im new here im wanted to ask if i can use 12V Mini Power Songle PCB Relay SPDT 10A SRD-12VDC-SL-C to my coin hopper with AC220V
That depends.
How much current does you coin hopper use?
it use 220 Volts AC
That is the voltage.
How many Amps does it need?
Looks like it has a fairly large motor, so I would be hesitant to say if the relay is OK without knowing the current rating.
The motor is a shaded pole induction motor.
Here is a quote from the web-page in the above link:
A major advantage is that the motor's stall current is only slightly higher than the running current, so there is low risk of severe over-heating or tripping the circuit protection if the motor is stalled for some reason.
For that reason, I don't think the starting current is going to be anywhere near 10A.
Bad.
Yeah i decided to use SSR-DA40 thanks
Why?
You know they do get Hot.
Use the Zero cross version
Very bad choice for a motor!
Why? I haven't experienced the kind of heating with on/off control that the OP is describing. In my experience, using on/off control helps eliminate a lot of the switching noise. I've had products in production for many years running both brushed and brushless motors without any issues. The solution I suggested is specifically intended for on/off control, not variable speed
im happy to say that im already done the project fotek SSR-DA40 works perfectly fine!! no heating
many thanks for suggestion ![]()
