Hello all,
I have mix matched some coding and even hired a freelancer to help with the final program but have lost contact with the freelancer and am way outside my level of knowledge now. I am hoping to trouble shot the code I have.
A little background, I have a Nano 33 IOT, it is attached to an HC-SRO4 ultrasonic sensor. I am trying to send the accelerometer and ultrasonic data wirelessly to my computer. The code also has a few formulas in it along the way. Essentially this device will attach to a barbell, when the barbell is lifted it will measure distance traveled, velocity, time, power and a couple other simple math calculations.
I asked the freelancer to have the code start when I put a number into the serial input, this will be the weight being lifted. Which will also be used in some of the calculations down the line.
As of now I believe I am able to connect to my wifi, and get an IP address, I am supposed to put this in a web browser to see the data. The web page never loads. When I type something into the serial input I get a few random Weights spit out and nothing else more.
The code is below, along with some picture references of the serial monitor.
Any input is appreciated.
#include <SPI.h>
#include <WiFiNINA.h>
#include <Arduino_LSM6DS3.h>
#define trigPin 10
#define echoPin 12
#define SECRET_SSID "****"
#define SECRET_PASS "****"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key index number (needed only for WEP)
float x, y, z;
int input = 0;
String input1 = "";
int status = WL_IDLE_STATUS;
boolean isInput1 = true;
boolean isInput2 = false;
boolean isInputDone = false;
float G = 0;
float state_G = 0;
float max_G = 0;
float state_dist = 0;
float max_dist = 0;
boolean time1 = false;
boolean get_data = true;
boolean get_data_done = false;
boolean cal_data = false;
int weight = 0;
float F = 0;
float previousDist = 0;
float main_dist = 0;
int main_time = 0;
float V = 0;
float W = 0;
float P = 0;
float N = 0;
float distance = 0;
long duration = 0;
static const unsigned long REFRESH_INTERVAL = 1000; // ms
static unsigned long lastRefreshTime = 0;
WiFiServer server(80);
Serial.begin(9600); // initialize serial communication
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT); // set the LED pin mode
get_dist();
previousDist = distance;
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to Network named: ");
Serial.println(ssid); // print the network name (SSID);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin(); // start the web server on port 80
printWifiStatus(); // you're connected now, so print out the status
if(isInput1){
while (Serial.available()) {
input += (char)Serial.read();
delay(5);
Serial.print("Weight = ");
Serial.print(input);
weight = input;
if(input >= 1){
isInput2 = true;
isInput1 = false;
if(isInput2){
input1 += (char)Serial.read();
delay(5);
if(input1 == "ok"){
isInputDone = true;
isInput2 = false;
if(isInputDone){
if(get_data){
get_accel();
if(x >= 1){
time1 = true;
get_accel();
get_dist();
state_G = x*9.80;
state_dist = distance;
if(state_dist > max_dist){
max_dist = state_dist;
if(state_G > max_G){
max_G = state_G;
if(time1 == true){
if(millis() - lastRefreshTime >= REFRESH_INTERVAL){
lastRefreshTime += REFRESH_INTERVAL;
if(x > 1){
time1 = false;
get_data_done = true;
get_data = false;
if(get_data_done){
F = weight*state_G;
main_dist = max_dist - previousDist;
main_time = lastRefreshTime/1000;
N = weight*9.806;
V = main_dist/main_time;
W = F*main_dist;
P = W*main_dist;
upload_data();
void upload_data(){
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
client.println("<p>Weight </p>");
client.println(weight);
client.println();
client.println("<p>Newtons </p>");
client.println(N);
client.println();
client.println("<p>Velocity </p>");
client.println(V);
client.println();
client.println("<p>Work </p>");
client.println(W);
client.println();
client.println("<p>Power </p>");
client.println(P);
client.println();
// break out of the while loop:
} else { // if you got a newline, then clear currentLine:
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Check to see if the client request was "GET /H" or "GET /L":
if (currentLine.endsWith("GET /H")) {
digitalWrite(9, HIGH); // GET /H turns the LED on
if (currentLine.endsWith("GET /L")) {
digitalWrite(9, LOW); // GET /L turns the LED off
// close the connection:
client.stop();
Serial.println("client disconnected");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
void get_accel(){
if (IMU.accelerationAvailable()) {
IMU.readAcceleration(x, y, z);
void get_dist(){
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration / 2) * .000343;
