU10(M1, 9, 0, 79, 1, 5);
//Button MBU11(M1, 10, 0, 80, 1, 5);
//Button MBU12(M1, 11, 0, 81, 1, 5);
//Button MBU13(M1, 12, 0, 82, 1, 5);
//Button MBU14(M1, 13, 0, 83, 1, 5);
//Button MBU15(M1, 14, 0, 84, 1, 5);
//Button MBU16(M1, 15, 0, 85, 1, 5);
////Add multiplexed buttons used to array below like this-> Button *MUXBUTTONS[] {&MBU1, &MBU2, &MBU3, &MBU4, &MBU5, &MBU6.....};
Button *MUXBUTTONS[] {};
//***DEFINE POTENTIOMETERS CONNECTED TO MULTIPLEXER*******************
//Pot::Pot(Mux mux, byte muxpin, byte command, byte control, byte channel)
//Pot MPO1(M2, 0, 0, 1, 1);
//Pot MPO2(M2, 1, 0, 7, 1);
//Pot MPO3(M2, 2, 0, 50, 1);
//Pot MPO4(M2, 3, 0, 55, 2);
//Pot MPO5(M2, 4, 0, 50, 1);
//Pot MPO6(M2, 5, 0, 55, 2);
//Pot MPO7(M2, 6, 0, 50, 1);
//Pot MPO8(M2, 7, 0, 55, 2);
//Pot MPO9(M2, 8, 0, 50, 1);
//Pot MPO10(M2, 9, 0, 55, 2);
//Pot MPO11(M2, 10, 0, 50, 1);
//Pot MPO12(M2, 11, 0, 55, 2);
//Pot MPO13(M2, 12, 0, 50, 1);
//Pot MPO14(M2, 13, 0, 55, 2);
//Pot MPO15(M2, 14, 0, 50, 1);
//Pot MPO16(M2, 15, 0, 55, 2);
//Add multiplexed pots used to array below like this-> Pot *MUXPOTS[] {&MPO1, &MPO2, &MPO3, &MPO4, &MPO5, &MPO6.....};
Pot *MUXPOTS[] {};
MIDI.begin(MIDI_CHANNEL_OFF);
pinMode(LED1Pin, OUTPUT);
pinMode(LED2Pin, OUTPUT);
pinMode(LED3Pin, OUTPUT);
pinMode(LED4Pin, OUTPUT);
pinMode LED4Pin, OUTPUT);
if (NUMBER_BUTTONS != 0) updateButtons();
if (NUMBER_POTS != 0) updatePots();
if (NUMBER_MUX_BUTTONS != 0) updateMuxButtons();
if (NUMBER_MUX_POTS != 0) updateMuxPots();
void updateButtons() {
// Cycle through Button array
for (int i = 0; i < NUMBER_BUTTONS; i = i + 1) {
byte message = BUTTONS[i]->getValue();
// Button is pressed
if (message == 0) {
switch (BUTTONS[i]->Bcommand) {
case 0: //Note
MIDI.sendNoteOn(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
case 1: //CC
MIDI.sendControlChange(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
case 2: //Toggle
if (BUTTONS[i]->Btoggle == 0) {
BUTTONS[i]->Btoggle = 1;
else if (BUTTONS[i]->Btoggle == 1) {
MIDI.sendControlChange(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
BUTTONS[i]->Btoggle = 0;
// Button is not pressed
if (message == 1) {
case 0:
MIDI.sendNoteOff(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
case 1:
void updateMuxButtons() {
// Cycle through Mux Button array
for (int i = 0; i < NUMBER_MUX_BUTTONS; i = i + 1) {
MUXBUTTONS[i]->muxUpdate();
byte message = MUXBUTTONS[i]->getValue();
if (message == 0) {
switch (MUXBUTTONS[i]->Bcommand) {
case 0: //Note
MIDI.sendNoteOn(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
case 1: //CC
MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
case 2: //Toggle
if (MUXBUTTONS[i]->Btoggle == 0) {
MUXBUTTONS[i]->Btoggle = 1;
else if (MUXBUTTONS[i]->Btoggle == 1) {
MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
MUXBUTTONS[i]->Btoggle = 0;
if (message == 1) {
case 0:
MIDI.sendNoteOff(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
case 1:
void updatePots() {
for (int i = 0; i < NUMBER_POTS; i = i + 1) {
byte potmessage = POTS[i]->getValue();
if (potmessage != 255) MIDI.sendControlChange(POTS[i]->Pcontrol, potmessage, POTS[i]->Pchannel);
void updateMuxPots() {
for (int i = 0; i < NUMBER_MUX_POTS; i = i + 1) {
MUXPOTS[i]->muxUpdate();
byte potmessage = MUXPOTS[i]->getValue();
if (potmessage != 255) MIDI.sendControlChange(MUXPOTS[i]->Pcontrol, potmessage, MUXPOTS[i]->Pchannel);
//LED1 set trigger at button press for button 1
if (Button BU1 == HIGH)
digitalWrite(LED1Pin, HIGH);
digitalWrite(LED1Pin, LOW);
// same for led2 button 2
if (Button BU2 == HIGH)
digitalWrite(LED2Pin, HIGH);
digitalWrite(LED2Pin, LOW);
//same for led 3 button 3
if (Button BU3] == HIGH)
digitalWrite(LED3Pin, HIGH);
digitalWrite(LED3Pin, LOW);
//same for led4 to button 4
if (Button BU4 == HIGH)
digitalWrite(LED4Pin, HIGH);
digitalWrite(LED4Pin, LOW);
//same for led5 button 5
