Coding questions relating to accelerometer
Hi. Im very new to Arduino and have a question relating to a project I am attempting.
I am making 2 Axis digital level using an AM3X accelerometer and Uno.
I have 5 led’s in an X. Up, down, left and right, and centre.
I can get the directional led’s to work, but not the centre one.
I dont know how to specify a range of numbers for the centreLed to go to HIGH, or if that is even how I would approach it.
I have these numbers being read off my accelerometer, and want the centre led to go HIGH when within these, or go LOW when outside them, so between Xaxis 330 and 340, and Yaxis 350 and 360.
I hope I am not too confusing with my question, but I am a noob.
Thanks heaps in advance, I would really appreciate some help from the gurus here.
Scott
const int forwardThreshold = 340;
const int backwardThreshold = 330;
const int leftThreshold = 360;
const int rightThreshold = 350;
My code is such
int xAxis = A0;
int yAxis = A1;
int zAxis = A2;
int axisValue = 0;
int centreLed = 13;
int forwardLed = 2;
int backwardLed = 3;
int leftLed = 4;
int rightLed = 5;
Serial.begin(38400);
Serial.println(“Starting up”);
pinMode(forwardLed, OUTPUT);
pinMode(backwardLed, OUTPUT);
pinMode(leftLed, OUTPUT);
pinMode(rightLed, OUTPUT);
pinMode(centreLed, OUTPUT);
// X axis
axisValue = analogRead(xAxis);
Serial.print(“X=”);
Serial.print(axisValue);
// centre led
// Forward LED
if (axisValue > forwardThreshold) {
digitalWrite(forwardLed, HIGH);
else {
digitalWrite(forwardLed, LOW);
// Backward LED
if (axisValue < backwardThreshold) {
digitalWrite(backwardLed, HIGH);
else {
digitalWrite(backwardLed, LOW);
// Y Axis
axisValue = analogRead(yAxis);
Serial.print(",Y=");
// Left LED
if (axisValue > leftThreshold) {
digitalWrite(leftLed, HIGH);
else {
digitalWrite(leftLed, LOW);
// Right LED
if (axisValue < rightThreshold) {
digitalWrite(rightLed, HIGH);
else {
digitalWrite(rightLed, LOW);
// Z Axis
axisValue = analogRead(zAxis);
Serial.print(",Z=");
Serial.println(axisValue);
delay(200);
Untested code warning.
Semi-pseudo code warning.
Firstly, rather than hide your evaluation amongst the control branches I’d evaluate and the state of the two axis early (shown below in left_right and forward_backward). It makes the code easier to read, test and maintain.
I think what you seem to be struggling with is checking when a value is between two limits, which is demonstrated below.
typedef left_right_t {LEFT, CENTRE_LR, RIGHT};
typedef forward_backward_t {FORWARD, CENTER_FB, BACKWARD};
    left_right_t : left_right;
   forward_backward_t: forward_backward;
    // Get X, Y (anareads etc...)
   if (x < leftThreshhold)
      left_right = LEFT;
   else if ((x >= leftThreshhold )  && (x <= rightThreshhold))
      left_right = CENTRE_LR;
      left_right = RIGHT;
   if (y < forwardThreshhold)
      forward_backward = FORWARD;
   else if ((y >= forwardThreshhold )  && (y <= backwardThreshhold))
      forward_backward = CENTRE_FB;
      forward_backward = BACKWARDS;
   // Extinguish the centre LED
   // Extinguish the forward and backward LED
   switch (forward_backward)
       case FORWARDS:
          // Light the forwards LED
       case BACKWARDS:
          // Light the backwards LED
       case CENTRE_FB:
         // Light the centre LED
   // Extinguish the left and centre LED .... DO NOT EXTINGUISH THE CENTRE!
   switch (left_right)
       case LEFT:
          // Light the LEFT LED
       case RIGHT:
          // Light the RIGHT LED
       case CENTRE_FB:
          // Light the CENTRE LED
Actually, I don’t like the switch statements. You could evaluate each LED on the logical states of the left_right, forward_backward, replacing switch statements with:-
      left_right = LEFT;
      left_right = RIGHT;
   digitalWrite(ForwardLed, (forward_backward == FORWARD));
   digitalWrite(BackwardLed, (forward_backward == BACKWARD));
   digitalWrite(LeftLed, (left_right == LEFT));
   digitalWrite(RightLed, (left_right == RIGHT));
   digitalWrite(CentreLed, ((left_right == CENTRE_LR) || (forward_backward == CENTRE_FB));
Thank you for your reply , and your time in writing to me.
I'm trying really hard to understand what it means but, or how I would use that in my code, or where I would put it in my code. I'm only a noob and 12 years old. It's really hard to find how to do this stuff. Would there be a way of saying "if pins 1,2,3,4 etc are LOW then make pin 12 HIGH?
if ( (digitalRead(1) == LOW) && (digitalRead(2) == LOW) && (digitalRead(3) == LOW) )
   digitalWrite(12, HIGH);
NOTE - using pin 1 is not a good idea because it is used for serial communication on many Arduino boards.
