Hello, I have Arduino Leonardo and my problem concerns SPI together with COG LCD with a ST7565R controller. It's made by AV-Display and here is the connection schematic (at the bottom of the page) Wyświetlacze graficzne znakowe LCD OLED UART MONO TFT VFD LED - Artronic OPTOELEKTRONIKA
My questions:
Do I have to connect ALL the pins? I have only one device on SPI, so is it necessary to connect SS? It is problematic in Leonardo, because it doesn't have SS output pin on board, as presented here http://www.instructables.com/id/Step-by-Step-Guide-to-the-Arduino-Leonardo/?ALLSTEPS
If it is essential to use SS - can I use any Leonardo pin to act as a SS? -
Am I right that A0 can be connected to any Leonardo pin? http://edeca.net/downloads/electronics/ST7565R_V17_960601.pdf page 20: "This is connect to the least significant bit of the normal MPU address bus, and it
determines whether the data bits are data or command.
A0 = “H”: Indicates that D0 to D7 are display data.
A0 = “L”: Indicates that D0 to D7 are control data." -
RESET - on http://edeca.net/wp/electronics/the-st7565-display-controller/ it is written that "It is necessary to connect RESET to the microcontroller as the initialisation procedure involves toggling this pin. This pin should not be tied high or low or it may not be possible to reset the screen correctly."
However on a scheamtic I found on the web it is clearly drawn that RESET is connected to 3V3 by a 10k resistor and to ground by 100nF capacitor: http://gembcior.pl/wp-content/uploads/2014/09/LCD_schemat.jpg
Which approach is correct?
Thank You in advance for any help and suggestions!