if (Button BU5 == HIGH)
digitalWrite(LED5Pin, HIGH);
digitalWrite(LED5Pin, LOW);
this is controller.h
#ifndef Controller_h
#define Controller_h
#include <Arduino.h>
class Mux
public:
Mux(byte outpin_, byte numPins_, bool analog_);
byte outpin;
byte numPins;
bool analog;
class Button
public:
Button(byte pin, byte command, byte value, byte channel, byte debounce);
Button(Mux mux, byte muxpin, byte command, byte value, byte channel, byte debounce);
byte getValue();
void muxUpdate();
void newValue(byte command, byte value, byte channel);
byte Bcommand;
byte Bvalue;
byte Bchannel;
byte Btoggle;
private:
byte _previous;
byte _current;
unsigned long _time;
int _debounce;
byte _pin;
byte _muxpin;
byte _numMuxPins;
byte _value;
byte _command;
bool _busy;
byte _status;
byte _last;
byte _enablepin;
class Pot
public:
Pot(byte pin, byte command, byte control, byte channel);
Pot(Mux mux, byte muxpin ,byte command, byte control, byte channel);
void muxUpdate();
byte getValue();
byte Pcommand;
byte Pcontrol;
byte Pchannel;
private:
byte _pin;
byte _muxpin;
byte _numMuxPins;
byte _control;
int _value;
int _oldValue;
bool _changed;
byte _enablepin;
#endif
thie is controller.cpp
Mux::Mux(byte outpin_, byte numPins_, bool analog_)
outpin = outpin_;
//enablepin = enablepin_;
numPins = numPins_;
analog = analog_;
if (analog == false) pinMode(outpin, INPUT_PULLUP);
//pinMode(enablepin, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
if (numPins > 8) pinMode(5, OUTPUT);
Button::Button(byte pin, byte command, byte value, byte channel, byte debounce)
_pin = pin;
pinMode(_pin, INPUT_PULLUP);
_value = value;
_command = command;
_debounce = debounce;
_time = 0;
_busy = false;
_status = 0b00000010;
_last = 1;
Bcommand = command;
Bvalue = value;
Bchannel = channel;
Btoggle = 0;
_pin = mux.outpin;
_numMuxPins = mux.numPins;
_muxpin = muxpin;
_value = value;
_command = command;
_time = 0;
_busy = false;
_last = 1;
Bcommand = command;
Bvalue = value;
Bchannel = channel;
Btoggle = 0;
void Button::muxUpdate()
byte temp = _muxpin;
temp = temp << 2;
if (_numMuxPins > 8) PORTD = PORTD & B11000011;
else PORTD = PORTD & B11100011;
PORTD = PORTD | temp;
byte Button::getValue()
// If BUSY bit not set - read button
if (bitRead(_status, 0) == false) { // If busy false
if (digitalRead(_pin) == _last) return 2; // If same as last state - exit
// If NEW Bit set - Key just pressed, record time
if (bitRead(_status, 1) == true) { // If new is true
bitSet(_status, 0); // Set busy TRUE
bitClear(_status, 1); // Set New FALSE
_time = millis();
return 255;
// Check if debounce time has passed - If no, exit
if (millis() - _time < _debounce) return 255;
// Debounce time has passed. Read pin to see if still set the same
// If it has changed back - assume false alarm
if (digitalRead(_pin) == _last) {
bitClear(_status, 0); // Set busy false
bitSet(_status, 1); // Set new true
return 255;
// If this point is reached, event is valid. return event type
else {
_last = ((~_last) & 0b00000001); // invert _last
return _last;
void Button::newValue(byte command, byte value, byte channel)
Bvalue = value;
Bcommand = command;
Bchannel = channel;
Pot::Pot(byte pin, byte command, byte control, byte channel)
_pin = pin;
_control = control;
_value = analogRead(_pin);
_value = _value >> 3;
_oldValue = _value << 3;
_value = _value << 3;
Pcommand = command;
Pcontrol = control;
Pchannel = channel;
void Pot::muxUpdate()
temp = temp << 2;
//PORTD = PORTD & B11000011;
_pin = mux.outpin;
_muxpin = muxpin;
_control = control;
muxUpdate();
Pcommand = command;
Pcontrol = control;
Pchannel = channel;
byte Pot::getValue()
int tmp = (_oldValue - _value);
if (tmp >= 8 || tmp <= -8) {
_oldValue = _value >> 3;
_oldValue = _oldValue << 3;
return _value >> 3;
return 255;
void Pot::newValue(byte command, byte value, byte channel) {
Pcommand = command;
Pcontrol = value;
Pchannel = channel;
