When i insert any bill, always dispensing 5 coins.
I inserted 20 bill = 4 coins, still dispensing 5 coins
When I inserted 50 bill = 10 coins, still dispensing 5 coins
And when I inserted 100 = 20 coins, still dispensing 5 coins
Need help what is the problem with my code
//**************Variables ****************
volatile byte hopperPulseCount = 0; // a counter to track the number of coins dispensed
volatile unsigned long pulseTime; // stores the time of the last pulse
int coinValue = 0; // number of 10 pence coins to dispense based on bill value
//************Pins Used *******************
int hopperPin = 2; // pin2 as optical count input
int billAcceptorPin = 3; // pin3 as bill acceptor input
int relayPin = 7; // pin7 output relay
//**** pinModes *************
pinMode(hopperPin, INPUT_PULLUP); // hopper optical count is an input
pinMode(billAcceptorPin, INPUT_PULLUP); // bill acceptor input
pinMode (relayPin, OUTPUT); // relay pin output
digitalWrite(relayPin, HIGH); // turn off relay - active LOW.
digitalWrite(hopperPin, HIGH); // use the internal pullup resistor on the hopper optical input
attachInterrupt(0, hopper, FALLING); // Hopper - attach a PinChange Interrupt to our pin on the falling edge - link to hopper function
// Check for bill insertion signal from the bill acceptor
if (digitalRead(billAcceptorPin) == HIGH)
// Read the number of pulses from the bill acceptor
int pulses = countPulses();
// Determine the coin value based on the number of pulses
coinValue = calculateCoinValue(pulses);
// Process the coin value and dispense coins
dispense(coinValue);
//******INTERRUPT detecting pulses from the hopper
void hopper() //function called when a coin is ejected from the hopper
hopperPulseCount++;
int countPulses() {
int pulses = 0;
unsigned long startTime = millis(); // Start time for timeout
// Wait for the pulse to start
while (digitalRead(billAcceptorPin) == LOW) {
if (millis() - startTime > 1000) { // Timeout after 1 second
return 0; // No pulse detected
// Count the pulses while the signal is high
while (digitalRead(billAcceptorPin) == HIGH) {
pulses++;
delay(10); // Adjust delay as needed based on the pulse duration
return pulses;
int calculateCoinValue(int pulses) {
switch (pulses) {
case 2:
return 20; // 20 pence coins
case 5:
return 50; // 50 pence coins
case 10:
return 100; // 100 pence coins
default:
return 0; // Unknown or unsupported number of pulses
void dispense(int coinsToDispense)
digitalWrite(relayPin, LOW); // turn on relay - active LOW.
delay(50);
while (hopperPulseCount < coinsToDispense / 10)
// Wait until the required number of coins are dispensed
delay(50); // wait to ensure the coin has enough momentum to leave hopper but not long enough for another coins to dispense!
Here's a sample of code that shows how you can count pulses from a bill acceptor.
It is based on the techniques introduced in the "StateChangeDetection" example.
You would have to add the part to dispense the coins.
I've tested it with a range of pulses from 1Hz to 100Hz.
int billAcceptorPinState = LOW;
int lastBillAcceptorPinState = LOW;
int credit = 0;
int baseUnit = 5; // Number of £/€/$ per pulse
billAcceptorPinState = digitalRead(billAcceptorPin);
if (billAcceptorPinState != lastBillAcceptorPinState) {
if (billAcceptorPinState == HIGH) {
credit = credit + baseUnit;
Serial.println(credit);
lastBillAcceptorPinState = billAcceptorPinState;
this is my latest code now, but the pulse/signal still the same like this
20 bill = 2 pulse
50 bill = 5 pulse
100 bill = 10 pulse
how do i change the code to fix the pulse into like this
20 bill = 4 pulse
50 bill = 10 pulse
100 bill = 20 pulse
volatile int totalPulses = 0; // Variable to store the total pulses detected
volatile bool pulseDetected = false; // Flag to indicate pulse detection
attachInterrupt(digitalPinToInterrupt(billAcceptorPin), handlePulse, FALLING); // Attach interrupt on falling edge
// Wait for pulse detection
while (!pulseDetected) {
// Wait for the interrupt to set the flag
pulseDetected = false; // Reset the flag
int pulses = hopperPulseCount;
// Update the total pulses detected
totalPulses += pulses;
// Print the total pulses detected
Serial.print("Pulses detected: ");
Serial.println(totalPulses);
coinValue = calculateCoinValue(totalPulses);
hopperPulseCount++;
void handlePulse() {
hopperPulseCount++; // Increment pulse count
pulseDetected = true; // Set the flag to indicate pulse detection
int countPulses() {
hopperPulseCount = 0; // Reset pulse count
pulseDetected = false; // Reset pulse detection flag
return pulses;
switch (pulses) {
case 2:
return 20; // 20 peso coins
case 5:
return 50; // 50 peso coins
case 10:
return 100; // 100 peso coins
default:
// Introduce a small delay to allow the hopper motor to settle
//delay(100); // Adjust this delay as needed
