Coding RGBs wont turn OFF!!!
Hi guys,
Stuck here, basically using my arduino uno. Using a button to turn two rgb leds on where they turn red then both green individually before turning off. Everything works great apart from at the end they wont turn off, instead they remain a yellowy colour.
Ive attached my code; any help would be great cheers!!!
int buttonState = 0;
pinMode(13, INPUT); // button
pinMode(11, OUTPUT); // rgb led 1
pinMode(10, OUTPUT); // rgb led 1
pinMode(6, OUTPUT); // rgb led 2
pinMode(5, OUTPUT); // rgb led 2
// read the state of the pushbutton
buttonState = digitalRead(13);
// check push button is pressed
if (buttonState == HIGH) {
analogWrite(11, 255);
analogWrite(10, 0);
analogWrite(6, 255);
analogWrite(5, 0);
delay(2000); // Wait for 2000 millisecond(s)
analogWrite(11, 0);
analogWrite(10, 153);
delay(4000); // Wait for 4000 millisecond(s)
analogWrite(6, 0);
analogWrite(5, 153);
delay(7000); // Wait for 7000 millisecond(s)
digitalWrite(11, LOW);
digitalWrite(10, LOW);
digitalWrite(6, LOW);
digitalWrite(5, LOW);
Do you have a pulldown resistor from the button input to ground?
hi there,
yes i have got one.
its the fact that i thought LOW meant it would be turned off but instead it seems to mean that its a yellowish colour.
Don't know if this is your problem, but get rid of
in your else clause.
It’s odd that you’re using 4 outputs for two 3-color LEDs… I think we need to see a schematic. And, you your comments don’t define the colors.
How about if you simply write all-low, do the LEDs go off? Do they go on when you write all-high? (That’s without the switch or any if-statements, etc.)
Can you control the colors individually without using the switch or if-statement?
evanmars:
Cheers, changed it but it didn't make a difference :confused:
DVDdoug:
It's odd that you're using 4 outputs for two 3-color LEDs... I think we need to see a schematic. And, you your comments don't define the colors.
How about if you simply write all-low, do the LEDs go off? Do they go on when you write all-high? (That's without the switch or any if-statements, etc.)
Hi there, Yeah I have attached a schematic at the top. basically I had it hooked up to all three but I couldn't get the correct colours or for it to turn off outside the "cycle" I have programmed.
