Coin Acceptor help. CH-268t
Has anyone every had some experience with the CH-268t? Below I will have the wiring instructions. Apparently it sends a pulse and the arduino is supposed to interpret this. I don’t know how to wire or program this and am in desperate need of help with that. I know the red and black wires and where they go but not the other wires. could really use some help on this. Essentially I want to make a counter for an arcade game I want to make.
White line—(N.C. signal)
Green line—(N.O. signal)
Gray line—Counter (Meter)
Yellow line—inhibit/low(<+1V)
Red line—PowerDC +12V
Black Line—Ground (GND)
Thank you to all who help.
Any chance of a link to the device? I would power it up and look at the grey line with a scope to see what it is producing before connecting it up to anything. It look like the yellow line has to be high as well but whether this is 5V or 12V I dont't know.
How can I do this with arduino?
With a voltage divider.
Ok so lets say I use a voltage divider and the Vout is 1.2 volts. How would I interpret that with arduino?
If pin1 = HIGH?
Or would it be analog?
Say the voltage is above 3volts, and attach it to a digital pin.
use 0V ----[10K]---- digital pin Arduino ----[20K] ---- 12 Volt
Then the arduino pin will get about 4 Volt (will be seen as a HIGH) , current will only be a about 0.4 mA
You could use one of the interrupt pins to measure the timing - see attachinterrupt() - if you want to
Ok so I’m totally lost and frustrated. Basically I bought a coin acceptor CH-268t. Been emailing seller and he told me that the pulse signal is 12v 20ms-100ms. I tried the voltage divider with R1 3.3kohms and R2 1.5kohms. The voltage input was 12v and the wiring for the CH-268t is:
All i got with Analog Input to serial and Digital input to serial was a bunch of numbers that don’t change even when I put a coin in the slot. Sometimes I’d get straight zeros down the line, but then again I don’t know if that was even the right sketch to use.
I’m totally lost and confused. I wanted to build a simple game machine for my little cousins but I don’t know how to continue from here on. If anyone has any ideas or suggestions I’d greatly appreciate them.
Like AWOL said, use a digital pin. Design the voltage divider so it turns +12V/0V into +5V/0V and attach it to a digital pin. Then use this sketch:
http://www.arduino.cc/en/Tutorial/Debounce
A switch on pin 2 should trigger the Arduino's LED. It will be a quick pulse.
I would change this line:
// set the LED using the state of the button:
   digitalWrite(ledPin, buttonState);
to this:
// toggle the LED using the state of the button:
if (lastButtonState != buttonState)
    digitalWrite(ledPin, !digitalRead(ledPin));
to make it a bit more friendly to read.
It depends on exactly what you are trying to measure.
In the simplest, a resistor would do (it measures the presence of a high voltage signal, potentially over a period of time), or a zener (it measures the presence of a specific range of a high voltage signal), to some adc.
Well Joen debounce did nothing. I took apart the hardware and played with it for a bit. The LED"s don' light up and the solenoid doesn't move. I'm going to see if I can return it or exchange it because I think it may be defective. Simply does nothing when I put a coin in.
Thank you all who have replied and helped me with this. I really appreciate it.
@hunter2379 - why do you post a question and then lock the thread?
Unlocked.
[quote author=Nick Gammon link=topic=127112.msg957148#msg957148 date=1350270764] @hunter2379 - why do you post a question and then lock the thread?
Unlocked. [/quote]
He asked this in at least one other message and it never got caught as a dupe (see http://arduino.cc/forum/index.php/topic,127204.0.html). In the other thread he has concluded that the device must be defective so he is sending it back. At that point I think he additionally concluded that continued discussion was a waste of everyone's time. But I am just guessing here. I had a discussion with him and he seems to be a nice guy and I suspect he didn't do it to intentionally irritate anyone or anything like that (like a different guy earlier this weekend).
OK, well that makes it less confusing.
Threads merged.
@hunter2379 - It's easier all round if you confine your questions about the same device to the same thread. You can see how confusing it is to ask about measuring voltages in one thread, and about the device for which you want to measure that voltage, in a different thread.
